What Happens If Two Devices Have the Same MAC Address but Different IPs on a Network?
gavron 13338 17
What happens if two different devices on the same local network use the same MAC address but have different IP addresses?
If two different devices on the same LAN use the same MAC address, the result is unstable and depends on the switch/router: the MAC table keeps relearning that address on different ports, so frames may reach one device or the other, the connection can appear and disappear, and in some cases the segment can be flooded [#14589484][#14589475][#14593531] Different IPs do not prevent this, because the conflict is at the MAC/ARP level, not the IP level [#14589027][#14589150] MAC cloning only works cleanly when the duplicate MACs are on different network segments, such as separate LAN and WAN sides, where ARP tables are separate [#14589277][#14589299]
  • #1 14588728
    gavron
    Help: 16
    Rate: 52
    Hello!
    I searched but I didn't get any specific information from uncle google...
    What happens in the local network and how routers/switches and all other equipment behave if we connect two computers/devices with the same MAC address.
    I don't mean that DHCP will give the same IP address and there will be a conflict because I know it, but what if we rigidly have 2 different IPs but the same MAC?
  • #2 14588910
    Alana
    Level 37  
    Help: 361
    Rate: 245
    I remember that I was playing that time, i.e. I assigned the same IP and MAC to 2 machines connected to 1 switch and something worked, i.e. the internet was on both machines but weak. I suppose that the switchuch has switched to hub mode [transferring information to all sockets] and that the matter is very version specific, i.e. with another switch or other topology it will not work or it will cause the network to go "crazy".
  • #3 14588977
    bogiebog
    Help: 2569
    Rate: 1530
    Devices in the network Nothing will happen, One network card (one mac) can have many IP addresses and this configuration works without any problems.
  • #4 14589008
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    But we were talking about the MAC, not the IP.
    In this case, the switches will go crazy (at least).
  • #5 14589027
  • #6 14589030
    bogiebog
    Help: 2569
    Rate: 1530
    IMO Switches won't go crazy, they will switch packets correctly, probably one computer will get all the packets, the Switch will fill in the MAC/port table and then when searching it will find one of the ports and send packets there.
    The situation is similar to one computer that you switch 'quickly' between the switch ports, rather you will not suspend the switch.
  • #7 14589049
  • #8 14589097
    gavron
    Help: 16
    Rate: 52
    Exactly... As I see, everyone says there will be a problem, but no one knows what will happen :P I also think something is going on. I'm just installing 2xw98 on virtualbox and we'll see what happens.. First I'll test on a virtual network and then I'll do bridged and see what my router will do...
    Overall, I'll get back to you and tell you what I've found: >
  • #9 14589150
  • #10 14589258
    gavron
    Help: 16
    Rate: 52
    Ok, then tell me why MAC address cloning on routers works? and nothing happens? After all, after cloning a mac on the router, you don't have to change the mac on the computer???
  • #11 14589277
    bogiebog
    Help: 2569
    Rate: 1530
    Because these MACs are on different networks/lan segments.
  • #12 14589291
    gavron
    Help: 16
    Rate: 52
    yes, but there are 2 of the same addresses on the router at the same time, one used for LAN and the other for WAN, so something should go wrong and it's not ... Besides, you don't really know what should go wrong..
    I don't know, I can't find specific information ANYWHERE about WHAT will happen and HOW the devices will behave in the case of 2 MACs..
  • #13 14589299
    bogiebog
    Help: 2569
    Rate: 1530
    gavron, write a firmware for the router or look at the linux sources, it will explain to you what and how.
    Added after 45 [seconds]:
    Arp tables are separate per segment/lan.
  • #14 14589305
    gavron
    Help: 16
    Rate: 52
    damn, but that's not the point, the fact that I'll write soft won't give me anything because if something is going to happen, I won't jump over it without knowing the problem, right?
    I'm just asking what will happen, but I see I have to test it myself :P
    the fact that there are separate ARP tables does not change the problem that I still do not know what is at stake :P
  • #15 14589326
  • #16 14589475
    bresio
    Level 19  
    Help: 25
    Rate: 43
    When it comes to the switch, one thing is for sure.
    There will be two entries in the ARP table with the MAC pinned to two different switch ports.
    Now we need to determine what the switch will do.
    There are two options:
    1. It will forward the packet to two ports - it will work like a HUB (rather it will not behave like that)
    2. Searching the ARP tables, it will find information that the MAC is on this port and will push the frame there. In a moment, it will receive an ACK confirmation, so the ARP table will receive information that this MAC is there.
    The question is, how long are entries in the ARP table stored?
    After connecting the computer to the network, the first packets you can see are:
    -DHCP Request (if the IP address is assigned dynamically)
    -Gratuitous ARP for IP_Address
    Anyway, right after connecting to the network, information about our host, its MAC and switch port appears in the ARP table.
    By connecting a second host with the same MAC, new information about the MAC and switch port is added to the ARP table.
    It remains a matter of determining how the manufacturer of the given equipment approached searching the ARP table (maybe some RFC clarifies it)
    Below is my theory:
    In the case of two same MACs, the switch will search the MAC tables for the first entry and redirect the packet there.
    If at the same time it receives a packet from the other host, it will be in the table above and the packet will go to it.
    The second host will determine that the incoming frame has wrong sequence and ACK numbers and will request retransmissions.
    The first host will continue to wait for data. After a while it will get, but again the sequence numbers and ACK will not match.
    To sum up. Hosts will get data frames randomly. The last one to answer will get it.
    TCP will force the data transfer until it receives valid sequences and ACKs.
    Because of this, it may seem that having two hosts with the same MAC "internet performance is weaker" :)
    It's best to build a lab.
    A switch and three hosts. Preferably some bare Linux with Wireshark turned on and see what's going on.
    Bare, so as not to litter in Wireshark with some connections that will be beyond the scope of interest.
  • #17 14589484
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    There is no single answer because the behavior of even a switch may be different, one model will start sending packets between two ports and another will start sending packets to all of them, and in the second case the entire network may be clogged.
  • Duplicate MAC addresses cause MAC flapping and outages
    #18 14593531
    stachurka
    gavron wrote:
    Hello!
    What happens in the local network and how do routers/switches and all other equipment behave if we connect two computers/devices with the same MAC address?
    From experience, the internet will appear and disappear on computers, connections with servers will disappear and reappear, when you start transferring a larger file, it will fly whole and will not break anything. A flood will start in the network and a lot of packets will fly to such an extent that their number will increase to such an extent that nothing can be done in this part of the network that is under a given switch. Most likely, the flood is caused by the fact that the second machine takes packets from the first one, the first one does not have a matching checksum and asks for a retransmission and the circle closes. As the second machine did the same, then both start to renew the packets, the switch does not assign the MAC table permanently, but updates it quite often, e.g. 3 COM did it every few minutes, the situation returned to normal and, for example, after 5 minutes flood again. Before I checked what and how, I have to admit that I ran around the cages and clients. I had networks several years ago, new networks, taken over, were sometimes built in such a strange way that such eggs were commonplace. I immediately switched to DHCP with blocking, as someone entered a static IP or changed the MAC in the subnet to one that was not entered in the database, it immediately blocked it, only in this way I managed to deal with such users who know better than an amine how the computer should be configured. To sum up, if you get two MAC's in one subnet, the internet will start to disappear on both computers.
    P.S. I also had a notification on my e-mail that someone changed their IP or MAC, and I had an SMS notification on the e-mail, so if someone changed it, I immediately received an SMS. And one more thing, when I wanted to have access to the Internet from any computer, I changed his MAC to one of his subnets, but which no one used. Unfortunately, there was no protection for this, it was only a limit of connections in the network, and if someone did not pay, after blocking, he could change the MAC to a neighbor, then only physical disconnection or blocking of his port, but only in managed swiches.
Connecting two devices with the same MAC address on a local network can lead to various network issues. Responses indicate that while one network card can have multiple IP addresses, having identical MAC addresses can confuse switches and routers. This may result in a messy ARP table, causing network failures or packet forwarding issues. Some users noted that the network might behave erratically, with intermittent connectivity and potential flooding of packets. The behavior can vary significantly depending on the switch model and configuration, with some switches potentially treating the scenario like a hub, while others may update their MAC tables frequently, leading to temporary resolution of issues. Testing in a controlled environment is suggested to observe the specific outcomes.
