Converting 250Ah 12V Battery to kWh & Calculating Mini Power Plant Capacity Requirements
rroobbaall 227328 4
  • #1 6531124
    rroobbaall
    How to convert battery capacity, for example 250 Ah at 12 V, to kWh at 220 V? I need to calculate how many and what kind of batteries I need to build a mini power plant.
  • #2 6531135
    pudzianowski
    Help: 82
    Rate: 127
    You also need to take into account the losses of the device converting 12V to 220V.
    kulmar
    Help: 184
    Rate: 382
    250 Ah * 12V = 3000 Wh = 3 kWh
  • #4 8307927
    cmepro
    Help: 7
    Rate: 50
    I`m going on holiday soon and I`m wondering, since there won`t be any electricity there, whether I`ll be able to provide some light using a battery.
    The case looks like this:
    battery: 100Ah 12V
    bulb: regular household: 40W 230V
    100 Ah * 12 V = 1200 Wh => 1.2 kWh
    1200 Wh: 40W = 30h
    Do I understand correctly that a fully charged battery will allow me to use a 40W bulb for approximately 30 hours?
  • #5 8307938
    Hucul
    Help: 382
    Rate: 470
    When using a 12V/230V converter, you must take into account at least 30% losses. A 12V bulb will be more economical.
