Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice
Vwuac 33420 31
What is the best way to clean the metal cooking plate on a tiled stove?
Clean the plate with a hand brass wire brush or a spatula, depending on how much carbon buildup there is. For light dirt, the brush is better and less messy; for heavy soot, scrape first with a spatula, then brush [#18536819] [#18536823] [#18536830] If the plate can be removed, take it outside and use a grinder with a soft wire brush and WD-40, then finish with fine abrasive paper for a smoother surface [#18600417] One reply also suggests caustic soda after the rough cleaning step [#18536860]
  • #1 18536778
    Vwuac
    Rate: 13
    Hello, I could not find anywhere exactly what I am looking for, so I am writing a new post. I have a tiled stove on which I cook, and as in the topic - how to clean this plate? Or rather, with what. I have read and watched various videos where tile grout, etc. were cleaned, but I care about cleaning this plate. Thank you in advance for any advice.
  • #2 18536811
    stanislaw1954
    Help: 2003
    Rate: 4624
    Vwuac wrote:
    I have a tiled stove on which to cook,
    In some parts of the country, a tiled stove is a stove in a room for its heating and it is impossible to cook anything on it, because it is sometimes high, for example, about 2m. For cooking is a tiled stove with a pytha in the form of one or more metal sheets placed over the hearth. And I think that's the point in this case.
    What to clean? Probably the simplest is a wire brush( can be on a drill, or grinder), it can be paper/abrasive cloth(by hand, or mechanically).
  • #3 18536819
    vodiczka
    Help: 1185
    Rate: 4301
    Traditional cast iron plate? Brass wire brush.
    Added after 2 [minutes]: .
    stanislaw1954 wrote:
    Wire brush( can be on a drill, or grinder),
    And the whole kitchen dirty. A traditional hand-held wire brush costs about PLN38. There can also be a wire scourer known as a wire brush.
  • #4 18536823
    kortyleski
    Help: 957
    Rate: 3847
    Better and cleaner to scrape with a spatula
  • #5 18536830
    vodiczka
    Help: 1185
    Rate: 4301
    kortyleski wrote:
    It is better and cleaner to scrape with a spatula
    This is already with very heavy soiling (thick carbon build-up). With a light one, the spatula will slip more than pick up dirt and grease.
  • #6 18536852
    stanislaw1954
    Help: 2003
    Rate: 4624
    And who says you have to do it indoors? You can take it outside and it's a hassle.
    kortyleski wrote:
    It's better and cleaner to scrape with a spatula
    I don't really understand what on this countertop could be cleaning with a spatula. Is there so much on the gas cooker in the average (normal) house that you have to scrape with a spatula. Many years ago, I had a charcoal stove with a cast iron, then steel, stove top and, apart from the occasional spillage because a pot was not moved to the edge of the stove in time, there was no extraordinary need for a wire brush. Simply washing it off with water using a rag and that was it.
  • #7 18536860
    palmus
    Help: 232
    Rate: 745
    Roughly with a spatula or wire brush. Then caustic soda.
  • #8 18536877
    vodiczka
    Help: 1185
    Rate: 4301
    I don't really understand what could be on this countertop, to clean with a spatula
    In that case, I'll ask what could be on this countertop since you recommend
    The easiest way is probably a wire brush( could be on a drill, or a sander), it could be paper/sanding cloth(by hand, or mechanically).
    When it gets busy there is something to scrape. I don't have anything to brag about, but I cleaned the overlay (grate) of the gas stove with a knife several times.
  • #9 18537117
    stanislaw1954
    Help: 2003
    Rate: 4624
    vodiczka wrote:
    In that case, I will ask what could be on this countertop since you recommend
    What do I recommend, cleaning with a spatula ?, I think someone else.
    Surely. The grate, I can understand, but not the whole hob, unless you wash the cooker once around Easter.
  • #10 18537135
    vodiczka
    Help: 1185
    Rate: 4301
    What do I recommend, clean with a spatula ?, probably someone else.
    Not nice mate, I quoted you what you recommend and you truncated my post and pretend to be Greek ;) .
  • #11 18537155
    stanislaw1954
    Help: 2003
    Rate: 4624
    I don't know what could be on this countertop, you have to ask the founder of the topic. Now LEFT ?
  • #12 18542860
    phanick
    Help: 65
    Rate: 2833
    Have it sanded and then sanded to a glossy shine then the dirt won't stick so much.
  • #13 18543939
    buczkog
    Help: 22
    Rate: 33
    Maybe you are referring to a coal cooker and not a tiled cooker (the cooker is at least 1.5m high and how to cook on it), as these are two different things.
    To the previous speakers "thank you" for the advice with brass brushes, sandblasting etc. etc. regarding the cleaning of the TILER stove.
    If you are concerned with a so-called coal stove, then scrape the tiles on it with a spatula or something similar, wire brush or sandblasting. You can also light a fire, throw in these cast iron plates and the grease and other gunk will burn off (proven method).
  • #14 18543960
    phanick
    Help: 65
    Rate: 2833
    The preceding "thank you" for the advice with brass brushes, sandblasting, etc. etc. regarding cleaning the TILER STOVE.
    It's not about cleaning the tiled stove, it's about cleaning the plate of this stove itself, that is, the metal sheet.
  • #15 18543986
    buczkog
    Help: 22
    Rate: 33
    phanick wrote:
    Thanks to the previous "thank you" for the advice with brass brushes, sandblasting, etc. etc. regarding cleaning the TILER STOVE.
    It's not about cleaning the tiled stove, it's about cleaning the tiled stove plate itself, that is, the metal sheet.
    Boy!!! Have you seen a tiled stove? (I've been dealing with them myself for over 30 years), and have you seen a coal stove???. Where have you seen cast iron plates in a tiled stove?! I guess the door which is made of cast iron and the grate of the stove and the rest of the housing is chamotte brick and ceramic tiles. On the stove or tiled stove you do not cook / bake, but it is only used for heating. The so-called coal stove is used for cooking and baking.
    P.S.
    Let the best author of the topic clarify whether he means kitchen or stove.
  • #16 18544006
    phanick
    Help: 65
    Rate: 2833
    Yes I saw it, here's an example, and stop whining already.
    Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice .
  • #17 18544315
    vodiczka
    Help: 1185
    Rate: 4301
    buczkog wrote:
    The preceding "thank you" for the advice with brass brushes, sandblasting, etc. etc. regarding cleaning the Kaffle Stove.
    Dyletant complete ;) Can you read the topic title with understanding? "Cleaning the slab on a tiled stove" The slab and not the tiles and grout. On a tiled kitchen and not on a tiled stove.
    buczkog wrote:
    Let the best the author of the topic specify whether he means the kitchen or the stove.
    I guess it's just for you. Other forumers understood without clarification, although the author is not consistent because in the title he writes about the kitchen and the text about the stove but about the stove on which you cook
    Vwuac wrote:
    I have a tiled stove on which you cook
    so the description is unambiguous.
    A tiled stove is a special case of a stove that heats the kitchen area and on which food can be cooked.
  • #18 18544655
    Aleksander_01
    Help: 1156
    Rate: 3386
    I grew up in a house where there was such a kitchen (since there is gas the kitchen has disappeared). The only garbage there was then was glass and metals, the rest went up in smoke.
    Someone earlier wrote to give it to sandblasting, maybe the pipes themselves are yes, but after all, this plate is well anchored to the stove and you will not take it out just like that. I know what I write because I witnessed at my place how they dismantled this contraption. I do not know what is going on here, but as I remember this plate was always clean. After all, even when a drop of something dripped, it was immediately a hiss and gray smoke and smell all over the kitchen.
    But there were times, oh my.
  • #19 18544680
    vodiczka
    Help: 1185
    Rate: 4301
    Aleksander_01 wrote:
    I don't know what's going on here, but as I remember this hob was always clean.
    Respect to the housekeeper, but as I remember the kitchen stove at my grandparents' house it was always before Christmas to clean the hob and there was always something scraped out, even though my grandmother took care of the cleanliness on a regular basis.
    The stove was surrounded by a railing of brass pipes and these were cleaned with Sidol, which in this case meant a suspension of chalk in ammonia water.
  • #20 18544691
    stanislaw1954
    Help: 2003
    Rate: 4624
    Someone earlier wrote to give it to sandblasting, maybe the pipes themselves are yes, but after all, this plate is well anchored in the furnace and you will not take it out just like that. I know what I'm writing because I witnessed them dismantling this contraption at my place
    I don't know if coal stoves were identically built in every region of the country, but I've encountered ones in which the frame was fixed permanently with the tiles, and the plate, whether cast iron (sometimes with a hole closed with the pipes, and sometimes without a hole), but I've also encountered steel ones, were removable.
    I don't know what's going on here, but as I remember this plate was always clean. After all, even if it dripped a drop of something it was immediately hiss and gray smoke and smell all over the kitchen.
    And here I concede the point.
    But curiously the author of the topic is silent.
  • #21 18544693
    vodiczka
    Help: 1185
    Rate: 4301
    but after all, this plate is well anchored to the stove and you won't take it out like that.
    At my grandparents' house there were two plates laid on the frame. One with pipes over the hearth and the other over the oven. They were removed without any problem.
    I see, That a colleague stanislaw1954 also encountered kitchens "like my grandfather's" ;) At my grandparents' house, the slabs were cast iron.
  • #22 18544715
    Aleksander_01
    Help: 1156
    Rate: 3386
    And with what that he could be dirty ? A little soot from the bottom of the pots was with a wet sponge at the daily "vetting" removed. The first ones (the hottest) were always super clean, there the temperature removed everything. There were four positions for the gars. The first two gray (contact with direct fire from underneath), the third blackish gray and the fourth black (the coldest). After all, only the gars stood on this tin, and for a very short time. More than once something sprouted it was removed on the fly. I remember how my mother scraped it with a knife, the rest was taken care of by the temperature.
    I still remember this. When some pipes got stained it was enough to turn them 180 degrees and there is no force on the fire. The same with other posts. It was enough that the 4th (coldest) was too black then the pipes went to the 1st and were already gray. Despite appearances, this kitchen was hardly self-cleaning. If you hoovered well the single would go red, and if you threw butter paper on the hearth there was a furor like in a jet engine.
  • #23 18544770
    stanislaw1954
    Help: 2003
    Rate: 4624
    vodiczka wrote:
    I see that colleague stanislaw1954 also encountered kitchens "like at my grandfather's house" ;) at my grandparents' house the plates were cast iron.
    I met and still happen to see "working" and even installed "horseshoes" in them.
    A horseshoe, for the less initiated, is a metal insert from pipes in the kitchen hearth. The water heated there flows to the boiler, where it heats the domestic water.
  • #24 18544793
    Aleksander_01
    Help: 1156
    Rate: 3386
    Add - there is an expansion vessel installed above the kitchen and the kitchen loses a bit of cug (I suspect the young ones do not know what cug is). At my mother-in-law's house there is still such a kitchen with a horseshoe.
  • #25 18544798
    vodiczka
    Help: 1185
    Rate: 4301
    Ot sclerosis ;) I remembered my grandparents' stove and forgot mine, my parents' to be exact. We had a stove with a horseshoe (in our country called ciegielka), it was not pipes but a welded structure of thick rectangular metal sheets.
    Add - above the kitchen is installed an expansion vessel
    The expansion vessel in our house was an "open" boiler, the overflow pipe led to the sink. The water heated the radiators, there was no heat exchanger to heat the domestic water.
  • #26 18544871
    Aleksander_01
    Help: 1156
    Rate: 3386
    Ot sclerosis. Well the expansion vessel was needed for the radiators. CWU was a large pot on the kitchen. One more thing - until the 80th there was no running water at my place, we had to carry buckets from the well something like 80 meters. It's a good thing my hands didn't grow like a baboon's, because I would have grated on the ground with my claws. The worst was the laundry, an endless story.
    I still remember the voltage reductions in the network. It was hard to watch the TV log because the voltage dropped below 190 volts. Tube TV would stop going.
  • #27 18544906
    vodiczka
    Help: 1185
    Rate: 4301
    But offtopic developed ;) Under me, the source of CWU but only for body washing and bathing, was a vertical copper boiler standing on a cast iron hearth in the bathroom. For washing plates and pots the water was heated as in your case.
  • #28 18544916
    Aleksander_01
    Help: 1156
    Rate: 3386
    It is YOU bourgeois, u tiebia copper boiler. Where did you get a copper boiler, after all, it was a strategic material during the commune (you know how many shells can be produced, and you made yourself a boiler). :D
    It's nice to reminisce.
  • #29 18546154
    vodiczka
    Help: 1185
    Rate: 4301
    How did you get a copper boiler,
    The boiler was still pre-war, it lasted until perhaps 1975, then it was galvanized steel and in 1980 we were connected to the CHP plant.
  • #30 18600417
    KikutStudio
    Today I dealt with this topic personally. I know from experience that if it can be taken off (as in my case), then a grinder with a wire brush (preferably soft) and WD-40. I do not know if this is how it should be done, but it works.
    Most people will be satisfied with the result obtained, but I'm going to go over it tomorrow with glossy paper.
✨ The discussion revolves around methods for cleaning the cooking plate of a tiled stove. Various cleaning techniques are suggested, including the use of a wire brush (brass or abrasive), spatulas for scraping, and caustic soda for heavy soiling. Some participants mention the effectiveness of sandblasting and using WD-40 for maintenance. There is a debate about the distinction between tiled stoves and coal stoves, with some contributors sharing personal experiences and historical context regarding the maintenance of these appliances. The consensus suggests that regular cleaning can be achieved with simple tools, while more thorough cleaning may require specialized methods.
