1.9TDI glow plug removal: is it better to replace on a warm or cold engine?
andre7725 70990 15
Should glow plugs be removed from a 1.9 TDI engine when it is warm or cold?
Remove the glow plugs when the engine is warm; several replies say warm aluminum expands and makes the plugs come out more easily, while difficult cold plugs can loosen smoothly once hot [#17682444][#17683206] One reply explains that aluminum expands more than the steel glow plug, so heating enlarges the hole and eases removal [#6503255] Another warns that unscrewing them hot can risk damaging the aluminum head threads, but that view is contradicted by later technical replies in the thread [#12043374][#17683206] If you fit new glow plugs, tighten them only after the engine has cooled down [#17683206]
  • #1 6502932
    andre7725
    When we remove the glow plugs, should the engine be warm or cold? Because I`m already crazy, one mechanic says yes, the other says yes. I will be grateful for the information.
  • #2 6502943
    mr.Sławek
    Level 32  
    Help: 207
    Rate: 207
    I don`t think it matters.
  • #3 6502966
  • #4 6503055
    Zygaqra
    Help: 257
    Rate: 496
    Logically, when cold. Where does this logic come from, and why do you replace the spark plugs because they are burnt, and if the plugs are burnt, the engine will most likely not start, which in such a case would require warming up the engine to remove the spark plugs. This probably makes no sense and confirms my reasoning ;-)
  • TDI starts above 5 C without glow plugs
    #5 6503096
    andre7725
    [quote="Zygaqra"]Logically speaking, when cold. Where does this logic come from, and why do you replace the spark plugs because they are burnt, and if the plugs are burnt, the engine will most likely not start, which in such a case would require warming up the engine to remove the spark plugs. This probably makes no sense and confirms my reasoning ;-) [/quote
    The TDi engine will start without glow plugs if the temperature is above +5 degrees C.
    Nevertheless, what you wrote is logical.
  • #7 6503286
  • Slowly work soaked glow plugs back and forth
    #8 12041718
    bieniek1984
    Rate: 19
    In general, I read a lot about it and to be honest, I had a spark plug break once, but it was crazy and it was done on a cold engine. Now I`m about to replace my second car, there are two that need to be replaced and I`m not doing anything rash anymore. I have been pouring brake fluid and WD40 on the spark plug for 2 days now. As for warm or cold, there is probably no difference (personally, I lean towards cold because the aluminum expands when warm and the diameter of the hole increases, and no matter how badly it goes, you won`t even feel the thread stripping. The important thing is to slowly move forward a little at a time. backwards and water it to the max with preparations and hopefully it will work.
    And finally, as I read somewhere, if it`s supposed to break, it will break, but I hope that everyone will be able to get it out without any problems.
  • #9 12043256
    swap
    Help: 6
    Rate: 71
    Mistrzunio1991 wrote:
    It doesn`t matter, but if the head is made of aluminum, it is easier to unscrew when the engine is cold.
    Can you find out more about this theory?
  • #10 12043374
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    It is always better to unscrew it when cold, because when unscrewing it while hot, you run the risk of unscrewing it along with the thread of the aluminum head. These threads often turn to powder. So much for practice.
  • #11 12045878
    bieniek1984
    Rate: 19
    Exactly
    Added after 5 [hours] 46 [minutes]:
    I managed to replace it without any problems :)
  • #12 17682061
    mxt
    Rate: 23
    I only replace it when cold, so logically the head expands and tightens the spark plug, then the thread falls apart.
    Moderated By szymitsu21:
    The next tip of this type will be rewarded with a warning.
    3/1/11. Don`t send messages that don`t add anything to the discussion. They are misleading, dangerous or do not solve the user`s problem.
  • #13 17682329
    cyborg39
    Help: 105
    Rate: 546
    Since when does the hole close after heating? They have always taught in physics that heated material expands "outwards", all holes have always enlarged when heated, and you are creating new rules of the world that the hole tightens when heated? Maybe the engine block for pressing in dry bushings should be frozen?
  • #14 17682444
    przemallo
    Help: 21
    Rate: 49
    Glow plugs that are difficult to start when cold often come out smoothly when the engine is hot. It is worth screwing new ones in with ceramic paste.
  • #15 17683206
    BANANvanDYK
    Help: 1169
    Rate: 2609
    This topic from 10 years ago can be closed - it only represents the state of technical ignorance from that period.
    Glow plugs should be removed when the engine is warm. Even several current articles from the automotive press write about it.
    The expansion of aluminum always enlarges the holes - so much so that cold bearings can be mounted in hot aluminum without using a hammer, and hot disassembly is easier than cold disassembly. In addition, current glow plugs have a significantly offset tip, which seals to the thread area. Anyone who has dealt with spark ignition engines probably knows what happens with a spark plug screwed in cold and screwed in hot (with a torque wrench), where the distance from the thread to the resistance plane is almost zero...
    And of course, tighten the glow plug only after the engine has cooled down.
  • #16 17683722
    cyborg39
    Help: 105
    Rate: 546
    BANANvanDYK wrote:
    it only represents the state of technical ignorance of that period.
    Sorry, it was the Middle Ages 10 years ago? The state of knowledge of these few "delinquents" has nothing to do with "that period" but with their total lack of education.
The discussion centers around the optimal conditions for replacing glow plugs in a 1.9 TDI engine, specifically whether to perform the replacement on a warm or cold engine. Most participants agree that it is preferable to replace glow plugs when the engine is cold, primarily due to the thermal expansion properties of aluminum cylinder heads, which can make it more difficult to unscrew the plugs when hot. Several contributors emphasize the risk of damaging the threads in the aluminum head if the plugs are removed while the engine is warm. Some also mention that modern glow plugs may behave differently, suggesting that they can be easier to remove when warm, but caution remains regarding potential thread damage. Overall, the consensus leans towards cold engine replacement to avoid complications.
