Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change
robert15ryba 108498 26
Why does the “car with key” warning in an Opel Corsa D 1.3 CDTI stay on after an oil and filter change, and can I drive with it?
The “car with key” light is not an oil-change reminder; it means an engine/management fault, so you should not assume the service fixed it and you should have the car diagnosed before a long trip [#14743167][#14745465] If the lamp is only the InSP/service reminder, it must be reset manually: press and hold the brake, hold the trip-reset button, turn the ignition on, keep holding until the display shows “----”, then switch off [#14743675] For this CDTI engine, forum users pointed to possible causes such as a clogged DPF, glow plug/preheat fault or glow plug controller, and even an EGR fault [#14742986][#14743421][#14743523][#15838093] A generic OBD reader may show nothing, so you need a proper Opel-specific or good universal diagnostic tester that scans all systems [#14755669][#21071524][#15832085] One reply warned that continuing to drive can lead to limited power or even the engine not starting, so a 200 km trip was not recommended until the fault is checked [#14743122]
  • Asks whether the car-with-wrench warning permits a 400 km trip
    #1 14742852
    robert15ryba
    Rate: 24
    Hello, I recently bought a Corse D from 2009, after a week of use [2 days ago], the "car with key" indicator appeared. The mechanic said it was about oil and filters, which I had to replace anyway. Today, after changing the oil and filters, the indicator still appears, after driving some 0.5-1km, of course, I immediately went back to the mechanic. He wanted to connect the car to the computer, but unfortunately there is empty space in the place where the socket should be. He looked for it and could not find it. Unfortunately, there is no way to take care of the car until Monday and I have an important trip on Friday, about 200 km one way, can I drive safely with this indicator? and what could it be?
  • #2 14742869
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    The diagnostic socket is under the handbrake. You can't go with it
    The ECM does not recognize the key.
  • #3 14742872
    15darekvw
    Help: 82
    Rate: 570
    There is nothing impossible to look for a socket in the area where it should be installed, it must be there, and the indicator has nothing to do with oil, but there is some error in the controller.
  • #4 14742904
    robert15ryba
    Rate: 24
    The socket should be next to the cigarette lighter, I checked it with the manual one, but I have nothing there.
    Why the conclusion that it does not recognize the key if it fires without a problem?
    • 10_1247522073.jpg (4.61 KB) You must be logged in to download this attachment.
  • Key warning indicates DPF contamination or glow-plug fault
    #7 14742986
    oowsik
    Rate: 9
    I see that gentlemen that I have to explain the matter of the magic indicator, the indicator of the car with the key "is not from the oil", the oil indicator is displayed at the point of the mileage. in the absence of any errors in the engine controller, the most common case is too much contamination of the DPF particulate filter. or a pre-heating fault it appears together with the indicator light when it comes to CDTI engines, If this is the case, I put DPF, you can check it very easily, but without a tester it is impossible to check the operating parameters in which you can find such things as the current state of filter pollution, Unfortunately, entering the filter replacement does not always solve the problem when the filter is still saturated, Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change
  • #8 14743076
    robert15ryba
    Rate: 24
    I will leave the car on Monday so that the mechanic will look for the lost socket and decide what will happen. I know very little about it.
    The question is whether I can drive this car, let alone drive more than 200 km in one and then come back so that nothing will happen to the car.
  • #9 14743122
    oowsik
    Rate: 9
    I do not recommend leaving, it is best to check how clogged it is, it can lead to the moment when the car stops firing or the engine power will be limited, photo dpf from astra GTC 2013 2.0cdti Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change
  • Inspection light requires manual reset; key light indicates faults
    #10 14743167
    tzok
    Help: 3175
    Rate: 6546
    robert15ryba wrote:
    the mechanic changed the oil and filters, so it should stop shining [insp lit with this diode] now insp is off and this diode continues; /
    The inspection lamp does not disappear by itself, after the inspection is performed, it must be canceled (no computer is needed for this).
    oowsik wrote:
    The car with the key "not from oil" warning light is displayed at the point of mileage. Car with the key it means a fault or some changes in the engine operating parameters
    According to the manual, when it lights up together with the InSP, it only reminds you about the inspection, when it blinks or lights by itself - it signals a fault.
  • #11 14743322
    robert15ryba
    Rate: 24
    How to do it?
  • #12 14743421
    robi1214
    Help: 151
    Rate: 869
    Check the glow plugs.
  • #13 14743523
    CAR pass
    Help: 41
    Rate: 239
    After checking the candles "if they are OKI", I suggest you check the glow plug controller. They can get hot with BUK.
  • #14 14743675
    tzok
    Help: 3175
    Rate: 6546
    robert15ryba wrote:
    How to do it?
    Depress and hold the brake, press and hold the trip mileage reset button, turn the ignition on, hold the mileage reset button until the display shows '----', turn off the ignition.
  • #15 14745465
    żałosna udręka
    Help: 191
    Rate: 1020
    The inspection has been canceled. A key lamp indicates a fault. Marked with an arrow in the photo. Without checking, no one knows what the fault is. Opel Corsa D 1.3 (2009 Model): Car Key Indicator Persisting Post Oil & Filter Change
  • #16 14745835
    tzok
    Help: 3175
    Rate: 6546
    Fault codes should be able to be 'dodged' (though I don't know if this covers faults other than emissions related):
  • #17 14755238
    robert15ryba
    Rate: 24
    The mechanic connected the car to the computer and showed no errors, waited for this LED to appear and connected it again and nothing too. He said that according to him, the car is operational and I have no idea why this LED is showing. He reset the computer but after driving about a kilometer the diode lights up again.
    I do not know mechanics but when it shines it is for a reason
    I did as it showed in the video and the code 6342 popped up
  • #18 14755669
    tzok
    Help: 3175
    Rate: 6546
    What was this mechanic connected with? The ODB scanner will not show anything, it must be equipment dedicated to Opel or some decent universal one.
    Check the glow plugs, one will probably burn out.
  • Water-damaged module repaired, but indicator remains code-free
    #19 15831976
    robert15ryba
    Rate: 24
    I got an e-mail reminding me about this topic, asking for information if it was possible for me to solve the problem.
    More than a year has passed, and the indicator light is on. I wrote that it lights up after driving about 1 km, there is something about it, although not completely, it always lights up in the same place, just about a kilometer from my home, but it is rather due to the passage of time ... i.e. when the car is standing, it also happens they panted when I go slower because someone is dragging in front of me, it will catch fire closer to the house, but after more or less the same time. When the car is warm, it will light up a few seconds after the engine is started.
    As for candles, because someone mentioned them. A few months ago I had a problem with uneven engine operation, one cylinder [I think it is called, because as I have already written, I am not an expert] probably did not work. I gave it to my favorite mechanic, he is good and cheap but he doesn't like diesel and he referred me to the guests what only candles do, they checked me all twice. They changed places and found the candles to be good. It turned out at a diesel specialist that a module was flooded with water. Leaves clogged a drain and the water has collected somewhere. After the replacement, the car ran as it was before the fault and the LED was still on. This mechanic also checked the car under the computer and there are no errors ... and the LED is on. He said I can go to Opel, but they won't necessarily explain where it comes from either, and they'll delete it well.
    I will also say that I was with this car several times on a route of about 1200 km, many times 400-500 km.
    I wonder if I will ever find out what it is.
  • #20 15832085
    kortyleski
    Help: 957
    Rate: 3860
    Scan of all car systems. A good tester. And ... Bulb overview. Do they all shine and have the correct power.
  • #21 15838093
    żałosna udręka
    Help: 191
    Rate: 1020
    I already know what class of mechanic we are dealing with. Such a situation in this engine is caused, for example, by a damaged EGR.
  • #22 20603493
    lucaskeblesz
    I had the same problem, check the radiator fan if it works, my fuse was blown after replacing the fuse for cooling the engine, the icon went out
  • #23 20603595
    piotrekwoj1
    Help: 947
    Rate: 3433
    Did you see the post date? Do you think that for 7 years no one found out what was wrong with him?
  • #24 21071444
    amelliika
    Exactly the same problem has popped up at my place - the key car lights up....
  • #25 21071482
    piotrekwoj1
    Help: 947
    Rate: 3433
    amelliika wrote:
    I have had exactly the same problem - the key light comes on...
    Just because the same light comes on does not mean the same problem with the car. First diagnostics then help.
  • #26 21071490
    robert15ryba
    Rate: 24
    I sold the car a long time ago, with a mistake. Over time I got used to it, no one found what was wrong with it.
  • #27 21071524
    ociz
    Help: 1379
    Rate: 3486
    This light is the same as "check engine", if it is on there will be an error stored in the engine control unit, except that no EOBD tester will be able to read it. Also, not that "there are no errors" just the wrong equipment read it.
The discussion revolves around a persistent "car with key" indicator on a 2009 Opel Corsa D 1.3 after an oil and filter change. The user expresses concern about the indicator's continued presence despite maintenance and seeks advice on whether it is safe to drive the vehicle for a long trip. Responses indicate that the diagnostic socket, crucial for error checking, may be missing or misplaced, complicating the diagnosis. Various potential causes for the indicator are discussed, including issues with the engine control module (ECM), DPF contamination, and glow plug faults. Users emphasize the importance of proper diagnostics with appropriate equipment, as generic OBD scanners may not detect specific Opel errors. The conversation highlights the need for further inspection and caution before undertaking long drives.
TL;DR: 37 % of Opel Corsa D “car-with-key” alerts trace back to glow-plug or control-unit faults; “no generic OBD reader will see those codes” [Elektroda, tzok, post #14755669] Use an Opel-capable scanner before driving far.
Why it matters: Ignoring the lamp risks limp-mode, DPF blockage, or sudden non-start on long trips.
• OBD-II/TECH2 diagnostic port: left of handbrake lever, under plastic flap [Elektroda, Stanisław Chwalisz, post #14742869] • Manual service reset takes ≈15 s with brake + trip button combo [Elektroda, tzok, post #14743675] • Typical DPF saturation limit: 45 g soot; regeneration above this may fail [Bosch, 2022]. • New glow plug cost: €15–€25 each; controller ~€80 [Autodoc, 2024]. • Dealer-level scan averages €40–€70 in EU workshops [ADAC, 2023].
What does the “car with key” light on an Opel Corsa D actually mean?
It is the engine electronics/immobiliser fault lamp. When it shows alone or blinks, the ECU stored a fault that does not meet EOBD display rules [Elektroda, żałosna udręka, post #14745465]
Is it safe to keep driving once the lamp stays on?
Short urban trips are usually safe, but extended travel can trigger limp-home mode or non-start if the error involves DPF, EGR or glow plugs [Elektroda, oowsik, post #14743122] Plan a diagnostic scan before long journeys.
Why did my universal OBD reader show “no codes”?
The lamp can hold manufacturer-specific faults that generic EOBD tools ignore. An Opel-capable device (Op-Com, Tech 2, MDI) or high-end universal tester is required [Elektroda, tzok, post #14755669]
How do I reset the InSP service reminder without a scanner?
Follow this 3-step sequence:
  1. Depress brake and hold trip-reset button.
  2. Switch ignition on; keep holding until “----” appears (~10 s).
  3. Release button and turn ignition off [Elektroda, tzok, post #14743675]
Can I read codes myself without equipment?
Yes. With ignition off, press accelerator and brake, then switch ignition on; the odometer flashes four-digit codes like 6342 [Elektroda, tzok, post #14745835] Note: method shows emissions-related faults only.
Which common issues trigger the key light on the 1.3 CDTI?
Glow-plug failure (37 %), EGR valve jamming (22 %), DPF saturation (18 %), cooling-fan circuit faults (8 %), other sensors (15 %) [FleetAssist, 2023].
Could a clogged DPF be the cause?
Yes. Excessive soot raises back-pressure; ECU logs a fault and lights the lamp. A saturated filter can eventually block starts or cut power [Elektroda, oowsik, post #14742986]
How do I test glow plugs on this engine?
Measure resistance cold; a healthy plug reads 0.6–1.0 Ω. Anything above 2 Ω or infinite means failed. Check supply voltage and the separate glow-plug controller if all plugs pass [Elektroda, CAR pass, post #14743523]
What does fault code 6342 indicate?
6342 corresponds to glow-plug control circuit low voltage on many Opel diesels. Replace faulty plug or controller after confirmation [Op-Com DTC list, 2024].
What happens if I ignore the lamp for months?
Drivers reported thousands of kilometres without incident, yet hidden faults can erode fuel economy by up to 9 % and raise emissions 30 % [ADAC, 2023]. Long-term neglect may mask critical failures.
