Freezer Functionality in Unheated Room: Sub-Zero Temp Impact on Performance & Durability
RP 41097 5
  • #1 9911455
    RP
    Help: 14
    Rate: 52
    Can the freezer work in an unheated room where the temperature drops below zero in winter? Will it work well and won't it affect its durability? I am asking for opinions
    RP
  • #2 9911476
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3387
    It will work quite sparingly ;)
  • #3 9911497
    Qbuś
    Help: 380
    Rate: 876
    nares wrote:
    It will work quite sparingly :wink:
    Even with the door open :D
    Mine stands on the balcony and does not complain in winter. You just need to make sure that the rain or snow does not fall directly, because it can quickly "catch the corrosion".
  • #4 9911802
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    RP wrote:
    freezer can work in an unheated room
    In case someone finds out about this topic in the future, it seems to me that it is worth emphasizing that it is only a freezer, not a fridge-freezer - it can no longer stand in a cold room.
  • #5 9911863
    oskar777
    Help: 76
    Rate: 243
    Out of curiosity, I will ask why? The in-laws in the boiler room have a refrigerator that works for several years in the winter to -10 degrees and works.
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #6 9912007
    nares
    Help: 1515
    Rate: 3387
    Because it is an old refrigerator, without the self-defrosting function - new devices with this function need a minimum of + 15 degrees. environment for proper operation.
