Car Battery Consumption: Measuring Amps Drawn & Charging Minutes after Engine Start
mlac 26369 21
How many amp-hours does a car starting event typically take from the battery, and how long does the engine need to run to recharge that loss?
A typical start uses about 1–2 Ah, and in one worked diesel example the loss was 1.32 Ah, which was estimated as about 10% of a nominal 60 Ah battery after accounting for battery aging and the fact that high-current discharge reduces usable capacity [#5903080] For practical driving, users estimated that roughly 15–20 minutes of driving is needed to make up one start, while full recovery of the battery can take several hours of driving [#20847500] [#20846388] The exact recovery time depends on battery condition, the starter current, glow plugs, and the car’s electrical load, so a weak battery or parasitic drain can make short trips end up negative overall [#5903080] [#20846388]
  • #1 5902866
    mlac
    Rate: 8
    I have a fairly simple question. I've searched but can't find a specific answer. How much A car consumes when starting. It is known that the battery has, for example, 45 Ah. The question is how much of it remains after starting the car. Is it, for example, 90% or only 60%. I know that immediately after firing the alternator charges the battery, but the question is how many minutes the engine must run to recharge this energy loss. You're about to say it depends on the car and the temperature. It is known that in the winter there will be much more wear, but in fuel-injected cars, the starter motor does not turn, it is not known how much, so the difference should not be great.
  • #2 5902876
    bolek
    Help: 86
    Rate: 299
    I guess it depends more on the size of the car (engine) than the temperature
    For a passenger car you can take an average of 300A/s
  • #3 5902885
    mr-perch
    Help: 94
    Rate: 287
    It depends on many factors. The question that springs to mind is why do you need this knowledge?
  • #4 5902909
    mlac
    Rate: 8
    Well, I'll explain it to you. Well, for the third time I recharged my mother's battery in this "winter" as it is her car around the city (no one else drives it) and she drives it sporadically, if at all. The car is a Suzuki swift. The charging current is adequate, everything checked, but if you drive once every 4 days, max 5 km, then what is surprising. But it's hard to explain to her, so I drew her a graph of how her battery is decreasing day by day. But I can't explain to her that if she doesn't drive for 5 days, going and starting it at a stop (so that, as she says, burn it) won't help because it will use more electricity to start than it's worth.
  • #5 5902966
    mr-perch
    Help: 94
    Rate: 287
    And here you are wrong. It is better to start the car once every two days than to leave it idle for 5 days. The battery will charge, you will stimulate the electrolyte, the engine will work.
    Start by checking the condition of the battery (electrolyte) and its capacity under load. That will tell you a lot.
  • #6 5902968
    goldwinger
    Help: 534
    Rate: 2100
    The battery is dead or the draw is too high.
    The starter will take 100A
  • #7 5902997
    mlac
    Rate: 8
    This is what I know from experience that it is not wrong. As three years ago it was minus 27 in January, I decided not to move the car for 6 days until the temperature returned to minus 8 and I fired without a problem. And the sister stubbornly fired and fired only once and failed the second time :) It is true that the cars are different, but the battery has a capacity of about 50 Ah. My theory is simple - when I start it, I drive for at least 15 minutes. And firing to burn the car was good when you had a polonaise.
  • #8 5903012
    mr-perch
    Help: 94
    Rate: 287
    Approx. you know more. Why in this arrangement are you asking us?
    I'm done with this topic. Just explain to mom to start driving when the temperature is around 10 degrees. Gotta wait until April...
  • #9 5903015
    mmm777
    Help: 98
    Rate: 240
    I join: either the battery needs to be replaced, or there is a problem with charging.
    Possibly - the battery needs to be replaced as a result of charging problems.
    - people, what do you drive, Fela drives normally for 2 (or 3) weeks...
  • #10 5903056
    mlac
    Rate: 8
    Well, I can't seem to get a specific answer. One says 300 A/s the other says 100 A to fire. I'm heading to bed :) but I encourage you to discuss something specific will come up.
    Regards
    kybernetes
    Help: 426
    Rate: 1487
    Let's consider such a case.
    Diesel engine, current consumption by the starter, in winter, after an overnight stop - let's say 250A, let the start-up last 15 seconds, plus 5 seconds of glow plug heating before and during start-up ~50A (cold ones have a large consumption, over 80A, which during heating reduces to 36-40A) that is:
    250A * 15s = 3750As
    50A * (5s + 15s) = 1000As
    3750As + 1000As = 4750As
    4750As / 3600s(number of seconds in an hour) = 1.32Ah
    However, there are two factors that should be kept in mind - firstly, the rated capacity of the battery after buying a new one in the store and installing it in the vehicle, it decreases significantly during operation (e.g. to 70% or less). The second thing is that the battery discharged with a high current of 200-300A has a capacity much lower than the rated one (e.g. 30%). In our case, it would look like this:
    60Ah(diesel battery) * 0.7(used to 70% of initial capacity, i.e. "still fresh") * 0.3 (discharged with high current) = 12.6Ah
    and this capacity should be taken into account during start-up
    Let's substitute it into the previous calculations - 1.32Ah for starting:
    12.6Ah / 1.32Ah = 9.5
    which gives us the number of winter starts that we can squeeze out of our battery. Translating this into the nominal capacity of the battery, one such start "eats" about 10% of this capacity.
    Regards
    PS: With greater frosts, there is one more factor - reducing the capacity of the cold battery.
    ociz
    Help: 1379
    Rate: 3486
    But it's not good for the engine, because it will only absorb moisture, so when you start it, it will heat up.
  • #13 5903102
    mmm777
    Help: 98
    Rate: 240
    The classic symptom of a battery drain:
    - the car does not start, no electricity,
    - we load, it loads quickly,
    - the car starts, we drive normally,
    - we leave the car in the evening,
    - she didn't start in the morning.
    The important thing is whether it is a natural descent, or caused by chronic undercharging or deep discharge (this exhausts the battery extremely effectively).
    But to find out what the cause is, at least you need to measure the voltage in the system while driving, and after it.
  • #14 5903141
    mlac
    Rate: 8
    Well done "kybernetes" that's what I meant. This gives some idea of what the battery life cycle looks like. Thanks alot.
    To be precise, I will say that my mother's battery does not rain after two days or a week, but after 3-4 weeks. In my opinion, the energy balance is negative and it gradually discharges because it runs too short.
    Exactly :)
  • #15 5903196
    goldwinger
    Help: 534
    Rate: 2100
    Listen, the starter in this car takes max around 130A, do you need something more?
  • Buffer power supply at 13.5–13.8 V for battery testing
    #16 19689518
    lukiiiii
    Help: 82
    Rate: 392
    mlac wrote:
    it doesn't rain after two days or a week, but after 3-4 weeks
    4x 7 days x 24 hours = 672 hours, all you need is some piece of shit in the car that takes 100mA and you have an empty battery.
    If there is still a problem, connect the buffer power supply, DC power supply set to 13.5 -13.8 V, you can even get ready-made power supplies.
    Ps. I am browsing the topic, because I would also like to know after how much time after lighting the car we make up for the loss in the battery? I heard after 4km or 4 min
  • #17 19689550
    Zbych034
    Help: 550
    Rate: 1417
    Have you checked the power consumption while parked?
    Maybe, for example, the trunk lamp does not always go out.
  • #18 19689553
    snow
    Help: 178
    Rate: 201
    Everything is explained well by colleagues, except that it should be remembered that the battery capacity is for a certain current that is drawn from it. Not every current will be 45Ah.
  • Short trips and failed alternator killed the battery
    #19 19689805
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    A friend once had a Ford scorpio with a 2.5TD engine (Italian VM), the glow plugs were still hot for about 10 minutes after firing, at that time there was practically no battery charging because the alternator was not working. The problem was that this lady drove about 2 km to work every day, the battery had to be recharged in the autumn and winter period once a week, and replaced with a new one 2-3 times a year, because it could not withstand such exploitation
  • #20 19694896
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    it was also like that in Isuzu, but there was and is a quick solution for it. The car after resting must give more than 14V on the battery, otherwise it will be linden.
  • Short trips need a smaller battery and longer charging
    #21 20846388
    mobiwojtek
    My comments:
    - check the current leakage when stationary; it happened that the immobilizer or alarm consumed a lot of electricity.
    - for short city driving, it is best to buy a smaller battery than the nominal one (one model smaller, if you need 50, then take 44) - it is easier, so you can charge it faster.
    - starting the engine to start it is electrically negative for a minimum of 20 minutes of driving.
    - natural charging of the engine (in one drive, with the car running, with a large battery reaching 12V+ an hour after turning off the engine) requires several hours of driving.
    - the energy needed to start the vehicle is only 1-2Ah.
    - capacitor batteries are already appearing. That's why.
    - I have a new battery, it should last like this for 2 years.
  • #22 20847500
    cyborg39
    Help: 105
    Rate: 546
    I once read somewhere a very average calculation that for one start of the car it takes about 15 minutes of driving to "send" electricity to the battery. I have accepted this calculation as quite true for many years because it more or less works, and that's it
The discussion revolves around the consumption of car batteries during engine start-up and the subsequent recharging process. Users share insights on the average current draw of starter motors, which can range from 100A to 300A depending on the vehicle and conditions. Factors such as battery capacity (e.g., 45Ah, 50Ah), engine type (diesel vs. gasoline), and environmental conditions (e.g., winter temperatures) significantly influence battery performance and longevity. Recommendations include starting the vehicle regularly to maintain battery health, ensuring proper charging, and monitoring for potential current leaks when the vehicle is stationary. The consensus suggests that driving for approximately 15 minutes post-start is necessary to replenish the energy lost during starting. Users also highlight the importance of battery maintenance and the potential need for replacement if issues persist.
TL;DR: A winter diesel start consumes approx. 1.32 Ah (≈10 % of a 60 Ah battery) and “one such start eats about 10 % of this capacity” [Elektroda, kybernetes, post #5903080] Plan on 15 minutes of driving to recover that charge [Elektroda, cyborg39, post #20847500] Why it matters: Knowing real draw and recharge time prevents dead batteries on short, cold trips.
• Starter draw: 100 – 130 A in small petrol cars [Elektroda, goldwinger, #5902968; #5903196] • Typical recharge after one start: ≈15 min or 4 km [Elektroda, cyborg39, post #20847500] • Parasitic drain ≥100 mA empties a 45 Ah battery in ~4 weeks [Elektroda, lukiiiii, post #19689518] • Alternator should show >14 V at idle for net charge [Elektroda, Strumien…, post #19694896] • High-current cranking cuts usable capacity to ~30 % [Elektroda, kybernetes, post #5903080]
How many amps does a typical car starter draw?
Small petrol starters pull 100–130 A; larger diesels can hit 250 A [Elektroda, goldwinger, #5902968; #5903196; kybernetes, #5903080].
Can repeated short trips undercharge my battery?
Yes. City hops under 5 km often discharge faster than alternator can replenish [Elektroda, mlac, post #5902909]
How do I measure parasitic drain while parked?
  1. Set multimeter to 10 A range. 2. Connect in series with battery negative. 3. Wait 30 min; reading should stay below 50 mA [Elektroda, lukiiiii, post #19689518]
Is it better to start the car every two days or leave it a week?
Brief idling adds moisture and rarely recharges; leave parked or drive ≥15 min instead [Elektroda, ociz, post #5903085]
