12V 200Ah Battery Life with 12V/230V 800W/1600W Converter at 500W Load: Charge/Discharge Cycles
Adi_B 60717 6
  • #1 8790448
    Adi_B
    Hello, I would like to ask for information or a method of calculating how many hours a 12v 200Ah battery connected to a 12V / 230V 800W / 1600W converter is loaded with continuous operation with a maximum power of 500W. And how many such discharge and charge cycles will such a battery last? The battery is new. I need to power a small shop and I do not have a very different solution. The generator is too loud. I know that there was a similar topic on the forum, but I think I made a mistake in the calculations, because when I counted according to the answers from that topic, it only lasts 2 hours.
  • #2 8790627
    ArturAVS
    Moderator
    Help: 2305
    Rate: 7869
    Let's count it roughly. 200Ah, i.e. 1h> 200A, 2h> 100A, 4h> 50A. 500W / 12V = 41.6 A. So it turns out about 4 hours. Not taking into account the losses.
    That's theoretically it comes out. Knowing the practice, I would count on 2 to 3 hours.
  • #3 8860953
    bigbith
    Rate: 19
    One should only pay attention whether the converter has no protection against battery discharge. Because then it will detach much faster. Preferably max. load the system and measure the actual current consumed - because you have not provided all the information about the DC / AC converter you are using and then, without exaggerating your calculations, use the proportions given by your colleague above.
    But without counting it, it should be able to withstand 3-3h20m without any problems
  • #4 8923264
    wnoto
    Help: 58
    Rate: 745
    If you use an acid battery, it should not be discharged to zero because then it loses its capacity quickly.
    Do you want to bring the battery to the store every day? (bring in, take out). Connected to the outside in the current frost, it will not have full capacity.
    Maybe if you gave what is hidden under the 500W, maybe we could find a different solution.
  • #5 19714902
    pionkajacek13
    The efficiency of the converter is still at stake? Solar panels are the best solution in my opinion.
    Moderated By krzysiek7:
    The author has not visited the forum for 11 years.
    3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
  • #6 19714932
    karolark
    Help: 702
    Rate: 2519
    What will be powered?
    Maybe the inverter can be omitted?
  • #7 19715422
    aksakal
    Tube devices specialist
    Help: 1673
    Rate: 3012
    12V 200Ah Battery Life with 12V/230V 800W/1600W Converter at 500W Load: Charge/Discharge Cycles 12V 200Ah Battery Life with 12V/230V 800W/1600W Converter at 500W Load: Charge/Discharge Cycles 12V 200Ah Battery Life with 12V/230V 800W/1600W Converter at 500W Load: Charge/Discharge Cycles
The discussion revolves around calculating the operational hours of a 12V 200Ah battery connected to a 12V/230V converter under a continuous load of 500W. Initial calculations suggest a theoretical runtime of approximately 4 hours, but practical estimates range from 2 to 3 hours due to inefficiencies and potential losses in the system. Participants emphasize the importance of considering the converter's efficiency and battery discharge protection, as well as the type of battery used, which should not be fully discharged to maintain its lifespan. Suggestions include measuring actual current consumption and exploring alternative power solutions, such as solar panels, to reduce reliance on the battery system.
