[Solved] Car Radio Battery Drain: Overnight Discharge Impact & Preventative Measures
miron50 50236 15
Can a car radio discharge the battery overnight, and how can I check or prevent it?
Yes—if the radio is wired incorrectly or does not enter standby properly, it can drain the battery overnight. Measure the current with an ammeter in series on the yellow or red wire; a normal standby draw is only a few mA, sometimes as low as 1 mA, while a faulty unit can draw 200 mA or more [#7104859] If the power section stays powered even when the radio is off, it can still consume battery current [#7104771][#7103117] One user confirmed a drain of 0.27 A with the radio connected directly to + on both yellow and red wires, which prevented starting after two days; moving the red wire behind the ignition switch solved it [#7169396] The usual wiring is yellow permanently to + for memory and red switched by ignition, though some radios use the opposite order according to the manual [#7104915]
  • #1 7102636
    miron50
    Rate: 20
    If the radio is turned off overnight, it may discharge the battery?
    7 words 3 mistakes. Too many% of these errors. Correct your post by using the Spelling key. Reg. point 15 and 10.9. damiancz
  • #2 7102641
    korrus666
    Level 40  
    Help: 584
    Rate: 476
    If it is operational it shouldn't.
  • #3 7103117
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1411
    If it is connected incorrectly, it can also discharge the battery, although for 1 night a functional radio should not completely discharge it.
  • #4 7104074
    djlj24
    Car audio specialist
    Help: 1104
    Rate: 1328
    The new Sony models, even if they are efficiently connected without the key, can discharge the battery overnight. Same as Nakamichi radios.
  • #5 7104764
    Michal232323
    Help: 11
    Rate: 30
    I do not understand how the turned off radio can discharge the battery?
  • #6 7104771
    kogiel
    Help: 11
    Rate: 44
    If it is badly connected, the power end is still powered, even though the radio is theoretically turned off
  • #7 7104859
    l.k.
    Maybe it does a lot. To find out, you need an ammeter. We turn it on the yellow or red wire, depending on the radio. You can measure both of them, 1 time later 2. Usually the power amplifier is damaged, it does not switch to "stand by" mode. The radio in this mode should consume about a few mA, some even 1mA. The damaged one will consume a current of 200mA or more. Unfortunately, this will happen with a weak battery and parking in the open air. You can also check without an ammeter, then the radio should be noticeably warm in the back.
  • #8 7104915
    kogiel
    Help: 11
    Rate: 44
    Well, the point is that often in radyjki they do not use tips with the st option - they only release 2 wires, yellow and red, one is to support, for example, the memory and the watch, and the other is to power the tip and a few other things so that the radio does not run out of battery, you need to connect it so as in the radio manual, i.e. yellow permanently and red after the ignition switch (sometimes the other way around)
    10 spelling mistakes in your post are way too many - correct it. I recommend the Spelling key. damiancz
  • #9 7106199
    miron50
    Rate: 20
    Hello and greetings! I disconnected the radio, the battery szrot (I bought a new one) I will write you a few words about this radio. it was wrong, but if you can connect them differently, there are two cubes, one power supply and the other speakers and antenna plug, the radio was playing, replacing the plugs will not lead to anything, I must admit that I'm green now, it's a pity because a nice mp3 usb, sd radio. ah and one more thing, radio stations did not go to listen to the distortion in the form of gurgling, damn it knows what it can be, the previous radio sounded good on this antenna, today I gave PLN 250 for the battery, maybe someone knows what can be with it ... thanks for the answers !!! :D
    Again, a dozen spelling mistakes, if you don't correct your posts, they will end up in the trash. All you have to do is want it. Regulations, points 15 and 10.9.
  • #10 7108967
    Michal232323
    Help: 11
    Rate: 30
    Maybe it is enough to replace the yellow wires with the red ones, but let someone else comment on this
  • #11 7110882
    zaq1.9
    It is best to pull out the panel
    Moderated By damiancz:
    There are Polish letters in Polish and they should be used
  • #12 7110923
    zezuama
    Help: 53
    Rate: 53
    My friend
    Do as your colleagues advise you, measure the radio with an ammeter and share the results,
    then we will continue to debate.
  • #13 7113240
    WITEK1952
    Help: 75
    Rate: 388
    Hello. Ammeter and you know everything. I would also check the battery itself and the charging voltage. Regards.
  • #14 7169396
    Micki_2004
    Help: 25
    I confirm that the car radio can discharge the battery. I had the Imago iM-C2 radio connected to the yellow and red cables directly under the + and after two days of inactivity on the car's auto alarm, I could not start. The current consumption with the ignition switch off was 0.27A. Connecting the red wire behind the ignition switch solved the problem.
  • #15 7169936
    damiancz
    Help: 475
    Rate: 1411
    I think that the topic has already been completely exhausted - I close.
  • #16 18276061
    miron50
    Rate: 20
    can discharge
The discussion centers around the issue of car radios potentially discharging the vehicle's battery overnight, even when turned off. Responses indicate that a properly connected radio should not cause significant battery drain. However, incorrect wiring can lead to power being drawn even when the radio is off. Specific brands like Sony and Nakamichi are mentioned as models that may still draw power under certain conditions. Users suggest using an ammeter to measure current draw and check for faulty components, such as a damaged power amplifier that fails to enter standby mode. Proper wiring, with the yellow wire connected to constant power and the red wire to the ignition switch, is emphasized as crucial for preventing battery drain.
