How to Determine Wi-Fi Capability on a Toshiba Satellite L30-10W (PSL33L-03J035PL) Laptop
rafik108 110632 14
How can I check whether a Toshiba Satellite L30-10W laptop has Wi‑Fi, and if it doesn’t, how can I get wireless internet without a cable?
Check Device Manager → Network adapters; if the Wi‑Fi card is present it should appear there, and it may also be disabled by the laptop’s wireless/antenna switch on the casing [#7688647] If the card is missing or the driver is not installed, this model can use one of several wireless chipsets (Intel, Realtek, or Atheros), so download the Toshiba wireless LAN driver package for the correct OS and try updating the driver with each one until Windows accepts the right match [#7688931][#7689163] If there is no internal Wi‑Fi card at all, you can still get wireless internet by adding a USB Wi‑Fi adapter or a PCMCIA Wi‑Fi card [#7688647]
  • #1 7688544
    rafik108
    Help: 7
    Rate: 100
    Hello colleagues.
    I am not a computer specialist (I think you can already see it after the question). I have internet at home, I connected the router and I have internet via radio, I secured this router according to the instructions, and it's ok. I wanted to see if someone else can break into me, a friend came with his laptop (Toshiba Satellite L30-10W Model NO PSL33L- 03J035PL) and it cannot detect any available networks (there is no this little computer at the bottom), I heard that it may not have a Wi-Fi device, I don't know exactly how to check it. And therefore, I have a question how to check if he has Wi-Fi, and if not, can he somehow get internet without a cable?
    Thank you in advance and best regards
  • #2 7688601
    kostian
    Help: 51
    Rate: 87
    Device manager - look for WiFi cards.
    Maybe - how to buy a wireless card (if it is actually not in the laptop).
  • #3 7688647
    phrozen
    Help: 8
    Rate: 128
    To check if it has a wifi card:
    Start -> Control Panel -> System -> Hardware -> Device Manager->
    tab Network cards and look there if there is an item that has "Wifi" in the name.
    If it is, it means it has a network card, but it may be disabled.
    To turn it on, you need to turn it on using the button on the laptop casing - look for the button with the antenna on it.
    After turning it on, the card should easily start looking for wireless networks.
    If there is no physical card in the laptop, you would have to buy a WiFi card for USB (PLN 50 and up) or for PCMCIA (about PLN 70).
  • #4 7688695
    rafik108
    Help: 7
    Rate: 100
    I don't think there is, but when I look for my laptop, I have this:
    "Network cards
    - Atheros AR5007EG Wireless Network Adapter
    - Broadcom NetLink (TM) Gigabit Ethernet
    - Network card1394 "
    and for him it is like this:
    "Network cards
    -Realtek RTL8139 / 810x Family Fast Ethernet NIC "
    neither for me nor for him nothing is written about Wi Fi and I still have wireless internet, or maybe one of these cards means that it is Wi Fi? Or maybe something needs to be installed? There is a switch with an antenna on the housing and it is on and nothing.
  • #6 7688811
    kostian
    Help: 51
    Rate: 87
    You have a wireless:
    this is this: Atheros AR5007EG Wireless Network Adapter
    He's not visible in the manager - are there any question marks?
    Quickly checked on the Internet - it should have a wireless card, if it is missing, it is turned off or there are no drivers.
  • #7 7688887
    rafik108
    Help: 7
    Rate: 100
    Well, I can see that they are:
    other devices
    -? Ethernet controller
    -? Modem Device on Hight Defintion Audio Bus
    SCSI and RAID controllers
    - AAK52D8W IDE Controller
    -? NERO IMAGEDRVE SCSI Controller
    I will try to install a driver, I do not know too much what will come up with something. And something will happen if I reinstall all the drivers?
  • #8 7688931
    kostian
    Help: 51
    Rate: 87
    The Ethernet controller is just the missing WiFi card.
    Do not install all of them: go to the Toshiba website, driver, download - select the laptop model and download the headsets to the WiFi card (Wirelles Network Adapter).
    Here you are ready - choose only the system;
    http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
  • #9 7689012
    rafik108
    Help: 7
    Rate: 100
    there is no "Wirelles Network Adapter" are like this:
    - Wireless Lan Client Manager
    - Wireless Lan Driver
    is one of these?
  • #10 7689047
    kostian
    Help: 51
    Rate: 87
    Wireless Lan Driver
  • #11 7689111
    rafik108
    Help: 7
    Rate: 100
    And I'm green again, all the others are getting married normally and at the same time "Wireless Lan Driver" you have to choose something and I don't know what? Can you help
  • #12 7689126
    kostian
    Help: 51
    Rate: 87
    I will be happy to help, but I don't know what to choose additionally - what system do you have?
  • #13 7689157
    rafik108
    Help: 7
    Rate: 100
    Toshiba satellite L30-10W Model NO PSL 33E-03J035PL XP operating system. I'm waiting for tips.
    kostian
    Help: 51
    Rate: 87
    I think I understand what's going on - there were apparently 3 types of wireless cards installed in these laptops; Intel, Realtek and Atheros I do not know what is yours, but download each one in turn and then update the driver in the device manager and indicate each of the downloaded drivers in turn (of course, unpack the previously downloaded files to disk) - the system will choose the right one, will not install You get another company because it won't fit.
    I bet on Atheros.
  • #15 7689390
    rafik108
    Help: 7
    Rate: 100
    Thanks, I had a little trouble but I advised.
    Thanks again for the advice.
The discussion revolves around determining the Wi-Fi capability of a Toshiba Satellite L30-10W (PSL33L-03J035PL) laptop. The user initially inquires about checking for a Wi-Fi card, as their friend's laptop cannot detect available networks. Responses suggest checking the Device Manager for network cards, specifically looking for entries that include "Wi-Fi." It is noted that the laptop may have a wireless card (Atheros AR5007EG) that could be disabled or lacking drivers. Users recommend enabling the card via a physical switch and downloading the appropriate drivers from the Toshiba website. The conversation concludes with the user successfully installing the necessary drivers after some troubleshooting.
