1.9 TDI – starter draws 250–290 A on crank, is that too much?
maciejwawa 42372 6
  • #1 8411637
    maciejwawa
    Rate: 29
    Hello, what current should the starter draw when starting the 1.9 TDI engine. In my case, it is about 250 -290 amperes. Is this not too much? Could this be an indication that the plain bearings are damaged?
  • #2 8411647
    romoo
    User under supervision
    Help: 242
    Rate: 1377
    This is not too much.
  • #3 8420016
    pchela.cwks
    Rate: 10
    When starting the engine, starters take 250-600A. In a diesel it will be near that upper limit.
  • #4 8428094
    maciejwawa
    Rate: 29
    Mine doesn't exceed 300 Amps, but in another VW6TDI car it was also taking about 300 Amps, so I thought maybe in mine the bushings (plain bearings) are out.
  • #5 8429792
    emeryt2
    Help: 717
    Rate: 2302
    It would have mechanical resistance and the current draw would be higher - where is the logic here , think!!!
  • #6 8431632
    maciejwawa
    Rate: 29
    Precisely the resistance would be higher. That's why I ask if it's possible that a four-cylinder engine draws 300A and a six-cylinder engine also draws the same amount both are warm around 90C. After all, in a V6 the resistance should be higher and it should draw more current.
  • #7 8432011
    ociz
    Help: 1379
    Rate: 3486
    See for example in older Opels in gasoline how much a Bosch starter takes, and how much a Valeo starter with the same engine. Valeo will turn even on starter cables from Ladybug, and Bosch will not start already with a weak battery.
The discussion centers on the current draw of a starter motor when starting a 1.9 TDI engine, with the user reporting a draw of 250-290 amperes. Responses indicate that this range is typical for diesel engines, which can draw between 250-600A during startup. Concerns were raised about potential mechanical resistance due to worn plain bearings, but it was noted that a four-cylinder engine drawing 300A is not unusual, even when compared to a six-cylinder engine. The conversation also references the performance differences between various starter brands, specifically Bosch and Valeo, highlighting that different starters can have varying current requirements under similar conditions.
