[EXCEL] Add Apostrophe to All Cells at Once: Efficient Solution for 2500+ Lines Input
Marcin_Sk 19166 4
  • #1 8289731
    Marcin_Sk
    Hello !
    I have a problem, due to excel seeing a cell as text by prefixing that text with an apostrophe, i need a solution how to add an apostrophe automatically to all cells at once. I have about 2500 lines and I don't really want to enter it manually for each one. Thanks in advance
  • #2 8289969
    marcinj12
    Level 40  
    Help: 1024
    Rate: 250
    And the convert to text function =TEXT(A1, "0") is not enough?
  • #3 8290091
    Marcin_Sk
    I haven't tried... I'll check and let you know. Thanks for the help
  • #4 8296917
    wrych
    Help: 37
    Rate: 22
    I'd like to run the following function in VBA:
    Function apostrof()
    For i = 1 To 30
    For j = 1 To 5
    Cells(i, j).Value = Chr(39) + CStr(Cells(i, j).Value)
    Next j
    Next i
    End Function
    Of course, the range for i, j is set according to your needs.
  • #5 8367675
    walek33
    Help: 132
    Rate: 81
    :arrow: imminent
    Have you tried activating this function?
    Added:
    For simplicity, I'll add that it should be Sub and not Function. :D Correct me if I'm wrong.
