Removing Broken Glow Plugs in Ford Mondeo MK3 2.0tdci 2003 without Head Removal
darek.b2000 9684 10
  • #1 16272070
    darek.b2000
    Hello, how can you remove broken glow plugs in Ford Mondeo MK3 2.0tdci 2003? without removing the head
    Removing Broken Glow Plugs in Ford Mondeo MK3 2.0tdci 2003 without Head Removal16709677_1...2737_o.jpg (359.84 kB)You must be logged in to download this attachment.
    Removing Broken Glow Plugs in Ford Mondeo MK3 2.0tdci 2003 without Head Removal16731946_1...5905_o.jpg (392.05 kB)You must be logged in to download this attachment.
    Removing Broken Glow Plugs in Ford Mondeo MK3 2.0tdci 2003 without Head Removal16734973_1...9897_o.jpg (369.6 kB)You must be logged in to download this attachment.
  • #2 16272078
    kkknc
    Help: 1904
    Rate: 6628
    You find a company on the net you are calling. They come and dial. You can also buy a drill set and play yourself.
  • #3 16272101
    robokop
    Help: 1760
    Rate: 6349
    kkknc wrote:
    You can also buy a mirror set and play yourself
    What will come out even more expensive.
  • #4 16272120
    ftp.kowal
    Level 36  
    Help: 327
    Rate: 1832
    I don't know if I can see correctly, but there was probably something combined there, which would increase the cost of the service. The kit can buy, only if it breaks the tap will get worse. For a company dealing with this, it is a while and you are a few hundred lighter.
  • #5 16272631
    darek.b2000
    I know all this but I want to do it myself
  • #6 16272669
    ftp.kowal
    Level 36  
    Help: 327
    Rate: 1832
    Enter the glow plug unscrewing kit on Google for a variety of choices. Just don't be surprised if something goes wrong and you'll need to drill, drill tap or spindle. It may happen that you damage the candle socket, but in extreme cases.
  • #7 16272887
    andrzej20001
    Help: 1571
    Rate: 6622
    You can do it yourself ... sometimes
  • #8 16273132
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    If you want to do it yourself, you can also find a way to do it yourself.
    On youtube there are videos on how to do it and what tools to use. I advise you to take the advice of a robokop colleague to heart because it certainly won't be cheaper by yourself.
  • #9 16273242
    JaKotlinka
    Help: 6
    Rate: 117
    I had such a problem with Zafira 2.0. The head was removed, without experience it is hard to do it. as someone has done it before and you can benefit from experience. There is a purchase of tools and risk. It is easier to disassemble the head and have someone who will repair the head [I mean removing broken candles]
  • #10 16273339
    ftp.kowal
    Level 36  
    Help: 327
    Rate: 1832
    It makes no sense to pull off the head and give it to someone to "pull out" the candles. It will come out even more expensive than pulling them out on the car. For the first candle I pulled out, all I needed was a 9 mm drill and of course a lot of patience. now I have sets for a nice few zlotys and some candles are still difficult.
  • #11 16273375
    JaKotlinka
    Help: 6
    Rate: 117
    As a colleague from Mondeo did not do this and there are no tools for it, it is better to return the car to a mechanic and have the broken candles replaced
✨ The discussion revolves around the challenges of removing broken glow plugs from a Ford Mondeo MK3 2.0 TDCi (2003) without removing the cylinder head. Participants suggest various approaches, including purchasing a glow plug unscrewing kit and attempting the removal themselves, while cautioning about potential complications such as damaging the glow plug socket. Some users recommend watching instructional videos online for guidance. Others express skepticism about the feasibility of a DIY approach, noting that professional help may ultimately be more cost-effective, especially if tools are required and the process becomes complicated.
