Future Mastercook Oven Timer: Setting Time & Exiting Auto Mode - Guide for Lost Manuals
michh 81654 6
  • #1 3827423
    michh
    Rate: 22
    After connecting to the mains, the auto indicator flashes and the time 12:00 is displayed (the dots are blinking). The question is how to set the time and exit the "auto" mode. Please help, I can't find the manual for this kitchen.
  • #2 3836095
    KACZOREK
    Help: 39
    Rate: 198
    I do not know this oven exactly, but programming the clock is solved quite differently. try pressing two buttons at a time or keeping the buttons pressed for several seconds
  • #3 3836156
    pekon
    Help: 17
    Rate: 23
    In most "masters" you have to press the first two buttons at the same time and the last one sets the clock.
    Regards.
  • #4 3849215
    michh
    Rate: 22
    I try but nothing works, once I managed to set the time, now I have no luck. Thanks for the tips.
  • #6 3918058
    michh
    Rate: 22
    I got instructions, but it turned out that it was nothing because the cables were cut into the housing, most likely during assembly at the factory. And there was a small short circuit, burned the cables, luckily it is under warranty. The clock could not be set. Thank you for your response.
  • #7 16372736
    19JU45RASINSKI
    Rate: 8
    To set the clock: after switching on the oven, 0:00 flashes on the display, press the second and third buttons simultaneously, 12:00 will be displayed, then turn the knob to the right SET THE CURRENT TIME! Good luck.
The discussion revolves around setting the time and exiting auto mode on a Mastercook oven timer, specifically when the display shows 12:00 with blinking dots. Users suggest pressing two buttons simultaneously, typically the second and third buttons, to set the clock. One user reported difficulties in setting the time, which was later attributed to a factory assembly issue causing a short circuit. A link to the manufacturer's website for user manuals was also provided as a potential resource for assistance.
