[Solved] A6 C5 2.5 TDI AKE - Hard Starting & Firing Issues: Warm Engine, No Errors, Long Cranking Times
barylaa 13272 7
  • #1 16897956
    barylaa
    Rate: 9
    Hello, patient a6 c5 2.5 tdi AKE problem with firing, not when it fires as normal, and not when you have to shoot for a long time to fire. An example from today I get on, start the car (smokes normally), drive away from 500 m, I go back after 1.5 hours and I have to spin for a while before it starts. When the engine is warm, it burns well (1 in 100 fires need to be turned a lot). There are no errors
  • #3 16899034
    barylaa
    Rate: 9
    Well, don't let it go, if nothing sensible to say you don't have why you are littering the subject? I'm not asking what distance I have to cover to have a diesel, but something else. The battery is new, so there is nothing for heavy firing in my case ....
    helmud7543
    Help: 1216
    Rate: 1564
    It needs 15-20 m of engine work to accept the current it gave up at start-up - just for the news. Although this is not about the topic but ... are you sure that you have a charged battery (after a few routes several hundred minutes after a few such firing certainly will not be - such laws of physics)? Observe how it turns the engine, I immediately recognize that it spins poorly as I have discharged (in addition, the ABS indicator lights when starting).
    Injection system not aerating?
    pe$$0s
    Help: 27
    Rate: 47
    injection angle to be checked first and candles, fuel filter, injection overflow lines
    Somebody22
    Rate: 25
    Also check the wires on the pump that go from the pump electronics to the valves. insulation can burn out and short-circuit.
    The shaft sensor can also give similar symptoms.
    Overall, it's the nastiest engine possible. You will do everything and you are still unwell. Somewhere on the Ukrainian forum I saw swap vp44 on VE6 mechanical :)
    bleto
    Check the glow plugs.
    Added after 1 [hours] 57 [minutes]:
    Candles, fuses and candle temperature control.
  • #8 17150087
    barylaa
    Rate: 9
    Car sold. close
The discussion revolves around a 2000 Audi A6 C5 2.5 TDI AKE experiencing hard starting issues, particularly after short drives when the engine is warm. The owner reports long cranking times with no error codes present. Responses suggest checking various components, including the injection angle, glow plugs, fuel filter, and wiring related to the pump electronics. Concerns about battery charge and the injection system's aeration are also raised, indicating potential electrical issues or component failures that could affect starting performance.
