Soot & Grease Removal Options for Glazed Surfaces, Joints, Emulsion Painted Walls - Manual Cleaning
juzef22 106854 11
How can I remove soot and grease manually from glazed surfaces, grout, and emulsion-painted walls?
The most effective option reported was Emi7 concentrate, which washed soot from glass panes, white plastic windows, glazed tiles, varnished surfaces, and even helped with grout, without smearing [#6179265] First, remove loose soot mechanically with a dense dry brush so it smears less during washing [#5749060] For washable surfaces, a strong washing-up liquid with more than 30% surfactants or a soapy-detergent paste such as Komfort was recommended [#5746956] Very aggressive cleaners for cooking chambers, based on soda lye and with pH around 12-14, may work but must be rinsed off thoroughly and can damage paneling or other surfaces [#5746956] HG Hagesan Clean Bathroom foam was also reported to clean soot fairly well from slightly porous tiles, though porous materials may never become perfectly clean [#5747225] A bleach based on technical sodium hypochlorite was suggested for whitening, but only with good ventilation and care around sensitive materials [#6181025]
  • #1 5744790
    juzef22
    Rate: 53
    What preparations are available on the market for removing soot and grease from glaze surfaces, joints and walls covered with emulsion paint.
    It is about manual cleaning.
  • #2 5745203
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Do you have a regular CO stove or a fine coal stove and a chimney without an insert?
    My aunt was also struggling with these stains. She installed the insert and applied a new plaster after removing the old one where there were stains and the problem disappeared.
  • #3 5745389
    juzef22
    Rate: 53
    I do not have a coal fired CO furnace.
    Soot on the walls in all rooms is the result of a fire in one of them.
    I want to remove excess dirt initially.
  • #4 5745552
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    I don't know anything about chemistry. Maybe sanding the walls?
  • #5 5745696
    juzef22
    Rate: 53
    I found Karcher funds on the internet
    -RM 750
    -RM 69 ASF
    has anyone used them? what is their effectiveness
  • #6 5746956
    serwal
    Rate: 54
    The soot is rather hard to remove from the joints
    But for starters, try some expensive and good washing-up liquid (Luwik, Ajax, etc.) with a surfactant content of more than 30% on washable surfaces, and soapy-detergent health and safety paste or Komfort washing paste works well. Except that you put it on by hand with a little water and wash it off with water. Proven when cleaning small washable surfaces from soot.
    If you want a pressure foam sprayer, look for something to clean the cooking chambers, but these agents are very aggressive (pH around 12-14) based on soda lye and must be thoroughly washed off the surface. There is a risk that they can damage paneling or other surfaces.
    Good luck because you have a lot of work
  • #7 5747225
    kalasz20
    Help: 42
    Rate: 66
    I can also suggest the HG Hagesan Clean Bathroom product - foam, spray bottle, I had smoke in the newly renovated bathroom myself, unfortunately porous materials can not be restored to a perfect clean state, my joints are darker. But it was fairly good at cleaning the soot from slightly porous tiles.
    Greetings
  • #8 5749060
    juzef22
    Rate: 53
    Thanks to everyone for the answers.
    I will do this:
    Initially, I will remove the excess soot mechanically with a dense brush, then I will use some cleaning agent and I will try to clean the joints with a steam generator.
    I will write what the effects of these actions will be.
  • #9 5757929
    juzef22
    Rate: 53
    As planned, I started to remove excess soot from the wall and ceiling with a dry brush. The original deep black turned to gray is a good sign, less smearing when washing.
    cdn
  • #10 6179265
    juzef22
    Rate: 53
    I have tried over a dozen preparations available in retail trade. On each of them, the manufacturer described its miraculous properties that grew along with the increase in the price of the product. It is a pity that the described miraculous action does not translate into a real fight against dirt.
    No matter if the preparation costs a dozen or so zlotys or several dozen in my test, the effect was always the same dirt smeared and was not washed away, in a word, the cash was thrown away.
    And now a hint of optimism.
    I found a product that I am happy with, not in some big retail chain, but in a small paint and building materials store. It is "Emi7 concentrate" in a 1-liter package at a price of about PLN 14 and, surprisingly, it washes off the soot, I repeat it, but not smudging.
    With the help of the Emi7, I washed the soot and other dirt from the surface of the glass panes and white plastic windows from the fire. I have cleaned the glaze without any problems, the joints are not completely white yet, but I will go to them again, this time with warm water. The tiles on the floor are washed clean joints. Varnished surfaces washed clean. The only drawback is too much foam, but that's a detail.
    And this is what Emi7 looks like
    https://obrazki.elektroda.pl/95_1235148759.jpg
  • #11 6181025
    Chris_W
    Help: 386
    Rate: 1051
    In some cases, hypochlorite based bleaches can be used. You then have to ventilate thoroughly and be careful with some materials (metals, fabrics, dyes) so as not to destroy - but the effect is that it makes 'whiteness' which can play a major role in the advertising of washing powder.
    Additionally, it disinfects and disinfects the surface.
    Oh, I don't mean ACE, lenor, vanish, etc., but technical sodium hypochlorite - for dilution in water.
  • #12 16419397
    Magnus99
    Rate: 20
    I checked the recommended EMI 7 liquid, concentrate when trying to clean soot from ceramic tiles. I scrubbed a heavily wet tile with a brush, unfortunately this preparation is a total linden and despite all efforts, there was no trace of EMI 7's effect on the roof. TENZI Gran smog preparation is used, however, when applying the preparation, one must take far-reaching precautions, during contact with the skin it feels like the preparation burns.
    It is worth emphasizing that Tenzi is cheaper than the EMI 7.
The discussion revolves around effective methods for manually cleaning soot and grease from glazed surfaces, joints, and emulsion-painted walls following a fire incident. Initial suggestions include mechanical removal of soot using a dense brush, followed by the application of various cleaning agents. Recommended products include Karcher RM 750 and RM 69 ASF, as well as HG Hagesan Clean Bathroom for slightly porous tiles. Users also mention the effectiveness of washing-up liquids with high surfactant content and the Emi7 concentrate, which reportedly cleans soot without smudging. Caution is advised when using aggressive cleaners, particularly those based on sodium hypochlorite, due to potential damage to materials. Overall, the effectiveness of cleaning products varies, with some users expressing dissatisfaction with commercial options.
