RFID UNIQUE Card Duplication: How to Copy Data to Blank Card & Necessary Devices
rejas 42246 16
How can I copy data from an RFID card to a blank card, and what device do I need?
To copy an RFID card you need to know its type first: ordinary UNIQUE 125 kHz cards have a fixed serial number assigned at production, so the original card number itself cannot be changed [#5620542][#12148950] However, the thread says you can still clone the number by reading it and writing it to a compatible writable "blank" UNIQUE card, or by emulating the card with electronics [#12149061][#12310036] One reply names an EMC-4 (Q5) card, a PRTxxEM Roger reader, and the free RARC software as the needed tools [#10177114] Another says copying a standard UNIQUE EM4100 card is possible and common with a portable palm-sized reader/programmer powered by 2×AAA, and it can be done in under 10 seconds [#10173248] So the required device is a reader-programmer matched to the specific card family, plus the right software; not all RFID cards are writable or interchangeable [#5620542]
  • #1 5619847
    rejas
    Rate: 9
    Hello, I have a question, how to copy data from RFID card to blank card? What device is it made of? Can you do that at all? Regards
  • #2 5620542
    bulba1
    Help: 77
    Rate: 60
    Depends on the type of card. The most popular UNIQE 125 kHz RFIDs are not saved and their unique identifier is given during production.
    For other types, you need a reader-programmer suitable for the type and, of course, the appropriate software. The card systems are not compatible with each other, especially when it comes to writing (and not all of them are writable).
    That's why you need to know what these cards are.
  • #3 5649621
    biela007
    You will not copy the card yourself. I once read that someone succeeded, but it probably requires a lot of knowledge and equipment. The basic feature of these cards is the unique number. Each card sends a 64-bit data frame (synchronization preamble, frame start marker, card data, i.e. its unique number written on five bytes, CRC8 checksum, positive or negative acknowledgment and frame end marker.
  • #4 10173248
    easypl12
    Rate: 32
    I refresh the topic, because RFID copying in std UNIQUE EM4100 is already possible and I would even say that it is common.
    He has such a device in the form of a portable reader that fits in the palm of your hand, powered by 2xAAA, the time of copying the RFID card is less than 10 seconds.
  • #5 10177114
    b3ck
    Level 19  
    Help: 29
    Rate: 32
    Copying is very easy. I present instructions on how to do it, and we will need:
    EMC-4 card (Q5)
    Free download of RARC from roger.pl
    • Duplikowanie transponderów Unique.pdf (1.25 MB) You must be logged in to download this attachment.
  • #6 11917991
  • #7 11918054
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    I just think, is it good that this information saw the light of day, although it is not a secret, but on the other hand it may be good, because at least installers and users of these cards will be aware that copying unique cards is a trivial matter - and thus dangerous. As for the question about the reader, "xx" stands for any model from the EM series.
    Greetings b3ck ;)
  • #8 11959478
    tomekkresek
    Rate: 15
    Here my colleagues showed a solution with unique almost contact cloning, and "experts" are able to clone from a distance of 3 m
    Unique readers are great for restricting access to ... a toilet
  • #9 12031971
    wurba
    Rate: 21
    I am not a "specialist", so I have a question. There are transponders on the ink and solvent bottles for industrial printers. How can you identify what type of transponder it is and possibly how it could be used? Maybe they will be suitable for opening the gate after installing the appropriate reader?
    RFID UNIQUE Card Duplication: How to Copy Data to Blank Card & Necessary Devices RFID UNIQUE Card Duplication: How to Copy Data to Blank Card & Necessary Devices
  • #10 12033965
    rubesom
    EMC-4 card (Q5)
    Download RARC for free from roger.pl
    But what will it do if we only read the card number and its expiry date in this way? What about the one-time CVC key? Is he also read?
    I am asking because if it is really possible to read this key, then I go for the scissors and cut the antenna in the card :!:
  • #11 12044450
    dariusz.bembenek
    Help: 455
    Rate: 615
    I might be wrong, but in the case of UNIQUE 125 kHz cards (the ones with access "to the toilet") something like a CVC key probably does not exist. Payment cards with tech. PayPass is a slightly higher driving school. The CVC is already there for sure.
  • #12 12125813
    djdamsza
    The Unique standard card has a serial number stored in it. It cannot be copied and recorded to another card.
    There are personalization readers that encode cards so that they can be assigned to specific employees in the company.
    http://skalmex.com.pl/skalmex2/pl/nasze-produkty/czytniki/czytnik-personalizacyjny
    It is true that the Unique standard is obsolete and is unlikely to be used in access control systems. However, they are successfully used in time recording systems. The employee has 1 card assigned to his account and is not able to have two.
    This is enough for the needs of the RCP.
  • #13 12148681
    b3ck
    Level 19  
    Help: 29
    Rate: 32
    Read my post a little higher and you will notice that it is possible.
  • #14 12148950
    djdamsza
    Unique standard cards have a permanently saved serial number. It can be read, but it is not possible to change the card number. Unique is not a writable card. I know that there are many professionals on this forum and I will probably throw a glove on many people, but I stick to mine. Nothing can be written to the Unique card.
    However, you can make a layout imitating a card from the read number. However, this is not the second card.
  • #15 12149061
    dariusz.bembenek
    Help: 455
    Rate: 615
    Friend above. Perhaps you understand the same thing just a little differently.
    Sure, it is not generally possible to modify an already existing card number in the card. Here, no one says to put such a card on the reader and molest it to such an extent that she wants to change the number ...
    We are talking about cards (an example card symbol is given above), which do not have an assigned number (this part of the memory is "free") and it is possible to "upload" any number that was previously read from a "normal" unique card.
  • #16 12310036
  • #17 12351528
    easypl12
    Rate: 32
    The price of the mifare card is not much higher (max 15%) than the price of the unique 125khz card.
    The reason for the popularity of unique systems is the multitude of solutions to support them and the simplicity of installation and configuration.
    Mifare cards should be encoded before use, if done wrong then mifare based solution will be easier to crack / work around than unique as mifare writers are much more common.
The discussion revolves around the duplication of RFID UNIQUE cards, specifically the 125 kHz EM4100 type. Users highlight that copying data from these cards is complex due to their unique identifiers, which are typically not writable. A portable reader, such as the PRTxxEM Roger reader, can facilitate copying, but it requires specific software and knowledge. While some users claim that copying is possible, others emphasize that the UNIQUE standard cards have a permanently saved serial number that cannot be altered. The conversation also touches on the security implications of card duplication and the comparative advantages of UNIQUE cards over Mifare systems in terms of cost and ease of use.
