Asus Laptop Camera: Fix Inverted Image Issue using Webcam Settings & Driver Updates
ColdFlame 169146 8
  • #1 9476987
    ColdFlame
    Rate: 24
    Inverted image from the Asus laptop camera
    You've probably been shocked by the inverted camera image on an Asus laptop?
    You are not the only one - there are hundreds or even thousands of such people. There are several solutions to this problem. I will present them below so that you can remove the defect or at least avoid it in such a way as to enjoy the correct operation of the image.
    Method 1.
    The first method is actually a simple trick to bypass, not fix, the issue.
    Enter the webcam settings on your laptop, ( e.g. USB Video Device ) and select " image inversion ". This way, by inverting the inverted image, you will get the right view.
    This simple trick is great if you want to act quickly, but if you want to completely fix the problem, check out the steps below.
    Way 2 . ( Highest probability of solving the problem )
    The next step is also not incredibly difficult. You just need to uninstall the drivers from the webcam, download other ( it's about the version ) and reinstall them. Then restart the computer and enjoy the correct camera image.
    However, if this does not help, try installing a different version of the drivers. Some laptops, due to the wrong version of the drivers, are not able to correctly display the image from the webcam. It is very likely that the problem lies in the drivers. It shouldn't take long to find the right drivers if you know your webcam model.
    Attention: Remember that you must restart your computer after installing and uninstalling drivers.
    Way 3.
    The cause of the inverted image may also be the webcam program that has problems with integration with laptops of this series. Try to uninstall the current webcam program and download it from a completely different manufacturer. Weird? And yet it sometimes helps ...
    Way 4.
    Uninstall the codecs installed on your laptop, restart your computer and check if the webcam image is displayed correctly now. Yes? That's great, because the problem was with the codecs. Perhaps some of them "bite" (are incompatible)with the camera controllers, causing the displayed image to be inverted and changing the parameter corresponding to it ( even in the registry ).
    Hope any of the above methods helped you with your problem.
  • #3 10151196
    gradek83
    Help: 930
    Rate: 2103
    Generally it is about the Operating System, or at least usually.
    In the example:
    ASUS MODEL: K52DE
    OPERATING SYSTEM: WIN XP SP3 32bit
    Hardware Identifiers:
    USB \ Vid_13d3 & Pid_5130 & Rev_1211 & MI_00
    (There is no support for this system on the manufacturer's website)
    As for the webcam, we download the driver:
    Camera_Azurewave_VS011_WIN7_32_z5854000207.zip
    -we unpack
    Then, in Device Manager, select our camera and Update Driver
    -No, not this time
    -Next
    -Install from a list or specific location
    -Next
    -Do not search, I will choose the driver to install
    -Next
    -From disk
    -Browse (We indicate the place of the driver) select the file. (snp2uvc.inf)
    A message will appear, click on YES and it's ready.
    [SN.NTx86.5.1]
    ;VGA
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.XP,USB\VID_13d3&PID_5108
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.XP,USB\VID_13d3&PID_5118
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.XP,USB\VID_13d3&PID_5120
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.XP,USB\VID_13d3&PID_5129
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.XP,USB\VID_13d3&PID_5130
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.XP,USB\VID_13d3&PID_5132
    ;1.3M
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5082
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5102
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5104
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5105
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5106
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5113
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5114
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.XP,USB\VID_13d3&PID_5133
    ;2M
    %SN.USBVideo2M.DeviceDesc% = SN.USBVideo2M.XP,USB\VID_13d3&PID_5122
    ;3M
    %SN.USBVideo3M.DeviceDesc% = SN.USBVideo3M.XP,USB\VID_13d3&PID_5101
    [SN.NTamd64]
    ;VGA
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.x64,USB\VID_13d3&PID_5108&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.x64,USB\VID_13d3&PID_5118&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.x64,USB\VID_13d3&PID_5120&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.x64,USB\VID_13d3&PID_5129&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.x64,USB\VID_13d3&PID_5130&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.x64,USB\VID_13d3&PID_5132&MI_00
    ;1.3M
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5082&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5102&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5104&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5105&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5106&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5113&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5114&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.x64,USB\VID_13d3&PID_5133&MI_00
    ;2M
    %SN.USBVideo2M.DeviceDesc% = SN.USBVideo2M.x64,USB\VID_13d3&PID_5122&MI_00
    ;3M
    %SN.USBVideo3M.DeviceDesc% = SN.USBVideo3M.x64,USB\VID_13d3&PID_5101&MI_00
    [SN.NTx86.6.0]
    ;VGA
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v32,USB\VID_13d3&PID_5108&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v32,USB\VID_13d3&PID_5118&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v32,USB\VID_13d3&PID_5120&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v32,USB\VID_13d3&PID_5129&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v32,USB\VID_13d3&PID_5130&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v32,USB\VID_13d3&PID_5132&MI_00
    ;1.3M
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5082&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5102&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5104&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5105&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5106&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5113&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5114&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v32,USB\VID_13d3&PID_5133&MI_00
    ;2M
    %SN.USBVideo2M.DeviceDesc% = SN.USBVideo2M.v32,USB\VID_13d3&PID_5122&MI_00
    ;3M
    %SN.USBVideo3M.DeviceDesc% = SN.USBVideo3M.v32,USB\VID_13d3&PID_5101&MI_00
    [SN.NTamd64.6.0]
    ;VGA
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v64,USB\VID_13d3&PID_5108&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v64,USB\VID_13d3&PID_5118&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v64,USB\VID_13d3&PID_5120&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v64,USB\VID_13d3&PID_5129&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v64,USB\VID_13d3&PID_5130&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.v64,USB\VID_13d3&PID_5132&MI_00
    ;1.3M
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5082&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5102&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5104&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5105&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5106&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5113&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5114&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.v64,USB\VID_13d3&PID_5133&MI_00
    ;2M
    %SN.USBVideo2M.DeviceDesc% = SN.USBVideo2M.v64,USB\VID_13d3&PID_5122&MI_00
    ;3M
    %SN.USBVideo3M.DeviceDesc% = SN.USBVideo3M.v64,USB\VID_13d3&PID_5101&MI_00
    [SN.NTx86.6.1]
    ;VGA
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x86,USB\VID_13d3&PID_5108&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x86,USB\VID_13d3&PID_5118&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x86,USB\VID_13d3&PID_5120&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x86,USB\VID_13d3&PID_5129&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x86,USB\VID_13d3&PID_5130&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x86,USB\VID_13d3&PID_5132&MI_00
    ;1.3M
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5082&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5102&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5104&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5105&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5106&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5113&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5114&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x86,USB\VID_13d3&PID_5133&MI_00
    ;2M
    %SN.USBVideo2M.DeviceDesc% = SN.USBVideo2M.w7x86,USB\VID_13d3&PID_5122&MI_00
    ;3M
    %SN.USBVideo3M.DeviceDesc% = SN.USBVideo3M.w7x86,USB\VID_13d3&PID_5101&MI_00
    [SN.NTamd64.6.1]
    ;VGA
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x64,USB\VID_13d3&PID_5108&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x64,USB\VID_13d3&PID_5118&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x64,USB\VID_13d3&PID_5120&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x64,USB\VID_13d3&PID_5129&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x64,USB\VID_13d3&PID_5130&MI_00
    %SN.USBVideo.DeviceDesc% = SN.USBVideo.w7x64,USB\VID_13d3&PID_5132&MI_00
    ;1.3M
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5082&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5102&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5104&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5105&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5106&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5113&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5114&MI_00
    %SN.USBVideo1M.DeviceDesc% = SN.USBVideo1M.w7x64,USB\VID_13d3&PID_5133&MI_00
    ;2M
    %SN.USBVideo2M.DeviceDesc% = SN.USBVideo2M.w7x64,USB\VID_13d3&PID_5122&MI_00
    ;3M
    %SN.USBVideo3M.DeviceDesc% = SN.USBVideo3M.w7x64,USB\VID_13d3&PID_5101&MI_00
    ATTENTION! if the above method does not work or it manifests itself in the fact that during the shutdown the system freezes and does not turn off, install the drivers 8060_Camera_AzureWave_XP_5853120202
    These are already modified drivers.
    The modification consisted in editing the file: snp2uvc.inf and changing the default camera settings.
    In a line...
    HKR, DefaultSettings, Mirror, 0x00010001, 1
    ... we change 0 to 1 at the end
    Installation is normally done via the PNPINST.exe file
    • 8060_Camera_AzureWave_XP_5853120202.zip (3.36 MB) You must be logged in to download this attachment.
    • Camera_Azurewave_VS011_WIN7_32_z5854000207.zip (3.38 MB) You must be logged in to download this attachment.
  • #4 10743095
    sierars1
    Rate: 43
    To me to ASUSA
    ASUS MODEL: K7010IO
    OPERATING SYSTEM: WIN Vista 32/67 WIN 7 32/64
    • Camera_Suyin_VISTA64_WIN7_64_6585377012.rar (1.62 MB) You must be logged in to download this attachment.
    • Camera_Chicony_VISTA64_WIN7_64_615200260.rar (1.25 MB) You must be logged in to download this attachment.
    • Camera_Suyin_VISTA32_WIN7_32_6585377012.rar (1.6 MB) You must be logged in to download this attachment.
    • Camera_Chicony_VISTA32_WIN7_32_615200260.rar (1.23 MB) You must be logged in to download this attachment.
  • #5 13268788
    kondzio144
    I need help
    I have an Asus U36GS and I also have an inverted image in the camera and I am looking for good drivers I have Windows 8 64 bits
    the hardware ID is
    USB \ VID_04F2 & PID_B1B9 & REV_2061 & MI_00 - this is the first number
    USB \ VID_04F2 & PID_B1B9 & MI_00 - this is the second number
    gives two because I do not know which is correct.
    I would be very grateful for your help
  • #6 13276409
    gradek83
    Help: 930
    Rate: 2103
    By updating the driver, first check the Camera_Chicony_CNF_9059_Win7_64_Z061005200440 driver, if it is OK, do not check the second one.
    • Camera_Intel_Win81_32_VER603947120062226.zip (3.86 MB) You must be logged in to download this attachment.
    • Camera_Chicony_CNF_9059_Win7_64_Z061005200440.zip (1.6 MB) You must be logged in to download this attachment.
  • #7 13436155
    marysia89
    I have an Asus K50I and I also have an inverted image in the camera and I am looking for good drivers I have Windows 7 Starter 32 bits
    the hardware ID is
    USB \ VID_13D3 & PID_5130 & REV_1211 & MI_00
    USB \ VID_13D3 & PID_5130 & MI_00
    Help
  • #8 13440385
    gradek83
    Help: 930
    Rate: 2103
    marysia89 wrote:
    USB\VID_13D3&PID_5130&REV_1211&MI_00
    LINK
  • #9 13441164
    GrzegorzWsparcieAsus
    Help: 11
    The topic is very well described and probably useful for many people. Let me also systematize some issues.
    On our website you can find a video showing how to find the PID and VID of the camera:
    https://www.youtube.com/watch?v=oqXKSDONEbQ&feature=player_embedded
    The drivers can in turn be downloaded from this link:
    http://www.asus.com/pl/supportonly/Camera/#support_Download
    The drivers are sorted and described according to the PID of the device.
The discussion addresses the common issue of inverted images from Asus laptop cameras, with users sharing various solutions. The first method involves adjusting webcam settings to invert the image back to normal. For a more permanent fix, users are advised to uninstall existing webcam drivers and install updated versions. Specific drivers for different Asus models and operating systems are provided, including links to download them. Users also share their hardware identifiers to seek assistance in finding the correct drivers. The importance of checking the PID and VID of the camera for driver installation is emphasized, along with resources for locating these identifiers.
