How to Fully Erase Windows & Clean Disk From Remnants: Post-Installation Dual Boot Issues
27070 6
  • #1 7112018
  • #2 7112029
    Xylometazolin!
    Help: 264
    Rate: 858
    Formatting a drive?
  • #3 7112036
  • #4 7112052
    cyberdar
    Help: 161
    Rate: 73
    It's best if you boot your computer from the Windows CD and read what it says there. And it will write during startup, among other things, that there is already windows on the disk. From this moment, read what he writes because you can choose a new installation, the disk on which the system is to be and formatting (full or quick).
  • #5 7112056
    Matuzalem
    Help: 1653
    Rate: 1101
    Are you, tomek40, sure that these are "leftovers of the old", and not just redundant path in boot.ini? - Start with this item.
    Edit the file and remove the redundant entry: My Computer - Advanced - Startup and Recovery - Startup - Edit.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #6 7112076
    DeDua
    Help: 30
    Rate: 26
    When installing a new system, you always have the option to install on the current disk, partitions, or to create new partitions, there is also the option of a full or quick format.
    On the active partition, usually C, there is a boot.ini file (for xp, not for vista, win7) it should be edited in such a way that it contains only the system you are interested in:
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
    In your case there will be two entries in this line, therefore you have a system select menu, delete that entry which system you don't want.
    If you have vista, win7 you need to use a special program, because from what I remember there is no such editing option as in earlier systems.
  • #7 7112334
To completely erase remnants of a previous Windows installation and resolve dual boot issues, users are advised to boot from the Windows installation CD. During the installation process, options for formatting the disk (full or quick) and selecting the installation partition will be presented. If remnants persist, it may be due to entries in the boot.ini file, which can be edited to remove unwanted system entries. For Windows XP, the boot.ini file can be modified to reflect only the desired operating system. For newer versions like Vista or Windows 7, a special program may be required to manage boot entries.
