Home methods to increase the range of the TV antenna and the radio antenna
Turysta10 67806 9
How can I improve the reception of a room TV/radio antenna at home with a simple DIY method?
A room antenna inside a block of flats is unlikely to give a big improvement; the practical fix is an outdoor passive antenna placed on the balcony or by a window facing the transmitter, ideally with a balun [#10006172] If you are near the transmitter, such an antenna should already handle it, and in this case a DVB-T MPEG4 tuner was also suggested for digital terrestrial TV [#10006172] If you want a cheap DIY solution, build a Yagi-Uda antenna; one reply says it can be done very cheaply and recommends using a Yagi calculator and build instructions [#9374733]
  • #1 9374705
    Turysta10
    Rate: 19
    I am looking for some home (simple) way to improve the quality of received channels on TV or via radio.
    I have a "room" antenna installed for the TV, unfortunately the quality of some programs that I receive is not satisfactory.
    I wonder if if I connected a cable or a suitable wire, I would be able to improve the quality of the received programs.
    Regards
  • #2 9374733
    wachcio
    Help: 61
    Rate: 74
    If you have any DIY skills and some materials to build the antenna or scrap the antenna, you will do it for a maximum of PLN 5 :)
    One of the easiest and best antennas is the Yagi-Uda. Download the Yagi Calculator program, with which you can count the dimensions and search for information on Google on how to make such antennas and work.
    Here you have a nice topic https://www.elektroda.pl/rtvforum/topic1475221.html#7230194
  • #3 9375084
    irekr
    Help: 1192
    Rate: 1239
    And I will ask a basic question: what and where do you want to pick up ...
  • #4 9376320
    Turysta10
    Rate: 19
    My favorite show - Al Jazeera ;-)
    And so seriously the standard TVP1,2,3 TVN, Polsat, Puls - nothing more is needed.
    Unfortunately, I live in a block of flats and I have to limit myself to a room antenna.
    I bought one, supposedly the strongest they had in the store. Unfortunately, I receive 4 programs, if I want to watch the other 2 I have to rearrange it.
    I am looking for a way to improve the quality of the channels I receive.
  • #5 9376532
  • #6 9377141
    irekr
    Help: 1192
    Rate: 1239
    No answer to the basic question: WHERE?
    It's not very precise in the block ...
    Some address, city, street .....
    Not every dog, Azorek ....
  • #7 10005263
    Turysta10
    Rate: 19
    mihal2002 wrote:
    Improve reception on room antenna in a block of flats ?! Laughable! :D On the outside, this one will be a problem! Buddy, cable, and nothing else.
    Unfortunately, there is no cable TV in my block :(
    irekr wrote:
    Basic question not being answered: WHERE?
    I didn't know it was important, but OK.
    Poraj 42-360 block hmmm ... 30 maybe 50 years old.
    How can my address help in resolving the problem?
    matis057
    Help: 227
    Rate: 215
    You have ~ 10 km to Błeszno. You should be receiving well.
    Buy yourself an outdoor passive antenna.
    Such an antenna with a balun on the balcony should already handle it.
    http://www.dipol.com.pl/antena_telewzyjna_uhf_11-elementowa_dipol_11-21-69_A1112.htm
    Set it to Częstochowa and watch it. You can buy a DVB-T MPEG4 tuner and watch digital terrestrial TV.
  • #9 10009777
    Turysta10
    Rate: 19
    Thank you for the advice, the balcony is gone, but we'll try to figure it out :-)
  • #10 10009916
    matis057
    Help: 227
    Rate: 215
    Do you have a window from the side of the transmitter in Błeszno or from the side of the transmitter in Węczyca?
The discussion revolves around improving the reception quality of TV and radio channels using home methods, particularly for users with room antennas in apartment buildings. Suggestions include building a Yagi-Uda antenna using DIY skills and materials, as well as purchasing an outdoor passive antenna for better reception. The importance of antenna positioning relative to the transmitter location is emphasized, with recommendations to use a balun and consider digital terrestrial TV options. The user expresses challenges with limited channel reception and the absence of cable TV in their building.
