Electronics Safety Forum: Discuss Fuse Types, Symbols & Applications (B10, C10, K10)
Pisaller 90331 6
  • #1 661828
    Pisaller
    I have met with "S" type fuses labeled npS261 B10, or S261 K16 etc. I don't know what the symbols B, K, C, G and maybe some others mean. I request information.
  • #2 662025
    G.Matras
    Rate: 14
    Hi
    These letters indicate the characteristics of a given fuse B - fast blow fuse C - slow blow fuse etc.
    It is simply for a variety of uses
    For example, D or E type fuses are used for the engine because they have a heavy start. There are special boards for this
    and the numbers after the letter indicate the rated current.
    that is:
    S191 B10
    Single glass fuse with a current of 10 Amps
    S193 C10
    Tripple time fuse 10 amps
    GM
  • #3 663328
    Panda02
    Level 32  
    Help: 158
    Rate: 118
    Is it possible to ask for a link to the page with these markings? Thanks in advance.
  • #4 663944
    rt69
    Buddy, get a catalog of any manufacturer, e.g. Fael, and there for each range of fuses are presented the switching characteristics, i.e. In / t
  • #5 664063
    Raaf
    Help: 37
    Rate: 77
    The most common stores and wholesalers include: ETI, FAEL. So: http://www.legrand.pl/ http://www.etipolam.com.pl/index1.htm
    The characteristics are selected depending on the protected circuit.
    Installations - B, C motors, D transformers, Rectifier systems A.
    There is no name fast, slow, because how to call eg S 303 d32 - very, very slow? :)
    Additionally:
    S30x - Rated short-circuit capacity 6000 A.
    S31x - Rated short-circuit capacity 10,000 A.
    S32x - Miniature circuit breakers with high short-circuit capacity of 25,000 A.
    the third digit on the circuit breaker (x) indicates the number of modules: 1,2,3,4.
    At the end of the markings - the current value.
    The matter of selection is therefore based on the foundations of an electric vocational school, supported by a catalog, for example of the companies listed above.
  • B, C, and D breaker trip multipliers explained
    #6 4837499
    piotrus110
    Rate: 8
    explain that a colleague of the basics of power engineering and fuse characteristics. The type B fuse can withstand a momentary increase in current exceeding a maximum of 5 times the rated value of the cut-off current, c: 10 times, d: 20 times, etc. Of course, this is not a very accurate value because the cut-off current depends on many factors, e.g. ambient temperature etc. The time of switching off each fuse must not exceed 0.2 sec (for voltage 230v and increased humidity) so that the short-circuit current does not exceed the safe voltage - in this case 50V
    example: the B16 type fuse can withstand a temporary current of up to 80A, and in the event of an excessive current of approx. 1.45, the switch-off current should operate after approx. 1 hour
  • Correcting B, C, D and E breaker applications
    #7 4841483
    Madrik
    Help: 627
    Rate: 1193
    G.Matras wrote:
    Hi
    For example, type D or E fuses are used for the engine because they have a heavy start.
    GM
    And since when is E for engines? :D Unfortunately, it is not the alphabet and the degree of delay that does not increase with the letter.
    E is faster than B and is used to protect electronic circuits. Although this type of overcapacity is very rare.
    I personally saw this type of "eski" maybe twice in my life.
    The engines are B (light starting and low power), C - most and D - heavy starting.
    C is also often used in switchgear protection.
The discussion centers on the characteristics and applications of various types of fuses, specifically those labeled with letters such as B, C, and D. The letters indicate the fuse's response to overcurrent: B for fast blow, C for slow blow, and D for very slow blow, with the numbers indicating the rated current. The conversation also touches on the importance of selecting the appropriate fuse type based on the protected circuit, with references to specific manufacturers like Fael and ETI. Additionally, the discussion highlights the current ratings and the ability of different fuse types to withstand momentary current surges, emphasizing the need for proper selection based on electrical engineering principles.
