[Excel] Automatic Insertion of / Between Characters in Cells - 5000 rows, 2nd & 3rd Characters
MrGrzechoo 57145 3
  • #1 8614674
    MrGrzechoo
    please help as you can automatically insert a character in selected cells between the data already entered in the cell. I have about 5,000 lines, and for each line I want to put a "/" in the space between the second and third letters or a digit (character) from the right. It would look like this:
    abcd1234 -> adcd12 / 34
    cdefghijk -> cdefghi / jk
    The "/" sign should always be inserted in the same place (i.e. between the 2nd and 3rd characters from the right)
    How can this be solved in Excel (2003 or 2007)?
    Can you do something like this automatically at all?
    adamas_nt
    Help: 1508
    Rate: 659
    Insert new column, paste function (example for source column A from 1 row)
    =FRAGMENT.TEKSTU(A1;1;DŁ(A1)-2)&"/"&PRAWY(A1;2)
    and drag down. Then select the column, Copy, Paste Special> Values and delete the source column.
    The same function can be used in a VBA loop (mid, len, right). It's worth it if the activity is repeated ...
    Januszf777
    Help: 59
    Rate: 46
    Hello, same solution in a slightly different way, skipping the error for cell voids:
    = IF (A1 = ""; ""; LEFT (A1, LEN (A1) -2) & "/" & RIGHT (A1; 2))
  • #4 8617651
    MrGrzechoo
    Thanks for the solution. Works great. Now I will try to figure out vba to make the inserting process a bit easier.
    Rispekt for adamas_nt and Januszf777
    That's what I meant.
    best regards
