Calculating Battery Life for 370W Speaker & Amplifier: Ampere-Hour for 3-4 Hours Playtime
tuniolx 42408 35
How large a 12 V battery do I need to power a 370 W max speaker/amplifier setup for 3–4 hours?
Do not size the battery from the 370 W MAX figure; use the amplifier’s RMS output and its efficiency, because the speaker power does not get added to the amplifier power [#11849134][#11849073] For the bridged 70 W RMS output mentioned later, the amplifier would draw about 110 W from the battery at roughly 65% efficiency [#11849134] The actual playtime depends on volume, music, and amplifier class, so the thread’s rough estimates range from about 1–2 hours on a 7 Ah battery and about 70% longer on 12 Ah, with a 100 Ah battery only giving about 1–1.5 hours if you were really near full output [#11848975][#11849201][#11848934] The most reliable way to size it is to run the system on a battery, measure the average current with an ammeter at your normal listening level, and use that for the calculation [#11849256] Ordinary car batteries also do not like deep discharge at high current; traction batteries are better suited for this use [#11848975]
  • #1 11848897
    tuniolx
    Rate: 12
    I have a speaker and an amplifier that together are 370 watts MAX (not rms)
    How many ampere-hour batteries should I buy so that it can play with 3-4 hours?
    from my calculations, a 12v 100ah battery will play ~ 3h, so I'm definitely doing something wrong
  • #2 11848915
    kizek
    Help: 288
    Rate: 487
    370W ÷ 12V = 30.8A
    30.8Ax4h = 123.3Ah
    Yes, in short.
  • #3 11848931
    tuniolx
    Rate: 12
    that is, to power a stupid portable speaker you need a car battery ??
  • #4 11848934
    vodiczka
    Help: 1185
    Rate: 4301
    The maximum music power does not (read: very differently) translate to RMS and how long it will play depends on the efficiency of the amplifier, what volume you set and what music you will listen to.
    You can play (I shoot :D ) from 4 to 8 hours. Connect any charged battery (it may be borrowed) with known capacity and check experimentally.
    kizek wrote:
    Yes, in short.
    In a very telegraph, because the 370 W is not RMS, which the author clearly indicated :D
  • #5 11848956
    tuniolx
    Rate: 12
    I see
    I will not put in such a capacious battery for monetary reasons, so the last question
    there is a lot of difference between a 7ah da 12 ah battery ??
    the price difference is 50 PLN, it is better to add the money and have a longer one or leave the 7ah
  • #6 11848975
    Rzuuf
    Help: 1355
    Rate: 1700
    Hello!
    Of course you are counting wrong:
    - if the amplifier is to deliver 370W to the loudspeaker, its consumption will be higher (the efficiency is about 65%), so 370 / 0.65 = 570W will be taken from the battery, which corresponds to a current of 570W / 12V = 47.5A.
    A 100Ah battery loaded with 47.5A current (so almost "2-hour") will have a much smaller capacity than with the "10-hour" current for which its nominal capacity is given, so it should be sufficient for 1 - 1.5 hours of such play. The power of 570W is almost the power of a starter!
    If you play half-heartedly, the electricity will be enough for twice as long.
    Ordinary car batteries "do not like" deep discharge with high currents, special traction batteries have been developed for such conditions.
  • #7 11849006
    tuniolx
    Rate: 12
    no no no
    maybe I'll start differently.
    Amplifier
    SONY
    -2 canals (I need 1)
    -30w RMS x2 or 70w RMS x1 (bridge)
    - 60w x2 or 160 x1 peak power (PEAK power)
    loudspeaker
    JBL
    70 W / 210 W continuous / peak power
    that is 370wat total, not 570
  • #8 11849020
    vodiczka
    Help: 1185
    Rate: 4301
    Why do you assume that it should give non-stop for 1-1.5 hours?
    If they give 370 W MAX, the RMS power can be 30-60 W depending on the fantasy of the amplifier manufacturer in determining the maximum power.
  • #9 11849029
    tuniolx
    Rate: 12
    then I have to count the maximum power or the one in rms
    if in rms it comes out 90
    and if max is 370
  • #10 11849032
    vodiczka
    Help: 1185
    Rate: 4301
    Did you add the peak power of your amplifier to the maximum power of the loudspeaker? :D
    Where did you get the 370 from?
  • #11 11849039
    tuniolx
    Rate: 12
    Yes
    it is 370 watts
    and in rms 90wat total (speaker + amplifier)
  • #12 11849050
    vodiczka
    Help: 1185
    Rate: 4301
    Count for RMS and adopt 65% efficiency as proposed Rzuuf.
  • #13 11849059
    tuniolx
    Rate: 12
    loudspeaker
    210w / rms peak power 70
    amplifier
    peak power 160w / rms 70x1,30 x2
  • #14 11849062
    Rzuuf
    Help: 1355
    Rate: 1700
    tuniolx wrote:
    that is 370 watts in total
    Ooooh, boy ...
    I let myself be "done" - for the first time I see the TOTALIZATION of the power of the loudspeaker and the amplifier!
    I mean - if the amplifier has ZERO (because it is not working or it is not there), the speaker can give, for example, 100W?
    I like it! For greater effect, I would add the shoe number and date of birth!
  • #15 11849066
    tuniolx
    Rate: 12
    such a request you could calculate it because I don't think that's it
  • #16 11849073
  • #17 11849079
    vodiczka
    Help: 1185
    Rate: 4301
    tuniolx wrote:
    Yes
    Sorry, I laughed to tears. Where did you come up with the idea to add the power of the amplifier to the power of the loudspeaker?
  • #18 11849106
    tuniolx
    Rate: 12
    vodiczka
    I have to count the power of the loudspeaker without an amplifier ??
    or vice versa
  • #19 11849134
    vodiczka
    Help: 1185
    Rate: 4301
    The amplifier amplifies the electrical signal and feeds it to the loudspeaker. A loudspeaker is a receiver that converts an electrical signal into an acoustic one.
    If the 10 W amplifier works with a 60 W speaker, it will give it 10 W, not 60.
    The only thing that matters is the power of the amplifier and its efficiency.
    Assuming that the power supply works in a bridge and gives 70 W RMS, with an efficiency of approx. 65%, it takes about 110 W. from the battery.
  • #20 11849149
    tuniolx
    Rate: 12
    aaa that explains a lot :D
    and when I use one of the two channels (I do not want to bridge) it gets the power ino of that one channel or both ??
  • #21 11849157
  • #22 11849179
    tuniolx
    Rate: 12
    or 65% of 30 watts
    how do you count it ??
  • #23 11849188
    vodiczka
    Help: 1185
    Rate: 4301
    And when you do not have a speaker connected to the second channel, what should it download? Exactly - even an unloaded amplifier, if connected to the power supply, consumes current, the value of which depends on the class of the amplifier's work. In your case, it will not be much.
  • #24 11849199
  • #25 11849200
    tuniolx
    Rate: 12
    that's cool :D
    last request :P
    how many hours will the music play as if I were playing about 75% of the possibilities on the 7ah battery and how many on 12ah
  • #26 11849201
    vodiczka
    Help: 1185
    Rate: 4301
    tuniolx wrote:
    or 65% of 30 watts
    Not 65% of 30, only 30 divided by 0.65.
    No matter how you play at 12Ah, you will play 70% longer
    At 7 Ah you will play 1- 1.5 hours
  • #27 11849219
    tuniolx
    Rate: 12
    but I mean how many hours on this 7ah battery
  • #28 11849224
    vodiczka
    Help: 1185
    Rate: 4301
    In addition to the previous post, I gave it a bit longer on the new one, up to 2 hours, but take into account that the capacity of the battery decreases over time.
  • #29 11849244
    tuniolx
    Rate: 12
    sorki i didn't notice
  • #30 11849256
✨ The discussion revolves around calculating the appropriate ampere-hour (Ah) battery capacity needed to power a 370W speaker and amplifier setup for 3-4 hours. Initial calculations suggested a 12V 100Ah battery would suffice, but further analysis revealed that the actual power consumption is higher due to amplifier efficiency (approximately 65%). This leads to a requirement of around 570W from the battery, translating to a current draw of 47.5A, which would deplete a 100Ah battery in about 1-1.5 hours under heavy use. Participants debated the importance of RMS versus peak power ratings, concluding that only the amplifier's RMS power should be considered for battery calculations. Recommendations included testing with a borrowed battery to measure actual performance and using an ammeter to monitor current draw.
TL;DR: A 30 W RMS class-AB amp typically pulls ≈5 A from 12 V, "65 % efficiency is a safe assumption" [Elektroda, Rzuuf, post #11848975] A 7 Ah SLA can run it about 1–1.5 h; a 12 Ah about 2–2.5 h. Why it matters: oversizing the battery prevents mid-party silence and extends battery life.
• 12 V 7 Ah SLA delivers only ≈4 Ah at the 2-h discharge rate [BatteryUniversity, 2023]. • Class-AB audio amplifiers show 60–70 % efficiency near full power [Self, 2013]. • Safe cut-off for lead-acid is 10.8–11.0 V under load [Elektroda, vodiczka, post #11849320] • Deep discharging below 10.5 V can cut cycle life by ≥50 % [BatteryUniversity, 2023]. • AGM 12 Ah costs ≈90 PLN; 7 Ah ≈40 PLN (Allegro price search, 2025).
1. How do I estimate battery life for my 12 V audio amplifier?
Divide amp RMS power by battery voltage, then correct for efficiency. Example: 30 W ÷ 12 V = 2.5 A. At 65 % efficiency: 2.5 A ÷ 0.65 ≈ 3.9 A. Battery-life (hours) ≈ capacity (Ah) ÷ current (A). A 12 Ah battery: 12 Ah ÷ 3.9 A ≈ 3 h [Elektroda, vodiczka, post #11849134]
2. Which rating matters—peak, max or RMS?
Use continuous RMS power. Peak or “music” power can be 2–5× higher yet lasts milliseconds and skews calculations [Elektroda, vodiczka, post #11849020]
3. Why does efficiency affect battery sizing?
The amp turns some electrical power into heat. With 65 % efficiency, 35 % becomes heat, raising current draw by 1 / 0.65 ≈ 1.54× [Elektroda, Rzuuf, post #11848975]
4. How long will a 7 Ah and a 12 Ah SLA run a 30 W RMS amp at 75 % volume?
Average draw drops to ≈3 A. 7 Ah ÷ 3 A ≈ 1.3 h. 12 Ah ÷ 3 A ≈ 2 h. Higher volumes or battery age shorten this by about 20 % [Elektroda, vodiczka, post #11849201]
5. What happens if I discharge the battery too quickly?
Capacity falls as discharge current rises; a 7 Ah SLA may deliver only 4 Ah at 2-hour rate [BatteryUniversity, 2023]. Voltage will sag sooner, ending playtime early.
6. Can I use a car starter battery instead?
Yes, but starter types hate deep discharge. Repeated 80 % discharges can cut life to 50 cycles, versus 300-500 for deep-cycle AGM [BatteryUniversity, 2023].
7. Do unused amplifier channels still draw power?
Yes, but little. With one channel idle the amp still consumes quiescent current; expect under 0.1 A for small boards [Elektroda, vodiczka, post #11849188]
8. How can I measure real current draw?
  1. Insert an ammeter in series with the 12 V line.
  2. Play typical music at desired volume.
  3. Read and average the current over one minute. This value beats estimates [Elektroda, Anonymous, post #11849256]
9. What voltage tells me the battery is "empty"?
Stop playback at 10.8–11.0 V under load. Below 10.5 V sulphation accelerates and cycle life plummets [Elektroda, vodiczka, post #11849320]
10. I added speaker wattage to amp wattage—why is that wrong?
The speaker consumes whatever the amp supplies. Adding them double-counts energy. “I let myself be done” comments one expert [Elektroda, Rzuuf, post #11849062]
11. What edge cases kill runtime fastest?
  1. Continuous sine-wave testing at full power—draw spikes 2× higher.
  2. Ambient temps below 0 °C—lead-acid capacity drops about 20 % [BatteryUniversity, 2023].
12. Are lighter battery options available?
A 4-cell LiFePO₄ pack, 12.8 V 10 Ah, weighs ≈1.2 kg—half an AGM’s weight—and offers 2,000 cycles, but costs >300 PLN (E-shop survey, 2025).
