Cloning a Mifare 13.56 MHz Proximity Card for Apartment Access with Family of 4
kamilalek1 34888 14
Can I clone a Mifare 13.56 MHz proximity card at home to get extra apartment access cards?
Not with a normal blank Mifare 13.56 MHz card; standard cards have a unique read-only serial number and encrypted communication, so a regular card cannot simply be cloned [#10011144][#10010957] Blank cards can usually only be added to the access system by enrolling their own number, not by copying another card’s identity [#10010957] Some people mention card emulators or research-only cloning projects, but they are not a practical solution for an ordinary user and may require hardware that behaves like the original card [#10011144][#10012887] The thread’s practical advice is to go the legal route: ask the administrator/property manager for additional cards or a change of the access system [#10011044][#10011318]
  • #1 10010827
    kamilalek1
    Rate: 41
    I live in a block of flats with a family of 4, to enter the apartment I have to put a proximity card to the door, the problem is that I got two cards and I need four, I went to the administration to make me two cards, and they said they can't do it because Up to 2 cards can be assigned to each apartment.
    Is there no "home" way to clone a proximity card, I saw an auction on Allegro where they sell blank cards - the standard of the card is mifare 13.56 mHz ??
  • #2 10010872
    telbod
    Level 32  
    Help: 163
    Rate: 240
    Probably not to clone. Unless some ancient system. Blank cards can be read into the system. And since when does the administrator decide how many people can live in an apartment?? Maybe it's some cheap system with a small capacity, e.g. 100 cards.
  • #3 10010925
    kamilalek1
    Rate: 41
    Standard is from 5 years ago.
    If I clone the card, it will have the same data as the first one, so the capacity of the system has nothing to do with it, if I'm wrong, write.
  • #4 10010938
    telbod
    Level 32  
    Help: 163
    Rate: 240
    Access control systems were created in order not to copy keys. It can be done with mechanical. Electronic keys are there to control the keys.
  • #5 10010957
    goldi74
    Help: 1367
    Rate: 1539
    Cards cannot be cloned. Each card, even a blank card, has its own number and it is loaded into the system.
  • #6 10010962
    kamilalek1
    Rate: 41
    Recently, in the news, they said that it is possible to clone a contactless - credit card, all you have to do is hug someone like that on the bus and you have their card details, so there should be no problem with the housing card if you can clone a credit card.
    Here's the video http://www.youtube.com/watch?v=ZKpEY4lRz9A&feature=player_embedded
  • #7 10011044
    piotrva
    Help: 625
    Rate: 735
    THESE CARDS CAN BE CLONED. At one time, there was even a project of a cloner card on the forum, which could pretend to be a previously read card. I am personally trying to do a similar topic (rfid unique 125khz) for research purposes, but just like the author of the mentioned project, I will not share the details, in particular the possible programs, because you never know who might find it useful.
    As for your problem, the solution is the law: the administration has no right to limit the number of keys in this case in electronic form. Go to them again and if they refuse, write a written request and then possibly a complaint with a request to change the system to another one, allowing you to use as many "keys" as you wish ;-)
  • #8 10011065
    kamilalek1
    Rate: 41
    I sent them a written request but they did not accept it, tomorrow when I find it you will send a scan.
    I saw several proximity card readers on the Internet, but the prices of PLN 800 are too high, I also read on the card security website that such a reader can be purchased for $ 50, but I can't find it anywhere.
  • #9 10011122
    gruby1
    Help: 126
    Rate: 171
    Or maybe make a card emulator? It is true that it is so inconvenient that it requires power, but it can be survived. I saw on a foreign website a project that probably consisted only of a microcontroller, a coil and a few passive elements. It would be possible to stuff it with the battery into some housing from the car remote control. Probably a simpler solution than cloning the card.
  • #10 10011144
    GSM
    Help: 72
    Rate: 16
    impersonation of the Unique system card (125 kHz) is no secret, the system itself is old and nobody (normal) uses it in serious security.
    With Mifare system cards (13.56 MHz) it is different, the transmission itself is encrypted and the card, apart from a unique serial number, contains memory banks in which any data can be stored.
    A card cannot be cloned to a regular other card, because the new "blank" cards already have a different one unique read-only serial number.
    You would need a card with the ability to assign it yourself a serial number.
    Another problem with impersonating Mifare system cards is the fact that the transmission is encrypted.
    There have already been successful attempts to break this security, but this is far from the reach of an ordinary bread eater who wants to make a second electronic key.
    So for your problem, you can assume that cards cannot be cloned.
    The only option in this case is to pester the administration for issuing additional cards and assigning them to your premises.
    Regards,
    GSM
  • #11 10011277
    wzk
    Level 19  
    Help: 22
    Rate: 25
    A legal problem and it must be resolved legally. You just have to be consistent. It is worth turning to lawyers, because such behavior of an official assuming electronic cutting even smacks of violating the Constitution.
  • #12 10011318
    dondu
    Help: 1292
    Rate: 809
    And that's the right way. Start with a letter to the property manager (letter by registered letter or delivered in person with return receipt on copy). Don't do anything "by the mouth". :)
  • #13 10012887
    piotrva
    Help: 625
    Rate: 735
    Emulator or card cloner -> it comes out the same and by the way, this solution with a coil and attiny85 does not work very well because I tested ;-)
    Well, it's actually not that simple with mifire cards ;-) Therefore, as I say - go to a lawyer with this, because such conduct of the cooperative is against the law.
  • #14 10173293
    easypl12
    Rate: 32
    I have an RFID programmer in the UNIQUE 125kHz standard.
    The programmer itself is the size of a pack of cigarettes, powered by 2xAAA, transponder reading 1sec, writing about 3sec.
    I tried copying cards and key chains, works great :)
    Writable cards are rewritable.
    BTW: maybe someone knows how the new code is maintained in the transponder? Is it some kind of flash memory?
  • Workplace proximity card copied to car transponder for PLN 10
    #15 10740393
    stempik
    Rate: 24
    kamilalek1 wrote:
    and they said that they can't do it because a maximum of 2 cards can be assigned to the apartment.
    Most often, if you pay for 2 people, you get 2 cards. So the legal route is rather out.
    But for some time now I have a toilet for a UNIQUE proximity card at work. Deposit PLN 50. Without any problems, the card could be copied to the transponder from the car for PLN 10. so I have 40 left for a drink.
    Moderated By fortronik:
    3.1.19. (13) It is forbidden to post entries in archived discussions.
The discussion revolves around the challenge of cloning a Mifare 13.56 MHz proximity card for apartment access, as the user has only two cards for a family of four. Responses indicate that cloning such cards is complex due to encryption and unique serial numbers embedded in each card, making it difficult to replicate them without specialized equipment. Some participants suggest alternatives like card emulators or legal action against the administration for limiting card issuance. The conversation highlights the limitations of the current access control system and the potential for legal recourse to obtain additional cards.
