Car Radio Power Consumption: Selecting the Right Power Supply for DIY Garage Project
Homeruss 49658 17
How much current can a car radio draw, and what power supply should I use for a DIY garage setup?
A car radio’s current draw depends on the model, volume, and speakers: a quiet unit may only take a few hundred milliamps, while a more powerful radio can need 5A or more, and 4x20W RMS models can draw 10A+ at full volume [#6396858][#6396871][#6397847][#6439248] If the radio is labeled with something like 4x35W, plan for a high-current supply; for lower-power or budget radios, 1–2A may be enough [#6397010] The safest way to size the PSU is to run the radio from a battery and measure the current with an ammeter [#6396858][#6430648] If you build a rectified 12V supply, use proper filtering: 470µF was reported too small and caused hum, while 2200µF to 4700µF removed it [#6430259][#6439248]
  • #1 6396852
    Homeruss
    Help: 7
    Rate: 26
    How much electricity can a car radio draw? I'm going to make myself such a radio in the garage and I don't know what power supply to do it.
  • #3 6396871
  • #4 6396882
    Homeruss
    Help: 7
    Rate: 26
    So if you want to make a power supply for nigo, the transformer is at least 5 A ??
  • #5 6396895
  • #6 6396944
    Homeruss
    Help: 7
    Rate: 26
    It's not some old cassette radio. I tried to connect it to some old ATX power supply with a power of about 100W and the radio worked only that nothing changed on the display, even though I was turning the frequency knob. Does this mean that the PSU is too weak?
  • #8 6397847
    konik83
    Help: 7
    Rate: 11
    New radios around 4x20W RMS can draw 10A and even more.
  • #9 6398276
    pita1988
    Help: 57
    Rate: 88
    I doubt :D 5A is more real
  • #10 6430207
    Homeruss
    Help: 7
    Rate: 26
    I assembled the power supply from a 12V - 0.5A transformer; rectifier bridge and electrolytic capacitor 470µF and when the speaker is connected, it "buzzes" terribly in it. Radio reception is fine but the buzzing is annoying. Is there a way to mute it or is it possible to modify this power supply somehow? I will add that it is about 2 meters away from the radio.
  • #12 6430522
    Vsad
    Level 19  
    Help: 7
    Rate: 12
    Capacitors are not small. How many do you have ? 0.5 A + rectifier bridge is a bit small, you need to give another power supply or a small 12 V battery, e.g. 1200mA
  • #13 6430618
    Bretos
    Help: 11
    Rate: 8
    Gee, I suggest you see what the fuse is in this radio, and use a power supply that is 0.5A weaker ... Simple.
  • #15 6430648
    Vsad
    Level 19  
    Help: 7
    Rate: 12
    Jeju connect to the battery, put the volume on max and check with the meter how much power it consumes and then combine. If it hums, it can't be weaker. Even if it is 10A, the radio will only take 3A
    James695 it's also true that there should be some condek behind the bridge, preferably a pair
  • #16 6439248
    Homeruss
    Help: 7
    Rate: 26
    James695 wrote:
    The 470 micro capacitor is very small, and it is what causes the hum. Install a 2200 micro capacitor and check.
    You were right. I installed a 4700 µF capacitor and the radio no longer hums. As for the current, I checked it on a car battery and max draws 0.3A, so 0.5 should be enough.
  • #17 6441176
    konik83
    Help: 7
    Rate: 11
    With 5A at 14V you will make a maximum of 70W of power.
    4x20 > 70. The power is already missing, and where is the CD drive, display, efficiency ....
    My radio has a 15A fuse, that also means something.
    Of course, if we listen quietly, the conscription will not be so large.
  • #18 6449734
    ciuqu
    Help: 512
    Rate: 829
    Half an amp is enough to listen to the radio quietly.
    What radio is this?
    Regards
The power consumption of car radios varies significantly based on the model, volume, and speaker configuration. At maximum volume, a typical car radio can draw over 5A, with some newer models potentially requiring up to 10A or more. For DIY projects, a power supply should be rated at least 5A for higher power radios, while lower-end models may operate on 1-2A. Users have reported issues with power supplies, such as buzzing sounds, which can often be resolved by increasing the capacitance of the filter capacitor. A 4700µF capacitor was suggested to eliminate hum, and it was confirmed that a 0.5A supply could suffice for low volume listening. It's important to check the radio's specifications, including fuse ratings, to determine the appropriate power supply.
