Mastercook Wrozamet Oven: Deciphering Heat Levels 1-8 to Celsius Degrees
Solo 167319 3
  • #1 5875007
    Solo
    Help: 35
    Rate: 142
    New apartment (rented) and a minor problem of my fiancée :-) We have a Mastercook Wrozamet gas cooker in the apartment, unfortunately there is no marking, model, etc. on it.
    The problem is that the oven temperature control knob does not have markings in degrees Celsius, only heating levels from 1 to 8. I will add that in the middle of the oven you can see the temperature probe / sensor.
    Does anyone know what temperature the heat level corresponds to?
  • #2 5875216
    nairam111111
    Rate: 33
    In the newer model of the Mastercook oven, the temperature scale is smoothly adjustable: 50,10,150,200,250 degrees. The most common maximum temperature is 250 degrees. By dividing it by 8, you will get the temperature at each level, i.e.: 30,60,90,120,150,180,210 and 240 at the 8th level (approximately)
  • #3 11249100
    david-92
    Rate: 70
    Hello, maybe I will dig up the topic. In my opinion it is the Mastercook MK-1306 or 1512 cooker. The first position is the level of the so-called toaster heater as if and the oven reaches 115 degrees C, at levels 5-8 from 170 to 240 degrees C
  • #4 20503627
    arkady850202
    Rate: 45
    I have a model 1510 and also have an 8 degree oven. Does anyone know what the temperatures are in the following degrees?
