A friend is probably ridiculous, he is even in junior high ... P = U * I or I = P / U and the next time is the demand for electricity and not somehow in Ruthenian calculating the demand in amperes ... I suggest to know the law Ohm R = U / I and two Kirchhoff's laws, but by the way ... Tell me what kind of amplifier it is, because it feels like you count it wrong, notice that the amplifier never has 100% efficiency because it is practically impossible ...
If you have a fuse in the amplifier, next to the socket for the power supply cables of the amplifier, look at it and you will know how much electricity this baby can draw.
I do not have an amplifier yet, I am asking myself because I am going to buy it and have it at home for a while, and I need to drive it somehow. A 4ohm bass box with 300W RMS power will be attached to it.
Added after 44 [minutes]:
Is there any other way to power it at home besides the battery? Because I can see that computer power supplies do not have that many amps at 12V.
A transformer with a power of about 500W and a secondary voltage of about 9-10V, 4 rectifying diodes for 50A and some filtering capacitor. It seems to me that there is no need to insert a stabilizer, because then the price of the power supply will increase significantly. Powerful computer power supplies have several 12V lines and are not connected to a single source. Additionally, the power supply for the computer is a switching power supply. The amplifier works on it, but not as it should.
look on the net (you will probably also find on the electrode) some power supply diagram and choose the parameters there for yourself ... or maybe some battery charger .. but I doubt that you will find such a large ampere ...
The discussion centers around calculating the amperage required to drive a JBL GTO 3501E amplifier, which has an RMS power output of 225W at 4 Ohms and 360W at 2 Ohms. The formula for calculating amperes is provided as I = P / U, where P is power in watts and U is voltage in volts. It is suggested that for optimal performance, a current supply of 35-40A is recommended, considering the amplifier's maximum power draw. Additionally, alternatives for powering the amplifier at home are explored, including the use of a transformer and rectifying diodes, as well as the limitations of standard computer power supplies. AI summary based on the discussion. May contain errors.
