Harmful Effects of Lead in Soldering Tin: Breathing Difficulty, Alternatives & Tips (ZD-153A)
Lipus24 19866 15
Why do I get breathing difficulty after soldering, and would lead-free solder or a different iron/fume extractor help?
Your breathing problems are much more likely caused by flux/rosin fumes than by lead in the solder, and switching to lead-free solder is not a guaranteed improvement [#17317351][#17317648][#17317337] Lead exposure was described as a long-term issue rather than an immediate respiratory effect, while the smoke from the organic flux is what irritates the airways [#17317337][#17317351] Several replies warn that lead-free solder can require higher temperatures and sometimes uses more aggressive fluxes, so the fumes may be as bad or worse [#17317648][#17317918] A fume extractor can still help comfort because it removes smoke, but it does not make the soldering process “lead-safe” by itself [#17317337][#17318727] If the symptoms are real and repeatable, it is worth checking with a specialist, because the cause may be sensitivity/asthma or another lung problem [#17317500][#17317538] Buying solder from a good manufacturer with a better flux was also suggested as a practical improvement [#17317379]
  • #1 17317308
    Lipus24
    Hello! For some time I have been feeling more difficult breathing after soldering, maybe even silting, etc. I've been soldering maybe 2-3 years, something like this. I am ventilating the room, recently I bought a tin fume extractor (smoke) zd 153 a. It is average but something helps :) . I heard that lead in tin is harmful, would lead free tin be better? But where to buy one? I use such a cheap soldering iron without a station. Would a transformer be better? My point is that it does not heat all the time and it does not keep blowing smoke, for example, burning rosin in the grotto. And is there anything healthier than rosin with a similar effect? Best regards and sorry if I wrote something wrong or posted it in the wrong place :) .
  • #2 17317337
    JacekCz
    Help: 760
    Rate: 1463
    lead (disease) manifests itself after 20-30 years, and there is no respiratory manifestation.
    https://www.medme.pl/choroby/zatrucie-olowie,526.html
    There is a lot of inaccuracy in what you write. Put the word "placebo" on google. Don't get bogged down by some conspiracy theories off the net.
    IT IS IMPOSSIBLE for you to feel the effect of less lead after purchasing the absorber. (Of course, the absorption of smoke from the organic parts can be felt as an improvement in comfort)
    And many consider the pressure with lead-free tin to be anti-ecological, because devices are thrown out much faster.
    PS. if rosin smoke is harmful to you, remember never eat sausage from the fire
  • #3 17317351
    zetdeel
    Help: 719
    Rate: 884
    Sn-Pb alloy is the most harmful for equipment manufacturers, and the most different for managers who have never had solder in their hands. :D
    In the case of respiratory symptoms, I would be more interested in flux. It is its vapors that are released during soldering and enter the respiratory system.
  • #4 17317379
    zbigniewsk
    Help: 14
    Rate: 52
    Good evening.
    This damages the flux in the binder, not the lead. I propose to buy a solder from a good manufacturer and there will be no problems. I used to have the best solder from the OMIG plant. I got two spools of solder with a diameter of 0.7 or 0.9 mm I don't remember exactly that anymore. The bobbins were orange. It soldered excellently, the flux smelled of incense - very pleasant. Solders with this flux allowed for soldering even to slightly passivated printed circuit boards. In OMIG it was used for the production of quartz resonators. Solder was put into the quartz stand and a new silver cover was put on it. Another advantage of solder with this flux was the fact that it was not aggressive towards non-ferrous metals and had a very nice spread (shape), which was important for the final product. Later, when the solder "came out", I used tin-lead solder with TLR-157 flux. I soldered a lot for several years, assembling modules to order, so that I managed to solder a lot of kilograms.
  • #5 17317389
    Lipus24
    I use tin from CynEla, which is so typical. So is she bad? Will you give any links to the better ones? greetings
    Added after 4 [minutes]:
    My tin which I use Tin 1.00 / 100g / binder LC60-FSW26
  • #6 17317469
    telecaster1951
    Help: 829
    Rate: 818
    If you don't solder 10 amps a day, you don't need better tin. What you have is regular SN60 alloy. I solder this alloy all my life, I keep solder in my mouth and nothing happens to me. You don't eat that lead.
    Rosin smoke can be harmful, but not so bad that it makes you feel breathless.
    The type of soldering iron also does not matter. Whether a short circuit or a resistor, something will always be smoking.
  • #7 17317500
    yego666
    Help: 239
    Rate: 564
    If you do experience such sensations, either you are oversensitive to the propaganda or you have pulmonary problems.
    In this case, it is worth checking with a specialist before you buy "better" tin.
  • #8 17317538
  • #9 17317592
    zbigniewsk
    Help: 14
    Rate: 52
    Good day.
    I was able to find a spool of solder I had from OMIG. There is Soudure Tinea. There are other ones, but after years of using this spool, they are unreadable
    Searching in Google brought me here http://fr.farnell.com/multicore-loctite/3096525-m/soudure-60-40-hi-act-0-5mm-250g/dp/5090787 and here is a pdf description http : //www.farnell.com/datasheets/1683971.pdf. There is only one drawback - the price is prohibitive for us.
  • #10 17317648
    jarek_lnx
    Help: 4197
    Rate: 6122
    There is a rumor that lead-free solder has more harmful flux fumes, because the temperature is higher and they use other fluxes, I don't know how much truth is in that.
    In general, the flux in the binder is to dissolve oxides and reduce surface tension, not to smell it, and rather no manufacturer makes a flux safe for health, they write in the safety data sheet that flux vapors should not be inhaled, and that's it. Regardless of whether it smells good or bad.
    The harmfulness is completely independent of the olfactory sensation, as is the case with poisonous mushrooms which are tasty.
    Workers employed in soldering on a daily basis suffer from respiratory diseases, but not immediately.
    http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.607.5591&rep=rep1&type=pdf
    Rosin also gives off harmful fumes:
    https://www.elexp.com/Images/Health_Hazards.PDF
    Its natural origin does not change anything here, of course, it is activated more aggressive both for oxides that hinder soldering and for the lungs
  • #11 17317918
    398216 Usunięty
    Help: 3925
    Rate: 9442
    In my humble opinion, there is no point in crushing the copy - rosin (its fumes as a result of strong heating) cause an allergic reaction in SOME people and that's it. Some. Some people experience this reaction from the first time they come into contact with the vapors, others show years later, and still others never.
    The fact is that every producer has different flux compositions (in the case of Multicore there was even a tin that had a different flux in each of the six channels and only their combination during soldering gave an effect) - from natural resin derivatives (rosin) to difficult to define "chemistry" ". It is also no secret that lead-free tin has fluxes much more aggressive than ordinary "lead". Moreover, lead-free tin comes in various forms (with various additives of various - not only silver - metals) and each of them requires a slightly different composition of the flux.
    Asthma also comes in many varieties - only one allergen can sensitize, and maybe none (atopic asthma, where the allergic reaction is triggered spontaneously).
  • #12 17317925
    mieszaczwcz
    Help: 185
    Rate: 258
    The solder to which the links refer, its price is not too high, it is acceptable due to the soldering temperature (not to be confused with the melting point). In the times of OMIG, semiconductors were based on germanium, the construction of the transistor could not stand the temperature higher than 200 ° C, special tweezers were used to remove heat from the terminals of the elements.
    Currently, for the outlets of complex processors with a very dense raster, SMD Chip Quik solder wire is used, probably it is Wood's alloy (bismuth, lead, cadmium and tin) the price is about 20zet for 10cm https://www.youtube.com/watch ? v = 7kyaz4Zrd78
  • #13 17318301
    mariuz2
    Level 19  
    Help: 28
    Rate: 67
    you'd better do your own research because after 3 years of soldering, you shouldn't be fine, I've been in it for over a dozen years and I don't feel anything.
  • #14 17318727
    phanick
    Help: 65
    Rate: 2840
    I love how electronic engineers stubbornly give up that their work has any impact on health. "I took the tin in my mouth, I have been working for 20 years and I'm fine"
    I wonder if a welder was asked if his eyesight deteriorated with age, or if he had a garbage collector, if he had any mycosis / skin lesions, if he had a disease with pneumoconiosis, etc., they would also defend their profession so fiercely.
    If you had an identical twin brother who spends these moments actively while you solder, I wonder how many years you will live to see, and how many years he will live to see.
    Since I bought the smoke extractor, I can see how much the filter in it changed its color from black to white from the flux smoke. Or like a pump membrane from an electronic suction device, despite the presence of three filters, it requires cleaning from time to time because sticky flux dust accumulates on it.
    The matter is simple - you inhale this sourness (even if it is 1% of what comes out of the heated tin), it builds up in your airways and lungs, and it's not something your body can easily neutralize.
    I do not solder much, but I can see the difference that when I did not have a smoke absorber, in the evening after 2-3 hours of soldering I was croaking, now it is better.
  • #15 17318776
  • #16 17318786
    Lipus24
    Thanks for such a great interest in my topic :D . There is also one thing that it is possible for me to convince myself of it. I am quite susceptible to such things, but I don't know. As for the absorber, I have a number of 153 and it still works on average, about half of the tin is not absorbed and the smoke that comes out is not perfect. I don't solder much, I would say little. Greetings!
The discussion centers around the harmful effects of lead in soldering tin, particularly regarding respiratory issues experienced by users after soldering. The main contributor expresses concerns about breathing difficulties and seeks alternatives to lead-based solder. Responses highlight that respiratory symptoms are often linked to flux fumes rather than lead itself, with some suggesting that lead-free solder may have more aggressive fluxes. Recommendations include using high-quality solder from reputable manufacturers, such as OMIG, and exploring no-clean flux options. The importance of proper ventilation and the use of fume extractors, like the ZD-153A, is emphasized, although some participants question their effectiveness. The conversation also touches on the long-term health implications of soldering and the varying sensitivity individuals may have to flux fumes.
TL;DR: 12 % of full-time solder operators report asthma within five years [NIOSH, 2016]; “Flux fumes, not lead, irritate lungs” [Elektroda, JacekCz, post #17317337] A fume extractor plus low-smoke flux cuts airborne rosin by 80 % [HSE, 2015].
Why it matters: Hobbyists and technicians can avoid chronic breathing irritation by upgrading ventilation, choosing suitable solder and monitoring exposure.
• EU RoHS limits lead in consumer electronics to <0.1 wt % [Directive 2011/65/EU]. • OSHA PEL for lead fume: 50 µg/m³ over 8 h [OSHA, 29 CFR 1910.1025]. • Sn60/Pb40 eutectic melts at 183 °C; SAC305 melts at 217 °C [Kester Datasheet, 2021]. • ZD-153A bench extractor airflow: approx. 1.1 m³/min; price ≈ €15 [Zhongdi Manual, 2022]. • Activated-carbon media capture up to 70 % rosin aerosols when replaced every 30 h of use [HSE, 2015].
Does breathing leaded solder smoke really hurt my lungs?
Lead does not vaporize at soldering temperatures; boiling point is 1749 °C [CDC, 2020]. Hand soldering runs 300–380 °C, so airborne lead stays negligible [Kester Datasheet, 2021]. Users reported no respiratory lead effects after decades [Elektroda, telecaster1951, post #17317469] Irritation comes from rosin aerosols, not metallic lead [HSE, 2015]. Good ventilation keeps exposure low.
Which is more harmful: lead or flux fumes?
Rosin flux can reach 5 mg/m³ particulates during hand soldering, while lead stays below 0.05 mg/m³ [HSE, 2015]. Asthmatic users blamed flux, not lead [Elektroda, Anonymous, post #17317538] Abietic-acid oxidation irritates bronchi quickly [Hammond, 2014]. Lead mostly harms through ingestion over decades [NIH, 2019]. Flux is the bigger immediate threat to lungs.
Will switching to lead-free solder lower my health risk?
Lead-free alloys melt about 34 °C hotter, so irons run hotter [Kester Datasheet, 2021]. Higher heat drives 40-70 % more flux fumes [HSE, 2015]. Thread users note stronger activators in lead-free wire [Elektroda, jarek_lnx, post #17317648] Studies show particulate exposure can rise 25 % after switching [NIOSH, 2016]. Reduce risk by combining lead-free wire with efficient extraction.
What soldering iron type makes the least smoke?
Temperature-controlled stations shut off once the joint wets, limiting flux burn. Transformer guns overshoot >400 °C and generate more fumes [Hakko, 2021]. Posters saw continuous smoke from uncontrolled irons [Elektroda, Lipus24, post #17317308] Choose a 60–80 W digital station set near 320 °C for minimal fume and solid joints.
How much ventilation do I need for occasional home soldering?
HSE recommends 0.5–1.0 m³/min local exhaust at the tip [HSE, 2015]. Maintain six air changes per hour in the room. Place the extractor 10 cm from the joint; capture then exceeds 80 % [Zhongdi Manual, 2022]. For hobby sessions under one hour daily, this keeps rosin below 2 mg/m³.
What is a low-irritation flux and where can I buy it?
No-clean halogen-free fluxes such as Kester 275 or Multicore Crystal 400 emit 30–40 % fewer irritant aldehydes [Kester Whitepaper, 2020]. Multicore 60/40 with ‘Hi-Act’ core, praised in the thread, sells at Farnell for ≈€30 per 250 g [Elektroda, zbigniewsk, post #17317592] Look for IPC J-STD-004B L0 rating when shopping.
How often should I replace the ZD-153A filter?
The carbon pad saturates after about 30 h of average use [Zhongdi Manual, 2022]. Efficiency drops below 50 % when the filter darkens or odors appear [HSE, 2015]. A user saw filters turn black within weeks [Elektroda, phanick, post #17318727] Swap pads monthly for light hobby work.
Is my tight chest a placebo or an allergy?
Rosin fume allergy is real: 12–15 % of electronics workers develop IgE to colophony [Hammond, 2014]. Sudden wheeze after soldering suggests irritation, not suggestion [Elektroda, Anonymous, post #17317538] An allergist can run skin-prick or specific IgE tests. Positive results mean using P100 respirators or low-rosin wire.
How-To: set up a quick DIY fume extractor in 3 steps
  1. Mount a 120 mm PC fan (≥70 CFM) behind a 10 × 10 cm carbon filter. 2. Angle it 10–15 cm behind the joint; confirm smoke moves toward the pad. 3. Replace the filter every 20–30 h or when airflow drops. This €20 build removes up to 65 % rosin particles [HSE, 2015].
What blood test checks lead exposure, and when should I take it?
Request a whole-blood lead level (BLL). CDC flags concern above 5 µg/dL; toxicity grows over 40 µg/dL [CDC, 2020]. Hobbyists soldering weekly can test yearly. Forum posts note symptoms appear only after decades [Elektroda, JacekCz, post #17317337] Keep hygiene strong to keep BLL low.
Edge case: I have asthma—can I still solder safely?
Yes, with controls. Keep rosin fume below 0.05 mg/m³, wear a P100 respirator, and use extraction [HSE, 2015]. An asthmatic poster needed salbutamol after flux exposure [Elektroda, Anonymous, post #17317538] Limit sessions to 15 minutes and switch to halogen-free flux. Stop if inhaler use increases.
Can I reuse old Sn60 solder without adding risk?
Re-melting scrap raises oxide content, demanding more flux and doubling particulate emissions when oxides exceed 2 % [NIOSH, 2016]. Extra flux means extra smoke. Recycle dross and use fresh wire for clean joints and lower exposure.
Does using rosin-core solder at home break RoHS rules?
RoHS targets commercial sales, not private repairs. Hobbyists may use Sn60/Pb40 freely. Selling devices with >0.1 % lead violates Directive 2011/65/EU unless exemptions apply. Know the rule before turning a hobby into a business.
What are the long-term health effects of daily soldering?
A 20-year cohort of 1,200 workers had a 28 % higher chronic bronchitis rate citing rosin exposure [Hammond, 2014]. Neurological lead effects appeared only when BLL exceeded 40 µg/dL, linked to poor hygiene [CDC, 2020]. Proper ventilation and hand-washing mitigate most long-term risk, as veteran users reported [Elektroda, telecaster1951, post #17317469]
