Exploring Battery Charging in Unheated Garage at Sub-Zero Temperatures (-20°C, -15°C, -10°C)
kaputo 52229 14
Can I charge a car battery in an unheated garage at sub-zero temperatures, and what are the risks or limits?
Yes, a car battery can be charged at -20°C to -10°C, but charging becomes much less effective as temperature drops and the process takes longer [#8891706][#9123553] At around -15°C, a fully charged battery may only have about 60% of its rated capacity, and the electrolyte temperature will not rise much during a normal low-current charger session [#8891706][#8891624] The same hydrogen-gassing explosion risk exists as with charging at higher temperatures, so the battery should be charged in a ventilated place [#8891461][#8891706] If the battery is still in the car, disconnect at least one terminal unless the charger limits the output to about 14.5 V, otherwise the vehicle electronics may be damaged [#8891706] If the battery was completely discharged and then frozen, do not try to charge it in the cold until it has thawed [#9073090]
  • #1 8891424
    kaputo
    Help: 37
    Rate: 128
    I was looking for information on this topic on the forum and on the net, but nothing specific can be found.
    Specifically, charging the battery in an unheated garage, for example, when the temperature is -20 ° C -15 ° C -10 ° C outside.
    In general, I found statements that I would rather not load, threat of an explosion, but no specific studies.
    I would prefer to avoid taking the battery out of the car. There are later problems with the electronics. You can find information on what upper temperature should not be exceeded, but nothing about the minimum temperature.
  • #2 8891461
    mikomir
    Help: 8
    Rate: 19
    In item 4 on the page:
    http://www.mototechnika.republika.pl/pliki/akumulatory.html
    it describes exactly how the temperature affects the battery parameters.
    Besides, the batteries are charged at such low temperatures when the vehicle is running and nothing happens (it does not explode, etc.).
  • #3 8891624
    kaputo
    Help: 37
    Rate: 128
    And they say that the electrolyte temperature ranges from 5 to 40 ° C.
    The electrolyte density is based on 25 ° C. At -25, even when charged it will be different. Also, a charged battery at -25 ° has 60% of its power.
    I am looking for a specific theory, let's say academic, describing the topic.
    I know that the battery is charged while driving, but you can find various opinions on this subject, unsupported by anything.
    The most effective charging is at 15-25 ° C. Does -25 make sense?
  • #4 8891706
    ^ToM^
    Help: 495
    Rate: 2939
    kaputo wrote:
    e.g. in an unheated garage when the outside temperature is -20 ° C -15 ° C -10 ° C.
    The principles of charging at low temperatures are the same as at high temperatures. It can explode in the same way as with high ones (hydrogen is released). At the same time, it should be borne in mind that charging is ineffective at low temperatures. Charging efficiency drops proportionally as the temperature drops. After charging, you will not get the rated capacity, only the one that the given temperature will allow you to do. At -15 deg it will be somewhere with 60% capacity when fully charged. You do not have to pull out, but unhook, at least one clamp from the car. Well, unless you have a charger that prevents voltage higher than ~ 14.5V on its terminals. Otherwise, the electronics may be damaged.
  • #5 8896861
    tzok
    Help: 3176
    Rate: 6549
    Automatic chargers have a program for charging the battery at low temperatures - the end of charge threshold voltage is different.
    During charging, the temperature of the electrolyte will rise ...
  • #6 8898358
    ^ToM^
    Help: 495
    Rate: 2939
    I can assure you that it will not increase by a degree when charging in the cold. Unless you can pass some powerful current through the battery. Usually, however, rectifiers give at most a few A, which at very low temperatures does not increase the temperature in a significant way.
  • #7 8898405
    robokop
    Help: 1763
    Rate: 6372
    I would argue here, although I did not check it organoleptically - nevertheless, the alternator voltage regulators contain a therm-sensitive element to regulate the charging voltage as a function of the external temperature, I have a fairly advanced inverter rectifier with a temperature probe to correct the current with the change of battery temperature. Also note that when the battery is fully charged, when overcharged with voltage, its temperature increases as the electrolyte gasses.
  • #8 8898922
    ^ToM^
    Help: 495
    Rate: 2939
    The problem is that as the temperature drops, the internal resistance increases proportionally. The apparent decrease in capacity is precisely related to the increase in Rw. Hence, when at 20 degrees C through the battery you manage to pass, for example, 4A, then at -15 degrees C I give myself 0.5-1A. This means that the increase in heat generation is not able to exceed its emission and thus the temperature does not increase. An ordinary rectifier usually works in such a way that the current drops practically to zero as the voltage increases at the terminals. So in this situation, even when the battery is gassing, the flowing current is small and is not able to raise the temperature in a measurable way. The compensation sensor in the alternator is more needed the other way. The charging voltage is to be corrected -20mV / deg C and it is quite critical with the increase, because it has an impact on the battery life.
  • #9 8899845
    tzok
    Help: 3176
    Rate: 6549
    I have a 10A automatic (impulse) charger and it stabilizes the current, not the voltage, and in the "winter program" it charges up to 14.7V (but only 7A) and not to the standard 14.4V. At -15 * C I did not charge, but around 0 * C the battery got noticeably warm.
  • #10 8905377
    robertos.moc
    gentlemen. The battery is charged with a charger only at temperatures above 5 degrees C. Then we only choose the method of charging, i.e. formatting, complementing and the last one is necessarily quick. and everything is decided by the amperage.
  • #11 8918118
    ^ToM^
    Help: 495
    Rate: 2939
    robertos.moc wrote:
    gentlemen. the battery is charged with the charger only at temperatures above 5 degrees C.
    Note that the "chargers" that are built into all cars charge at all temperatures. Even when it's outside -30st. Hence, the charging temperature is not critical, while the charging efficiency at sub-zero temperatures is low.
  • #12 8923164
    robertos.moc
    you look like a charger too. the alternator is designed to recharge the battery and the main task is to power everything you turn on. recharging in this case is possible because your battery has been energized.
  • #13 8951184
    ^ToM^
    Help: 495
    Rate: 2939
    Hence I wrote "charger". Recharging is possible at any time, even when the battery is discharged to "zero". There is no such thing as "agitation" here.
  • #14 9073090
  • #15 9123553
    zdzich1958
    Temperature affects the rate of chemical reactions in the battery, which affects the battery capacity. In the range from 18 degrees to 27. Increasing the temperature by 1 degree causes an increase in capacity from 0.5 to 1%. At -15 degrees you can charge, but it will take much longer.
Charging batteries in unheated garages at sub-zero temperatures (-20°C, -15°C, -10°C) poses challenges due to decreased efficiency and increased internal resistance. While batteries can be charged at these temperatures, the capacity achieved is significantly lower, often around 60% at -15°C. Automatic chargers designed for low temperatures adjust the charging voltage and current to mitigate risks, but charging remains inefficient. Concerns about potential hazards, such as hydrogen gas release, are noted, emphasizing the importance of using chargers that limit voltage to protect vehicle electronics. The electrolyte's temperature and density also affect charging performance, with optimal conditions being between 15°C and 25°C. Overall, while charging is possible, it is not recommended to charge batteries that are completely discharged in extreme cold, as frozen electrolyte can prevent charging.
