Can YKY 4x16mm² Cable Be Buried Underground from ZKP to Main Switchboard?
malutkipio 46378 12
Can a YKY 4x16 mm² cable be joined underground between the ZKP and the house main switchboard, and how should that joint be made?
Yes — the cable can be joined underground, but it must be done as a proper cable joint/muff, not with a simple twist. A common solution is a repair kit with heat-shrink sleeves with glue, or crimp connectors in a sealed housing that is then poured with special resin [#8194142] [#8194200] [#8194502] For 16 mm² conductors, you need the right tools: a press for crimp lugs and, for heat-shrink sleeves, a good heat gun or even a gas burner if needed [#8194502] [#8194583] Self-vulcanizing tape was mentioned as an option, but the thread suggests heat-shrink repair kits are the better practical choice for this size of cable [#8194502] [#8194611] If you use a proper connector, leave a little spare cable at the joint and note its location [#8194502]
  • #1 8194119
    malutkipio
    Can YKY 4x16mm? cable be connected in the ground? how is it how is it a cable from ZKP to the main switchboard in the house
  • #2 8194142
    zdzisiek1979
    Help: 561
    Rate: 1254
    This is called a cable joint.
    There are various solutions, starting from crimping the connector on the conductor and securing it with special heat-shrinkable sleeves, these are whole sets, or there are clamps with screws, and after twisting the cables, the whole thing is closed in the housing and poured with a special resin.
    Added after 13 [minutes]:
    Here are videos of how it is done but in the technique of pouring resins
    http://www.youtube.com/watch?v=7XVnHCMGou0&feature=related
    http://www.youtube.com/watch?v=2zzTnF2zZak&feature=related
    http://www.youtube.com/watch?v=RofP1_AovK0&feature=related
  • #3 8194200
    retrofood
    Help: 1140
    Rate: 4797
    There is no need to play with muffs. A cable repair kit (the first one, i.e. jackets) does the trick.
  • #4 8194291
    12robert12
    Help: 134
    Rate: 179
    heat-shrinkable tubing but with glue.
  • #5 8194296
    retrofood
    Help: 1140
    Rate: 4797
    The repair kit shirts are there always with glue.
  • #6 8194308
    HeSz
    Electrician specialist
    Help: 97
    Rate: 198
    What is the difference between a "repair kit" and a "muff"? In addition to naming!
    Regards
  • #7 8194502
    zdzisiek1979
    Help: 561
    Rate: 1254
    I misunderstood something a bit and the text went to the trash can, maybe now it will be fine :D
    There is also a self-vulcanizing tape, but since it is 16mm2, it would be difficult to twist the cores together.
    It is best to go to a good store or electrical wholesaler and tell about your problem, they will definitely do something about it, but you need to have something to do it because if you want to use crimp connectors, you must have a press to tighten when it comes to heat-shrinkable sleeves with glue, you need a good heat gun or gas burner.
    In addition, you need to make a bit of spare cable at the muff, just in case there is no surprise and no fish face in the future. :D and remember where it was made.
  • #8 8194583
    Miwhoo
    Electric installations specialist
    Help: 128
    Rate: 316
    A repair kit with heat shrink tubes is OK, but sometimes a heat gun is not enough and you have to have a gas burner, and this is a bit higher driving school, not to burn ... Besides, you need a good crimping tool for ferrules, unless you get twisted fittings .. .
    A set for 4x1.5mm2 cost about PLN 15 recently :) The kit includes everything you need for assembly, except a heat gun and a press tool
  • #9 8194611
    Siergiej_S
    Vulcanizing tape was good 30 years ago, now I won't say what you can wrap it with, it will go away with time anyway. And the spare is not needed if the connector is properly made, nothing can happen there. The heat gun is sufficient to heat shrink tubes, even much thicker than 16.
  • #10 8194695
    retrofood
    Help: 1140
    Rate: 4797
    Is it not enough?
  • #12 8197871
    Enpro
    Help: 39
    Rate: 97
    [quote = "Siergiej_S"] Vulcanizing tape was good 30 years ago, now I won't say what you can wrap it, and it will go away with time.
    I would advise you to think first before you write something because you have no idea what you are writing about, such tapes are used and will be used for a long time, but you can see that you have never seen a repair kit for a medium voltage cable
The discussion revolves around the proper methods for connecting a YKY 4x16mm² cable underground, specifically from a ZKP to a main switchboard. Various techniques for cable joints are highlighted, including the use of crimp connectors, heat-shrinkable sleeves, and repair kits. Participants emphasize the importance of using quality materials such as heat-shrink tubing with glue and self-vulcanizing tape, while also noting the necessity of appropriate tools like heat guns and crimping tools. The conversation includes links to instructional videos and product examples, underscoring the need for proper installation to ensure reliability and safety.
