Automatically sum the same cell across multiple sheets in Excel, including new sheets
pawel_tel 30575 9
How can I automatically sum the same cell from multiple Excel sheets, including any new sheet added later?
Use a 3D sum formula with two “marker” sheets around the sheets you want to include, for example `=SUM(a:b!A1)` [#8217955] Put the sheets in the tab order as `a, Sheet1, Sheet2, ..., b`, and the formula will sum cell `A1` from every sheet between `a` and `b`, inclusive [#8217955] If you insert a new worksheet anywhere between those two tabs, it will be included automatically [#8217955] The key is the sheet order on the tab bar, not the sheet names themselves [#8244967]
  • #1 8213603
    pawel_tel
    Rate: 10
    Hello, I have such a case.
    I need to know how scratch automatic sum of a given cell from all sheets.
    I mean, if I already have Sheet1, Sheet2, Sheet3 and I have one cell totaled in another sheet, and I will add another sheet to keep it totaling there?
  • #2 8216989
    walek33
    Help: 132
    Rate: 81
    Rather, nothing happens in nature. If you want to automate certain activities, use a macro.
  • #3 8217955
    meriadook
    Rate: 10
    It is enough to put e.g. the formula = sum (a: b! A1), where a and b are the names of the sheets limiting the ones you want to sum. You can name them whatever you want.
    Sheets in turn:
    a, Sheet1, Sheet2, ...... SheetN, b
    This formula sums cells A1 in worksheets a to b inclusive, if you now insert some extra worksheet between a and b, it will also be summed.
  • #4 8223792
    adamas_nt
    Help: 1508
    Rate: 659
    meriadook wrote:
    Sheets in turn:
    Rather, this will result in an argument error ...
    As a colleague mentioned fight33 there remains a macro or user function using a loop Eg
    For i = 1 To Sheets.Count
    In the case of user functions, Excel does not recalculate the worksheet automatically, but they can be forced eg at an event Worksheet_Activate .
  • #5 8243403
    meriadook
    Rate: 10
    and have you tried my method at least? because I can see that it is not;] and it is simpler than macros
  • #6 8244967
    adamas_nt
    Help: 1508
    Rate: 659
    :arrow: meriadook Indeed. I tested it and it works. You forgot to add that the names do not matter, but the key is to arrange the tabs on the sheet bar. I return my honor and congratulate you on your knowledge.
  • #7 9475980
    leszekkpl
    Rate: 20
    And is it possible to sum sheets in Excel, but the sheets would be in different Excel files and they would also have different names.
    For example, I have xls files called data1.xls in it 100 sheets, another file called data2.xls in it 100 sheets, is it possible to sum up all these sheets in a separate file in excel (200 in total)?
    These worksheets are named with numbers from 1 to 100.
    I will add that the location of these files is:
    C: \ Documents and Settings \ office \ Pulpit \ data1.xls
    C: \ Documents and Settings \ office \ Pulpit \ dane2.xls
    Thank you in advance for your answer.
  • #8 9476203
    walek33
    Help: 132
    Rate: 81
    If there are only two files, it is enough to modify the colleague's formula meriadook .
    =SUMA([Zeszyt1]Arkusz1:Arkusz3!A1;[Zeszyt2]Arkusz1:Arkusz3!A1)
  • #9 9476596
    leszekkpl
    Rate: 20
    and anyone already used such a formula, sum between two excel files?
    Added after 29 [minutes]:
    I managed to do it if someone needed, then below is this formula:
    = SUM ('C: \ Documents and Settings \ office \ Pulpit \ [dane1.xlsx] 1'! A1) + SUM ('C: \ Documents and Settings \ office \ Pulpit \ [dane2.xlsx] 1'! A1)
    it sums up the first sheets in two Excel files, with one A1 cell, but the range can be modified as needed.
    It is also known that everyone can have a different location, different file and sheet names.
  • #10 9490647
    walek33
    Help: 132
    Rate: 81
    :arrow: leszekkpl
    And why in your example SUM() ? You will achieve the same by:
    ='C:\Documents and Settings\biuro\Pulpit\[dane1.xlsx]1'!A1+'C:\Documents and Settings\biuro\Pulpit\[dane2.xlsx]1'!A1
The discussion revolves around summing values from multiple Excel sheets, specifically how to automatically sum a cell across various sheets, including newly added ones. A suggested formula is =SUM(Sheet1:SheetN!A1), which sums cell A1 from all sheets between Sheet1 and SheetN. Users also discuss the use of macros for more complex scenarios, particularly when dealing with sheets across different Excel files. For summing cells from different files, the formula =SUM('[data1.xlsx]Sheet1'!A1, '[data2.xlsx]Sheet1'!A1) is provided, allowing users to sum cells from specified sheets in separate files.
