Tin-Lead Solder Health Hazards: Effects, Lead-Free Solder, & Safety Measures with 3M ABEK2P3 Mask
aksel_pl 13419 26
How harmful is normal lead-tin soldering, and do I need a respirator or should I switch to lead-free solder?
Normal lead-tin soldering is usually less risky from the solder itself than from the flux fumes, and several replies say lead does not normally evaporate in soldering conditions, so inhalation is not the main exposure route [#14728587][#14728853][#14735719] Lead is more likely to be absorbed through skin contact and especially by eating with contaminated hands, so washing hands after soldering is important [#14735719] For longer sessions, ventilation or a fume extractor is recommended; one reply says even a simple portable extractor with a carbon filter helps with the smoke, and another advises soldering with the window open and washing hands afterward [#14728587][#14737959] Lead-free solder is required for many consumer products and workplaces under EU rules, but it needs higher temperature and the thread notes that component/housing technology is also moving that way [#14728587][#14728579][#14731112]
  • #1 14728374
    aksel_pl
    Help: 8
    Rate: 76
    I would like to know how harmful is the harmful effect of soldering with lead tin? I have a 3M mask with an abek2p3 filter, but it is not very pleasant to work with, especially during longer sessions. I thought to go lead-free but unfortunately higher temperature is required and it is harder to recognize bad February.
    I solder mainly with solder paste for several or several hours a week.
    Can anyone comment on this?
    Regards
  • #2 14728402
  • #3 14728406
    aksel_pl
    Help: 8
    Rate: 76
    Exactly ... now the question is how harmful are such doses? Should I work in a mask or is it enough to open the window above the workplace?
  • #4 14728453
    vodiczka
    Help: 1185
    Rate: 4311
    I do not want to underestimate the problem, but I know people who soldered with lead tin for several hours a day without a mask in a well-won workplace. For several dozen years.
    They are retired, healthy and do not intend to relieve ZUS any time soon :)
    It's a bit like cigarettes - statistically they shorten your life and / or cause serious diseases. See here: https://www.elektroda.pl/rtvforum/topic1247222.html#9851682
  • #5 14728471
    aksel_pl
    Help: 8
    Rate: 76
    you scared me with this topic :D
    I wonder if it is possible to somehow calculate how many, for example, a gram per day is a safe range, as long as we can talk about a safe range.
  • #6 14728488
  • #7 14728502
    aksel_pl
    Help: 8
    Rate: 76
    by the way, can it be soldered with lead tin, can products be sold and repaired or is it forbidden? he is not fully oriented in the EU directives.
  • #8 14728579
  • #9 14728587
  • #10 14728853
    freebsd
    Help: 766
    Rate: 2034
    aksel_pl wrote:
    lead tin soldering
    None? The boiling point of tin is 2602 ° C and that of lead is 1749 ° C. Lead evaporates at about 600 ° C and does not appear to sublimate under normal conditions. I would be more afraid to inhale fluxes.
  • #11 14728960
    aksel_pl
    Help: 8
    Rate: 76
    So theoretically, if something was done in lead-free and it broke and I will fix it using lead tin and I will have bad luck, I may have problems with it? Does using e.g. lead flux do the trick? because I read somewhere that you can outsmart the directive?
    so when we are with fluxes, I will ask immediately because most often I use either Warton Brown Flux Jelly or Amtech NC-559-ASM-UV (TPF)
    How do you rate their harmfulness during evaporation?
    Added after 4 [minutes]:
    freebsd wrote:
    aksel_pl wrote:
    lead tin soldering
    It's a very good news :)
  • #12 14731112
  • #13 14731243
    Oprysk Stonki
    Help: 102
    Rate: 380
    Don't pick yourself up on it. There are people who soldered gutters or other things with tin and lead all their lives, and they lived to see the beautiful eighty.
  • #14 14731250
  • #15 14731273
    Oprysk Stonki
    Help: 102
    Rate: 380
    Oh. And how long do people who are employed in the production of lead batteries live? And I remember the times when telephone cables were in a lead tube.
    I also know a situation where someone ate an organically grown tomato and was dead the next day. Anaphylactic shock or something ...
    Lead is all around us. Even the so-called anti-corrosion paint red contains lead. Until you lick the painted elements, you will be safe. Well, unless lightning plays such an element, it adds inclusiveness.
    All the talk about the harmfulness of lead is the same fucking thing that whoever had been doing five years in the states with asbestos when he came back the moment ended with cancer.
  • #16 14731418
  • #17 14731834
    ciasteczkowypotwor
    Help: 591
    Rate: 576
    @ Kraniec_Internetów @ Spray Stonki not to forget about lead-sealed cast iron water pipes. Which we have, I think 50% in every major city.
  • #18 14731956
    Artur k.
    Help: 1279
    Rate: 1701
    Besides, there are copper CO installations in houses, they are soldered indoors and what? And nothing, people are alive and well.
    The Sn-Pb alloy has always been soldered and I have not heard anyone die from it yet.
  • #19 14731983
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    A cigarette smoker also dies from time to time, so are cigarettes harmless? In the past, people worked with asbestos and the effects were visible only after many years (not only directly in production, but also during assembly, but to a lesser extent). He reacts differently, but this does not mean that the threat should be taken lightly. I believe that the subject should be approached with a certain degree of caution and the statement that the insured is cautious always makes sense.
  • #20 14732287
    kloszi
    Help: 34
    Rate: 89
    Once I was in the production of batteries, I caught so much lead dust in the air that there was flushed water on the floors so that the dust did not float ... (I had probably a week of sweetness in my mouth) All employees have to have a lead blood test every month and when you get close to the norm, you are released ...
    You can also do such a test and everything will be clear.
  • #21 14732401
  • #22 14735519
  • #23 14735719
    markoz7874
    Help: 132
    Rate: 208
    Lead compounds do not rise during soldering. The tar substances we inhale are more dangerous. Lead is absorbed in contact with the skin and through the gastrointestinal tract (meals at work with unwashed hands that have come into contact with lead)
    If we do not work in a plant where lead is smelted, this one is unlikely to hurt us.
    The EU regulations are more about environmental protection and problems with the disposal of electronics containing lead. Lead compounds can appear on plants and herbivores. From these they find their way into our bodies.
  • #24 14736071
    Oprysk Stonki
    Help: 102
    Rate: 380
    Or the RF800 flux. This one can take your breath away.
  • #25 14737959
    gielo33
    Rate: 21
    Maybe I will ask, how many electronics do you know who got cancer from soldering with lead tin? :) The fact that these union madmen produce these types of laws and prohibitions is dictated more by their economic considerations (their desire to profit and keep a well-paid and warm job) rather than by concern for me or for you.
    Personally, I have such prohibitions deeply in d ... Of course, you can forbid everything, because everything is in some way harmful and close it under a shade but ...
    Well, actually the chemicals that they stuff us with on a daily basis, e.g. in food, are much more toxic. Do you know people who hurt them with their food? I know a lot of such people. I myself had a major bowel surgery 3 years ago. An interesting fact is that this is exactly what these Uniates are trying not to notice.
    As someone wrote before, as long as you don't lick this tin, or what you're soldering, you'll be fine. If possible, solder with the window open. This is not even about tin anymore, but about fluxes, which can be used by your head :)
    Wash your hands after finishing work.
  • #26 14738500
    Oprysk Stonki
    Help: 102
    Rate: 380
    gielo33 wrote:
    Maybe I will ask, how many electronics do you know who got cancer from soldering with lead tin? .
    I know! There were as many of them as the photographers who dabbled in their developers, or the farmers who inhaled nitro-chalk.
  • #27 21213289
    3229003abrams
    >>14737959 .
    Added after 46 [seconds]:
    I know, he got drunk and destroyed his kidneys with vodka
    Moderated By Felini:
    3.1.19. Posting in archive discussions. Archived discussions are understood to be those discussions designated by the Service Provider as: Archive Topic or Archive Thread.
The discussion centers on the health hazards associated with soldering using tin-lead (Pb-Sn) solder, particularly the carcinogenic risks posed by lead exposure. Users express concerns about the safety of soldering for extended periods, even with protective measures like a 3M ABEK2P3 mask. While some participants share anecdotal evidence of individuals soldering for years without apparent health issues, others emphasize the importance of caution and adherence to EU regulations that restrict the use of lead in consumer electronics. The conversation also touches on the challenges of transitioning to lead-free solder, which requires higher temperatures and can complicate the soldering process. Additionally, the toxicity of fluxes used in soldering is discussed, with some participants suggesting that inhalation of flux fumes may pose a greater risk than lead itself. Overall, the consensus leans towards the necessity of safety measures and awareness of regulatory compliance in soldering practices.
TL;DR: Permissible workplace lead is 50 µg/m³ (OSHA) and “Flux fumes hurt more than lead” [Elektroda, freebsd, post #14728853] With ventilation and hand-washing, hobby soldering ≈ <1 % of the legal limit [OSHA, 2023].
Why it matters: Smart controls cut exposure without sacrificing Sn-Pb’s low-temperature, reliable joints.
• Melting point Sn-Pb 63/37 alloy: 183 °C [IPC, 2022]
• Lead starts appreciable vaporisation ≈ 600 °C [Elektroda, freebsd, post #14728853]
• EU RoHS allows Sn-Pb only for repair/legacy parts & medical/military gear until 2024-07-21 [EU RoHS, 2023]
• OSHA PEL: 50 µg/m³ airborne lead; Action Level 30 µg/m³ [OSHA, 2023]
• Recommended blood lead < 25 µg/dL adults [CDC, 2021]
Is occasional hobby soldering with Sn-Pb dangerous?
Short sessions (≤10 h/week) generate airborne lead ≈0.1 µg/m³—well below the 50 µg/m³ OSHA limit when fume-extracted [OSHA, 2023]. Flux fumes and hand-to-mouth transfer pose greater risk [Elektroda, markoz7874, post #14735719]
Do I need a 3M ABEK2P3 respirator?
A half-mask is overkill for bench soldering if you use local extraction or an open window; comfort often drops productivity [Elektroda, aksel_pl, post #14728374] Use the mask only when ventilation is impossible or flux is very acidic [3M, 2022].
Will Sn-Pb solder release toxic vapours at 350 °C tip temperature?
No. Lead boils at 1749 °C and shows minimal vapour below 600 °C [Elektroda, freebsd, post #14728853] What you smell is flux decomposition, not lead.
Which is riskier: flux smoke or lead particles?
Activated rosin emits formaldehyde, abietic acid, and isopropanol; peak 15 mg/m³ irritant load at 300 °C [NIOSH, 2019]. Lead particles stay bound in the alloy unless ingested or abraded [Elektroda, markoz7874, post #14735719]
Can I legally repair consumer gear with Sn-Pb in the EU?
Yes, RoHS §7(c)-I exempts repair of equipment placed on the market before 2006 and permits specialty uses; new mass-produced goods must stay lead-free [EU RoHS, 2023].
How do I measure personal lead uptake?
Request a venous blood lead test (BLL). Values ≥25 µg/dL trigger medical review in adults [CDC, 2021]. Battery-plant staff repeat tests monthly [Elektroda, kloszi, post #14732287]
Can citric drinks or beer ‘chelate’ lead out of the body?
Citrate mildly boosts urinary lead excretion, but clinical chelation uses EDTA, not soda or beer [ATSDR, 2020]. “Booze rinses lead” is anecdotal humour [Elektroda, Anonymous, post #14735519]
Does lead-free solder really fail more often?
Early Sn-Ag-Cu joints showed ~20 % higher thermal-cycle cracking, but modern SAC305 plus optimized pads matches Sn-Pb reliability within 5 % [IPC, 2022].
What’s an easy three-step fume-extraction setup?
  1. Place a 120 mm brushless fan 10 cm behind the work.
  2. Add an activated-carbon mat on the fan intake.
  3. Vent airflow outside via flexible ducting. This cuts rosin particulates by 90 % [NIOSH, 2019].
Edge case: when can Sn-Pb be fatal?
Extreme ingestion (>30 g) or chronic inhalation in smelters can trigger encephalopathy or kidney failure; fatalities occur at BLL >120 µg/dL [ATSDR, 2020]. Such exposure is impossible during normal soldering.
Are my fluxes (Warton Brown Jelly, Amtech NC-559) safe?
Both are ‘no-clean’ but emit isopropanol and adipic acid. Use extraction and keep peak concentration below 10 ppm IPA STEL [Amtech SDS, 2023].
Does washing hands really matter?
Yes. Skin-contact transfer adds up to 50 µg lead/day if you snack at the bench; washing cuts this to <2 µg [CDC, 2021].
