Distinguishing Fast, Time-Lag (Slow) Fuses & Time-Delayed Fuses with Letter T
TT 115812 8
  • #1 3450762
    TT
    Hello, I have a question, how to distinguish between fast and slow fuses? Are there any time-delayed ones where the rated current is preceded by the letter T.
    If we do not know whether a quick or slow fuse is to be used in the device, what fuse we use.
  • #2 3450837
    Arnold_S.
    Help: 49
    Rate: 86
    In brief:
    T - delayed,
    F - fast,
    and there are more types and markings.
    Details in articles from EdW.
    http://www.edw.com.pl/pdf/k01/62_099.pdf " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.edw.com.pl/pdf/k01/62_099.pdf part 1
    http://www.edw.com.pl/pdf/k01/63_102.pdf " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.edw.com.pl/pdf/k01/63_102.pdf part 2
    http://www.edw.com.pl/pdf/k01/64_102.pdf " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.edw.com.pl/pdf/k01/64_102.pdf part 3
    There is not enough space to write about it here.
    PS
    Can't you find these things yourself?
    You do not know about the existence of www.google.pl?
  • #3 3450961
    Quarz
    Help: 1646
    Rate: 629
    power fuses are appropriately marked, the delayed ones have a stylized image of a turtle, although they are hardly used in households.
    Whereas electronic fuses; tubular glass (of which there are several sizes) are divided into four groups;
    - ultra fast,
    - quick,
    - standard,
    - delayed.
    The easiest way (seeing the wire through the glass tube) is to distinguish a slow-blow fuse, because it has a ball (loop) in the center, which serves as an accumulator of thermal energy.
    Standard and fast fuses are often indistinguishable in this way, because in both cases it is just a simple wire, but the speed of operation depends on the diameter of the wire and the material it is made of for a given rated current.
    In addition, the quick-action fuses sometimes have a spring that tensions the wire, the purpose of which is to accelerate the breaking of the circuit after the wire burns out (especially at lower rated currents).
    Ultra-fast fuses have a wire covered with quartz sand, whose task is to quickly extinguish the electric arc created after the wire burns out.
    The only sure way is the description on the fuse, although there is a mess in this matter, because the marking system has been changed several times over the years, and sometimes you can find a fuse and a sixty-year-old ... :D
    Besides, Europe used its own (and it happened that the manufacturer meant the fuse's overload integral in a different way - a parameter characteristic for wire-fuse fuses), Uncle Sam used his own, and oblique eyes also his own designations.
    I also know if I do not know the characteristics of the transient state of current consumption when switching on a given device.
    It is not a simple matter; selection of the correct value and type of fuse characteristic.
    Therefore, it is a separate (and extensive) branch of electrical engineering called protection of electrical apparatus.
    I will only add that one of the world's leading companies producing fuses offers more than twenty types of fuses for a given rated value for the breaking voltage of 250V ~ (RMS).
  • #4 3451425
    TT
    Thank you for your help. Of course I did a google search, there are plenty of fuse vendor sites out there, but I couldn't find any good article about them. Maybe I was looking poorly, if so, I am sorry. Qarz wrote: Besides, quick fuses sometimes have a spring that stretches the wire, the purpose of which is to accelerate the breaking of the circuit after the wire burns out (especially at lower rated currents).
    In the article from Elektroniki dla życia, they write that the delayed ones sometimes have a spring.
  • #5 3451654
    Quarz
    Help: 1646
    Rate: 629
    TT wrote:
    Quarz wrote: Besides, the quick fuses sometimes have a spring that stretches the wire, the purpose of which is to accelerate the breaking of the circuit after the wire burns out (especially at lower rated currents).
    but this only proves the diversity of solutions and there is no contradiction, because it all depends on what wire (current resistance) the spring tightens.
    In slow-blow fuses de facto it is quite thick wire together with the spring, and the main slow-blow fuse is a solder connecting the spring with the wire, while in fast ones; the second wire is definitely thinner and welded to the spring.
  • #6 3451701
    Arnold_S.
    Help: 49
    Rate: 86
    Because it's true.
    T - they can have a spring, and they can also be in the sand ...
  • #7 3452728
    TT
    Thank you for your help. However, the article in EdW shows that it is often possible to predict what type of fuse to use (usually a delayed fuse in the device's network circuit, and a fast one at the output of the power supply).
    I still have a question, what system of markings was used by the USSR? I have a lot of Soviet fuses with the letter T, they are probably delayed, but I prefer to be sure, because, as you know, many markings have completely different markings.
  • #8 14564546
    zdzisław197
    Rate: 21
    What is the fuse marked M2 / 250G, is not made of glass and there is an ESKA inscription on the sides of a white opaque tube?
    Moderated By trymer01:
    Regulations, point 3.1.19
  • #9 17204560
    misiek1111
    Level 37  
    Help: 325
    Rate: 1097
    To the 20mm tubular collection, you must also add a safety box. very slow. On the photo TT10mA:
The discussion focuses on distinguishing between fast fuses, slow (time-lag) fuses, and time-delayed fuses marked with the letter "T." Fast fuses (F) react quickly to overcurrent, while slow fuses (T) are designed to withstand temporary overloads. Delayed fuses may feature a spring mechanism or a thermal accumulator, such as a ball or loop, to manage current flow. The conversation also touches on the identification of fuses based on their construction, such as the presence of quartz sand in ultra-fast fuses. Additionally, there is a query regarding Soviet fuse markings, specifically those with the letter "T," which are presumed to indicate delayed fuses. The importance of selecting the appropriate fuse type for specific applications is emphasized, with recommendations for using delayed fuses in network circuits and fast fuses at power supply outputs.
