Pioneer DEH-2200UB Error 23: USB Flash Drive Connection, FAT32 Format, Music Playback Issue
xagaciax 59291 5
  • #1 9169098
    xagaciax
    Recently I wrote that I have error 26 on my radio after connecting the USB flash drive, but it turned out that it was error 23 xD
    Well, I did what I read - I formatted the flash drive to fat32, I put the music on and unfortunately still the same: / the best thing is that it worked before, basically this error 23 popped out overnight and until now it is not I know what to do with it.
    I'm sorry if there was such a topic, and if someone coped with it, I would ask for info.
  • #2 10167500
    tomplichta
    Rate: 49
    You have a badly formatted flash drive for fat16 or fat32
  • Test with one compatible MP3 file on another drive
    #3 10179495
    msepl
    Help: 56
    Rate: 189
    Take the second flash drive, format correctly. Same ?
    Just upload one song and check it out.
    They must meet the following conditions.
    File extension: .mp3
    o Bit rate: 8 kbps to 320 kbps
    o Sampling frequency: 16 kHz to 48 kHz (32 kHz, 44.1 kHz, 48 kHz for emphasis)
    o Compatible ID3 tag version: 1.0, 1.1, 2.2, 2.3, 2.4 (ID3 tag Version 2.x is given
    priority over Version 1.x.)
    o M3u playlist: No.
    o MP3i (MP3 interactive), mp3 PRO: No.
  • #4 17477982
    diuri
    Rate: 12
    I had the same situation. I formatted the pendrive with rufus and the problem is gone.
    I remembered that I used to use a USB flash drive as botable and formatted by changing the partitioning scheme to GPT under UEFI. Maybe Windows does not change the partitioning scheme when formatting.
  • #5 17522406
    pdpiotrek2
    Rate: 9
    Rufus pena under fat32 and after the case, even NTFS does not read
