Candy Aquamatic 6 Washing Machine: Find User Manual, Single Knob Program Selection Guide
aga1199 56022 7
  • #1 6387916
    aga1199
    He rents an apartment and there is a washing machine in it, I can't find a manual for it. It has only one knob on which there are only numbers so I don't know what program I turn on. Please help.
    Regards
    Aga
  • #2 6387999
    ar_j
    Rate: 49
    I'm not 100% sure if it's in this model but I saw the following thing once:
    After pulling out the powder drawer, you can see such a blue (nautical?) strip on top. You have to pull it up. In this way, a plate with descriptions of the washing programs will come out of the secret slot.
    Regards.
  • #3 6388178
    aga1199
    Great, thanks a lot you are right :D
    Regards
  • #4 7072601
    Tomasz2701
    I have a similar problem with program descriptions. But I don't have this tag with descriptions. Would it be possible to send these descriptions or a clear photo of this plate?
    Regards.
  • #5 7327153
    megan_ka
    Rate: 18
    I have been renting an apartment for 2 days myself, where there is such a washing machine and I sat down to the computer to look for instructions and through the answers above I came across info about the plate - I had it :)
    Here's what it says for those interested:
    Resistant cotton fabrics
    program 1 very dirty 90 degrees max 3kg
    program 2 normal wash 60 degrees max 3 kg
    program 3 quick wash 40 degrees max 2 kg
    program 4 rinsing only max 3kg
    program 5 quick spin max 3kg
    Delicate, synthetic fabrics
    program 6 very dirty 60 degrees max 2kg
    schedule 7 universal washing 50 degrees max 2 kg
    schedule 8 quick wash 40 degrees max 2 kg
    schedule 9 wool 40 degrees max 1 kg
    program 10 slow spin max 1.5 kg
    Additional programs
    program A prewash 40 degrees max 3kg
    "triangle" program stain removal max 3kg
    Z program draining the water
    I hope I have helped those interested :)
    the answers above helped me, because I would not have found this plate myself :)
    megan
  • #6 7401609
    ar_j
    Rate: 49
    Candy Aquamatic 6 washing machine.
    I found the manual, attached.
    • aquamatic-6.pdf (1.1 MB) You must be logged in to download this attachment.
  • #7 7401652
    megan_ka
    Rate: 18
    thank you very much
    unfortunately, the plate itself does not inform about the duration of a given program - I was delighted to put the laundry on program 2 - normal washing 60 degrees - it lasted almost 2.5 hours!!
    massacre - terribly long and only holds a maximum of 3 kg, otherwise it will not wash thoroughly ...
    the instruction will come in handy - maybe the washing times will be :)
    although I'm still wondering if I should buy a new bigger one...
  • #8 7401806
    ar_j
    Rate: 49
    2.5 hours on the 60 ° C program is not so bad ... Although it is possible that the heater is a bit scaled. I suggest an invigorating "empty" wash at 90 ° C with a descaler.
    By the way, at the moment it is considered "normal" to wash at 40 ° C. And on such programs, washing machines work for 2-2.5 hours ... This is what class A, AA, AAAAAA etc. is all about. ;)
    Regards.
The discussion revolves around the Candy Aquamatic 6 washing machine, specifically addressing the lack of a user manual and the single knob program selection. Users shared insights on locating a hidden plate with program descriptions by pulling up a blue strip in the powder drawer. Detailed washing programs were provided, including settings for cotton, synthetic fabrics, and additional options. Concerns about long wash durations, particularly for the normal wash cycle, were raised, with suggestions for maintenance through descaling. A user also shared a manual for the machine, which was appreciated by others in the discussion.
