Word 2007: Creating Independent Columns for English and Polish Texts Using 1x2 Table
VVisnia 31967 0
  • #1 7659641
    VVisnia
    Help: 47
    Rate: 26
    Hello everyone
    I need to put two separate texts next to each other in two columns in one document. On the left, I want to put the text of the act in English and in the next column in Polish. The problem is that the basic column setting in a word works so that when text reaches the end of a column, it continues from the top in the next column.
    However, I need to change it so that one text runs through one column to the very end, and the other one runs separately to the other, as if in a separate, independent document.
    If anyone has a concept to implement it in word 2003, I'd love to hear it. I was messing around with 2003 and I will install it for the purposes of this process.
    thanks in advance
    Added after 11 [minutes]:
    Well, it was enough to make an effort and move the brain and the solution appeared by itself. Just create a 1x2 table and that's it. Stretch out appropriately and paste as desired. At most, the table frame should be removed later.
    So, subject to remove unless mod deems it useful for posterity.
