[Solved] Convert 1500 Cubic Meters of Gas to Normal Cubic Meters: 170 mbar, 22°C Calculation Method
orion61 30795 4
  • #1 9176811
    orion61
    Rate: 13
    How to calculate ?.
    1500 cubic meters of gas is how many normal meters.
    The gas is 170 mbar and 22 degrees C.
  • #3 9177781
    orion61
    Rate: 13
    Thank you for the answer, but it did not help me.
    After the calculations, cosmic numbers come out.
    For comparison, I have meter readings.
    Such gas consumption occurred for the same production.
    Under normal conditions, 1750 m - and in cubic meters, 2600.
    But on the second day in normal conditions 2200 m and in cubic meters 3900.
    In the first version, the difference is 45-50%
    In the second, over 75%
    That is why I am asking for a formula, a conversion factor to compare both of these indications.
  • #4 9178388
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Take a look at the first link to the post crs_sc .
    Note that gas volume depends on temperature and pressure.
  • #5 18425400
    orion61
    Rate: 13
    Devices with both m3 and Nm3 meters were used
