  • #1 8527679
    kolokat
    Help: 47
    Rate: 31
    Do you have any idea how to unscrew TORX screws without a suitable screwdriver?
    I struggle with the disk to extract the plates, and the torxes I have are too big for the ones on the disk.
  • #2 8527716
    cirrostrato
    Help: 285
    Rate: 956
    In Poznań, in the Market, for a few PLN, buy the right tip, otherwise you will smash something in the disk ...
  • #3 8527739
    krzyjak
    Help: 110
    Rate: 137
    As once I unscrewed a few screws with a flat screwdriver with the appropriate width of the tip (the tip can possibly be adjusted on the grinder), but I must admit that it is a risky operation. You can fix the screw head in such a way that only drilling it will help. Good luck.
  • #4 8527905
  • #5 8527910
    habrozaurus
    Conditionally unlocked
    Help: 167
    Rate: 59
    Take a small flat-head screwdriver, put it on the screw, give a lot of tin to solder the screwdriver with the screw and unscrew.
    A good way to unscrew very worn torxes in phones :)
  • #6 8528614
    tomek10861
    Help: 13
    Rate: 199
    I use pliers to spin the discs. I grab the bolt head and twist until the bolt comes off. Then a flat screwdriver. :D But I have to finally invest in Torxy.
  • #7 8531444
    stroggo81717
    Help: 45
    Rate: 41
    I know two ways:
    - You buy a Torx screwdriver and unscrew it.
    - You don't care about bolts? Open them. The method for reaming the screws is given above.
  • #8 8531469
    arti13
    Level 32  
    Help: 85
    Rate: 79
    I had such a large knife ... I sawed the tip a bit flat and it was going somehow ..:]
  • #9 8532501
    gwidon997
    Help: 44
    Rate: 71
    You can also adjust the appropriate hex key and unscrew it.
The discussion revolves around methods to unscrew TORX screws without the appropriate screwdriver. Suggestions include purchasing the correct TORX tip, using a flat screwdriver with a modified tip, drilling the screw heads, or soldering a screwdriver to the screw for better grip. Other methods mentioned involve using pliers to twist the screw or adapting a hex key for the task. Some participants noted the risks of damaging the screws or the device if improper techniques are used.
