How is the number of networks, hosts and network type determined over IP?
shel82 66740 13
How do I determine the number of subnets, usable hosts, and whether an IP address is a network, broadcast, or host address from the IP and mask?
With a /27 mask, the last octet is 11100000, so there are 3 subnet bits and 5 host bits: 2^3 = 8 subnets, 2^5 = 32 addresses per subnet, and 30 usable hosts after excluding the network and broadcast addresses [#8225374][#8215870] For 192.168.50.0/27, the subnet network addresses are 192.168.50.0, .32, .64, .96, .128, .160, .192, and .224, with the host ranges in between [#8225374] To find the address type, AND the IP with the mask to get the network address; if the host bits are all 0 it is a network address, if they are all 1 it is a broadcast address, and otherwise it is a host address [#8225284] For example, 192.168.17.111/28 AND 255.255.255.240 gives 192.168.17.96 as the network address, and 192.168.17.111 is the broadcast address for that subnet [#8225284]
  • #1 8215459
    shel82
    Rate: 116
    Hello, can someone describe with a simple and understandable example how, knowing the IP address and the mask, you can count the number of useful networks, hosts and what type of address is it?
  • #2 8215870
    bogiebog
    Help: 2569
    Rate: 1530
    You don't need IP, just a mask.
    E.g. 255.255.255.240
    you convert each number from the mask to a binary form
    255 = 1111 1111
    240 = 1111,0000
    S - number of ones for 255.255.255.240 S = 28
    H - number of zeros, for 255.255.255.240 H = 4
    Number of networks = 2 ** S.
    Number of hosts = 2 ** H in each network (almost -2 per broadcast address and network address)
  • #3 8216173
    shel82
    Rate: 116
    Hmm, I still do not understand, because having this address: 192.168.50.0/27 in the example I have 8 networks and 32 hosts given in the answer ...?
    Meaning yours mask 27 = 255.255.255.224 = 1111 1111.1111 1111.1111 1111.1110 0000 so I have 27 networks and 5 hosts?
  • #4 8216220
    bogiebog
    Help: 2569
    Rate: 1530
    > Reasoning your way
    you don't understand our way
    2 ** S is two to the power of S.
    2 ** 27 = 134,217,728
    2 ** 5 = 32
  • #5 8221094
    shel82
    Rate: 116
    2 ** 5 = 32
    I was misled by your notation - it's probably easier and more legible to write 2 ^ S ...
    Continuing with the mask example:
    255.255.255.224 = 1111 1111.1111 1111.1111 1111.111 0 0000
    has 27 ones, which is 2 ^ S = 2 ^ 27 = 134,217,728 , but the answers I have 8 networks - why this number?
    the number of zeros is 5, so S ^ H = 2 ^ 5 = 32 and I agree with that.
  • #6 8221130
    bogiebog
    Help: 2569
    Rate: 1530
    > 27 ones settle down, i.e. 2 ^ S = 2 ^ 27 = 134 217 728, but I have 8 nets for the answers - where does this number come from?
    Maybe someone is just considering the last octet, i.e. 1110 0000,
    Then the number of 1s is 3 and the number of nets 2 ** 3 = 8
  • #7 8223767
    shel82
    Rate: 116
    Our leader said that for 192.168.50.0/27, that is, looking only at the mask itself 255.255.255.224 = 11111111.11111111.11111111.11100000 the correct answer is 6 networks and 30 hosts, and I already got lost, maybe someone will explain it to me?
  • #10 8223820
    bogiebog
    Help: 2569
    Rate: 1530
    > 6 networks and 30 hosts are the correct answer
    he seems to subtract 2 (broadcast address and network address) from the number of networks (8) - and he gets 6 - which is a bug.
  • #11 8225228
    shel82
    Rate: 116
    I looked a lot and considered an exemplary mask, eg.
    considering only the last term (224 = 11100000) and here I do not know why only this term is considered?
    Through trials in the given calculator and then calculations, it turns out that the number of ones tells us about the number of hosts, according to the previous formula:
    2 ^ 3 = 8,
    and the number of zeros with the number of networks:
    2 ^ 5 = 32
    and I'll stick to it.
    The following question is how to find out by such an address (e.g. 192.168.17.111/28) whether it is a HOST, NETWORK, PUBLIC, GROUP address?
  • #12 8225284
    bogiebog
    Help: 2569
    Rate: 1530
    > 192.168.17.111/28
    network address = 192.168.17.111 AND netmask
    192.168.17.b (0110 1111) and 255.255.255.b (1111 0000) = 192.168.17.b (0110 0000) = 192.168.17.96
    broadcast address = netaddress + all ones for host bits
    192.168.17.b (0110 0000) + b (1111) = 192.168.17.b (0110 1111) = 192.168.17.111
    the rest of the addresses are host addresses.
    b (xxxx) the number xxxx written in binary
  • #13 8225374
    carlos_oc
    In the example you gave at the beginning of the post, the address 192.168.50.0/27 actually points to 8 networks with 32 hosts in each of them. The three 1's in the last octet point to these 8 networks (2 ^ 3 = 8 - this is the number of combinations you can make with 3 bits available). The network addresses will look like this in this case:
    192.168.50.0 (hosts 192.168.50.1 to 192.168.50.31 where 192.168.50.31 is broadcast)
    192.168.50.32 (hosts 192.168.50.33 to 192.168.50.63 where 192.168.50.63 is broadcast)
    192.168.50.64 (hosts 192.168.50.65 to 192.168.50.95 where 192.168.50.95 is broadcast)
    192.168.50.96 (hosts 192.168.50.97 to 192.168.50.127 where 192.168.50.127 is broadcast)
    192.168.50.128 (hosts 192.168.50.129 to 192.168.50.159 where 192.168.50.159 is broadcast)
    192.168.50.160 (hosts 192.168.50.161 to 192.168.50.191 where 192.168.50.191 is broadcast)
    192.168.50.192 (hosts 192.168.50.193 to 192.168.50.223 where 192.168.50.223 is broadcast)
    192.168.50.224 (hosts 192.168.50.225 to 192.168.50.255 where 192.168.50.255 is broadcast)
  • Clarifying /27 subnet count and usable host ranges
    #14 15148048
    konradsonic
    Rate: 8
    Why does my colleague describe hosts and not subnets? There are no separate subnets here. If the subnets increase, the number of hosts in them decreases proportionally. What a colleague wrote here a bit incomprehensible for me. There can be 8 subnets, so the 3 octet does not change while keeping the number of hosts taken into account
    1.network address
    2 host min
    3. host max
    4.broadcast address
    And we have to stay in 30
    http://42.pl/netcalc/?a1=192.168.50.161&a2=192.168.50.190
The discussion revolves around calculating the number of networks and hosts based on an IP address and subnet mask. A user inquires about how to derive the number of usable networks and hosts from an IP address (e.g., 192.168.50.0/27) and its corresponding mask (255.255.255.224). Responses clarify that the subnet mask can be converted to binary to count the number of ones (S) and zeros (H). The formula for networks is 2^S, while for hosts, it is 2^H - 2 (to account for the network and broadcast addresses). The confusion arises from different interpretations of the subnetting process, particularly regarding the number of networks and hosts derived from the last octet of the mask. Ultimately, it is established that for a /27 mask, there are 8 subnets and 30 usable hosts per subnet.
