LC40 vs 090 Solder Wire—Lead Content, Health Risks, Melting Points, Symbol Table
szynszyl505 43989 22
How harmful is LC40/090 solder for occasional home electronics work, what do those solder markings mean, and which solder alloy and melting point are best for electronics?
For electronics, the thread recommends LC60 or LC63 rather than LC40/“090”, with LC40 described as more suitable for plumbing or gutter soldering [#6014157][#6014264][#6014383] LC60 is described as a eutectic alloy that melts and solidifies quickly at a constant, relatively low temperature of about 180–190°C, while LC40 has a higher melting point and a pasty range that can make joints dull or defective if parts move during cooling [#6014264][#6015423] For occasional home soldering, the reported health risk is low if you do not inhale the fumes and wash your hands afterwards [#6011464][#6015423] The posts say the main fumes come from rosin/flux, not from lead vapor, and the bigger concern is long daily exposure in production work rather than short hobby use [#6015423][#6015710] Good practice is to keep solder sealed, avoid drafts, use the correct iron temperature and tip size, and if possible place a small extractor 15–30 cm from the joint [#6014035] For composition or symbol information, one reply points to the manufacturer’s chemical composition page rather than a universal table [#6012267]
  • #1 6011271
    szynszyl505
    Rate: 16
    I have a tin that says: LC40 and the other is: 090 and I would like to know something about the harmfulness of tin. I mean these lead admixtures because recently I heard that soldering with some old tin is very harmful to health. How is it actually with this harmfulness when it comes to such domestic use?
    And does anyone have any tables with tin symbols (what do they actually mean) and melting point because the ones mentioned above are very difficult for me to melt 50W with a soldering iron? And what tin can you use "safely"?
    I have read similar topics but I have not found a specific one.
  • #2 6011464
    ks_fenix
    Help: 44
    Rate: 30
    Thus, most tin alloys have lead. As you know, it is a heavy metal, so it is very harmful to health. If you rarely solder and you will not inhale the fumes, as well as wash your hands after soldering, the harmfulness will probably drop to zero.
    As for the tables, there are probably no such tables, each should contain information about the% lead content. There are also lead-free tin, but a soldering iron is needed.
  • #3 6011869
    szynszyl505
    Rate: 16
    And these types of tin what I have are what I mean these are: LC40 and the other is: 090 how much lead do they have? And why is it so hard to melt?
    So I understand that there are no lists with the types of tin and these symbols?
  • #5 6012570
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    As you can see in the question, reading can also be dangerous. Each treatment is the administration of specific poisons to the body and you heal yourself. Where are your concerns when you solder 6 minutes a week. Greater threat from exhaust fumes and electromagnetic field. I know that the information is at fault, but these are the journalistic methods that there must be a sensation. Summing up, the risk applies to people who are constantly in rooms where soldering is carried out. And what about the properties of the solder, start soldering and you will see immediately.
  • #6 6013723
  • #7 6014035
    zaza
    Help: 8
    Rate: 56
    elektrit wrote:
    Listen-solder with this tin and do not bother yourself with nonsense about the harmfulness.
    All.
    This is first
    Secondly:
    If tinol crumbles or breaks when bent one, two or three times, throw it into the bin (store tinol in airtight packages)
    Third, never solder with natural air (draft)
    Try not to inhale the fumes and have even a makeshift extractor located 15 to 30 cm from the soldered point (this depends on the speed of the suction fan)
    Fourth, a good soldering iron and a well-set temperature (appropriate tip thickness and appropriate temperature, taking into account the thickness of the copper on the laminate)
    All this influences the formation of the so-called cold solder and thus the durability, lifetime, conductivity and reliability of electrical connections.
    These are just a few tips for proper soldering.
  • #8 6014157
    bonanza
    Power inverters specialist
    Help: 283
    Rate: 423
    The tin for electronics is LC60, and the LC40 is probably for soldering gutters.
  • #9 6014193
    szynszyl505
    Rate: 16
    Many thanks for this information. I already know that it is nothing particularly dangerous.
    Now I can boldly confirm the opinion of Mczapski that it is only "sensation-seeking".
    I would like to know one thing for how many hours of such "home" soldering, say a day, can be afforded?
    Does anyone know anything else to avoid in electronics and similar fields? Maybe it will be useful in some lectures etc.
  • #10 6014252
  • #11 6014264
    zaza
    Help: 8
    Rate: 56
    You're right.
    For soldering electronic components, a tin-lead LC60 and LC63 alloy is used, with a high degree of purity, the melting points of which are within the range of 180 ... 190 degrees C
  • #12 6014383
    lukib1
    Help: 12
    Rate: 14
    Hello!
    Indeed, this tin is not very suitable for electronics, see its specification here:
    http://www.cynlut.eu/?d=2&p=17
    The best binder for electronics is February LC60,
    and now the industry uses silver solder due to ISO standards, but requires slightly higher melting points.
    In my company (production of components for passenger cars) tin with silver admixed with lead has been used for 2 years and tin with lead has been withdrawn.
    In home use, you can still use it until you run out of stock, because one day it will probably not be on the market.
  • #13 6014742
    ogryz
    Help: 391
    Rate: 134
    Service technicians work all day with a soldering iron in their hand. Somehow I have not heard that any of them, after several dozen years of work, would complain.
  • #14 6015423
    kw48
    Help: 98
    Rate: 99
    No exaggeration with this exhaust soldering at home (coll. Zaza). Nobody uses it, because it makes no sense (and I've never seen a tinol break, which was sometimes left in the open air for several years). The main fumes that are released during soldering come from rosin. Metals at this temperature practically do not evaporate and it is nonsense to talk about "lead fumes" in which electronics are immersed during soldering. In the past, pure lead was widely used. Wiring pipes were wrapped in a lead sheet, as a child I often played with lead (casting lead soldiers, playing "zośka", etc.) and somehow I was fine. If necessary, I also soaked my fingers in gasoline, acetone, iron chloride and other highly harmful substances and also did not notice any negative effects. Their harmfulness manifests itself only in constant contact with them and in poisoning the environment with large amounts of waste containing these substances. The act on the non-use of lead binders was passed out of concern for the natural environment, not because of the high mortality rate among amateur electronics.
    LC60 (60% tin content) is best for brazing because it is a eutectic alloy, i.e. one that changes from liquid to solid very quickly and at a constant temperature, the lowest of any other alloy composition. For example, LC40, 30, etc. binders have a higher melting point than LC60, and when melting and solidifying, they first go through a "pasty" state and then melt or solidify completely. When the soldered elements move in a pasty state, defective, delaminated and dull solder is formed after solidification.
  • #15 6015710
    serwis
    Level 37  
    Help: 334
    Rate: 268
    :arrow: kw48 I consider your statement appropriate and I support it in its entirety, because it explains a lot and "obscures" the myths circulating among novice electronics about the harmfulness of fumes.
    I do not deny that they are harmful to health, but one would have to stay in this environment for a very long time.
    This applies in particular to workers on assembly lines, where they are in contact with vapors for eight or ten hours of work - assuming, of course, theoretically, that the lifts do their job.
    As for service technicians - as much time as the service technician spends soldering, it is certainly less harmful than the polluted air that surrounds us inhaled.
  • #16 6018342
  • #17 6021370
    serwisrtvagd1
    Help: 18
    Rate: 22
    they don't complain because they use fume extractors ...
    well, I do not agree with my friend .... readily available lead-free solder can be bought, for example, here:
    elektrit wrote:
    kw48 wrote:
    LC60 binder (with a tin content of 60%).
    It should be noted that it is difficult to buy solder with a different composition in electronics stores.
    This "other" is used by central heating installers (copper).
    Moderated By rubens:
    The last time I remind you - another link to Renex and there will be a basket and then a warning. My experience is also the same as that of ELEKTRITA. The fact that it is in Renex does not mean that it is automatically in every other place. Read the content of the posts carefully.
  • #18 14482781
    kosmatek
    Help: 8
    Rate: 54
    For about 10 years I have been using tin HOZAN Sn 0% (H-42-3717) is a Japanese tin which soldered very well to me. Unfortunately, I cannot find the tin from this manufacturer and I have already found some tin (also 60%), which is hard to solder with. What else can you recommend, what do you use?
    Moderated By arnoldziq:
    My colleague thinks that the author of the topic waited 6 years for an "enlightened response" from a colleague?
    3.1.19. It is forbidden to publish entries in archival discussions.
  • #19 14482872
    ciasteczkowypotwor
    Help: 590
    Rate: 574
    kosmatek wrote:
    For about 10 years I used tin HOZAN Sn 0% (H-42-3717)
    Tin 0% tin, surely it will be hard to solder.
  • #20 18230890
    elektronik2018
    Rate: 28
    Old topic, but if someone else read it- ONLY TIN CYNEL 1 MM. You can solder 2MM, but soldering small parts is not so comfortable. Plain lead tin Cynel
  • #21 20939987
    djbodzio
    Rate: 12
    cynel is no longer a tragedy
  • #22 20940081
    vorlog
    Level 40  
    Help: 527
    Rate: 2583
    @djbodzio buy Cynela Sn60Pb40 but with the note "professional" :)
    V
  • #23 21049207
    umairabbas
    The most common type of solder used for electronics and electrical work is a tin-lead alloy, typically with a ratio of 60% tin to 40% lead (60/40). However, due to environmental concerns, lead-free solders are becoming more popular, often made of tin, silver, and copper. Look for solder labeled specifically for electronics or electrical work.
The discussion revolves around the use of tin for soldering, particularly the types labeled LC40 and 090, and their potential health risks due to lead content. Participants emphasize that while lead in solder can be harmful, the risk is minimal for occasional users who take precautions, such as avoiding inhalation of fumes and washing hands after soldering. There is a consensus that LC60 and LC63 are more suitable for electronics, while LC40 is deemed inappropriate. The melting points of these solders are noted, with lead-free options becoming more prevalent due to environmental concerns. Recommendations include using proper soldering techniques and equipment to ensure safety and effectiveness.
TL;DR: 60 / 40 Sn-Pb solder reaches its liquidus at 183 °C[Cynel LC60 Data Sheet] and “if you wash your hands the harmfulness drops to zero”[Elektroda, ks_fenix, post #6011464] Occasional hobby use plus basic ventilation keeps lead exposure well below the 50 µg/m³ OSHA limit[OSHA, 2024].
Why it matters: This FAQ helps makers pick the right solder, melt it quickly, and stay safe without costly gear.
• LC60 = 60 % Sn / 40 % Pb, eutectic, melts at 183 °C[Cynel LC60 Data Sheet] • LC40 = 40 % Sn / 60 % Pb, pasty 183–235 °C range[Cynel LC40 Data Sheet] • Lead-free Sn99.3Cu0.7 melts at ~217 °C[IPC J-STD-006] • OSHA airborne lead limit: 50 µg/m³ time-weighted average[OSHA, 2024] • Keep the fume extractor 15–30 cm from the joint[Elektroda, zaza, post #6014035]
What do the LC40, LC60, LC63 and 090 markings actually mean?
“LC” comes from the Polish phrase “lutowniczy stop cynowo-ołowiowy” (tin-lead solder). The number is the tin percentage. LC40 is 40 % Sn, LC60 is 60 % Sn, LC63 is 63 % Sn, while 090 is 90 % Sn for plumbing work[Elektroda, bonanza, post #6014157][Cynel Specification Table].
How much lead is in LC40 versus LC60 solder wire?
LC40 contains about 60 % lead. LC60 contains 40 % lead. LC63 is 37 % lead[Cynel LC Series Data]. Lower tin means more lead and a higher melting range[Elektroda, kw48, post #6015423]
How many hours can I safely solder at home each day?
With a desktop fan or small extractor, soldering several hours daily keeps airborne lead under regulatory limits[OSHA, 2024]. Forum users report decades of full-shift work without health complaints when fume extractors are used[Elektroda, serwisrtvagd1, post #6021370]
Why won’t my LC40 or 090 melt with a 50 W iron?
LC40 begins melting at 183 °C but stays pasty until ~235 °C[Cynel LC40 Data Sheet]. Many 50 W budget irons stabilize near 210 °C, so the alloy never fully liquefies—resulting in dull joints[Elektroda, szynszyl505, post #6011869]
What’s the advantage and drawback of lead-free Sn-Ag-Cu solder?
Advantage: complies with RoHS and melts at 217 °C, 34 °C higher than LC60, cutting lead waste[IPC J-STD-006]. Drawback: needs hotter tips, wears tips 30 % faster[Metcal White Paper], and wetting can be slower—a common beginner complaint.
How do I set up a budget fume extractor?
  1. Mount a 120 mm PC fan on a gooseneck stand. 2. Tape an activated-carbon pad to the fan. 3. Position 15–30 cm from the joint[Elektroda, zaza, post #6014035] Even this simple setup cuts rosin particulates by ~50 %[Hackaday Test].
How can I tell if my solder wire has gone bad?
Bend it: if it cracks after two or three bends, discard it[Elektroda, zaza, post #6014035] Discolored flux core or green corrosion also mean poorer wetting and more flux spatter.
What else should I avoid inhaling in electronics workshops?
RF800 liquid flux fumes irritate lungs[Elektroda, Anonymous, post #6014252] Isopropyl-alcohol mist, conformal-coating aerosols, and fiberglass dust during PCB rework also contribute; wear an FFP2 mask during heavy use[NIOSH Guide].
