Asus k52j: Fix Inverted Camera Image on Windows 10 - Skype Call, Built-in Camera & Mic Issues
Ewciak92 47373 17
How can I fix an upside-down built-in Asus webcam in Windows 10?
Install the correct Asus Windows 7 webcam driver for your exact camera model from Device Manager; that is what fixed the upside-down image for the thread starter [#15504964][#15504987] First check the camera identifier in Device Manager, because this model had several webcam variants, and the working driver depends on the exact device [#15504964] Download the Asus driver package, unpack it with 7-Zip, then in Device Manager choose the webcam and update the driver by pointing Windows to the unpacked folder [#19054270] One user reported that the third Asus driver they tried worked and the camera returned to normal [#15504987] If the Asus package still does not work, one reply suggested trying the manufacturer’s Windows 7 driver package for the exact camera, or as a last resort reversing the image with ManyCam or OBS [#19518502]
  • Request for step-by-step fix for inverted camera
    #1 15503570
    Ewciak92
    Rate: 16
    Hello. I have a problem with the built-in camera in Asus. I have had Windows 10 for about a week and today I noticed that my camera was turned upside down when I wanted to make a call via Skype. There was also no sound and the microphone did not work, but I solved these problems. Unfortunately, I have been left with this unfortunate painting and I cannot deal with it. I read that the only option would be to go back to Win 7, but that's not an option :( When it comes to computers, this is black magic to me and I don't know what to do to fix this problem. Please help me with detailed instructions (as for a child :P ) what I should do step by step. I have been struggling with it since the morning and I hope that some good soul will help me solve it.
  • #3 15503996
    Ewciak92
    Rate: 16
    Unfortunately, there are no drivers for Win 10 on the Asus website :(
    Added after 14 [minutes]:
    The description on this page https://www.elektroda.pl/rtvforum/topic3074904.html tells me nothing :(
    I don't even know where to look for that xxx.inf or snp2uvc file, or whatever :(
  • #4 15504124
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Run regedit, go to:
    HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Class \ {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} \ 0000 \ DefaultSettings
    and:
    HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Class \ {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} \ 0000 \ Settings
    Find a Flip there and set it to 1 if it is 0 or vice versa.
  • #5 15504284
    Ewciak92
    Rate: 16
    I did everything in order, but unfortunately I stopped at / 0000 / because still nothing pops up :( There is neither DefaultSetting nor Settings :( I don't know .. maybe I'm doing something wrong? Black magic :(
  • #6 15504823
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Otworz notatnik, wklej do niego:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}\0000\DefaultSettings]
    "Flip"=dword:00000001
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}\0000\Settings]
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}\0000\Settings]
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\Class\{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}\0000\Settings]
    Zapisz pod nazwa fix.reg (nie txt!) i uruchom.
  • #7 15504855
    Ewciak92
    Rate: 16
    I did with this notebook exactly as written. It popped up if it should make changes to my computer and if I want to add it to the registry. I added. Turn the laptop off and on, I checked the webcam hopefully, but unfortunately no changes :( Is it impossible to do this anymore without changing Windows? :( I hope there is still a way out.
  • Third Asus camera driver fixed the issue
    #9 15504987
    Ewciak92
    Rate: 16
    Is it an imaging device from the device manager? If so, then USB2.0 0.3M UVC WebCam. Aleee ... if I wanted to set up in the Skype settings, apart from that, USB2.0 .. There was also Asus Virtual Camera, and the device manager does not have it.
    Added after 24 [minutes]:
    The third driver from Asus worked :)
    I am so happy! I don't know how to thank you! :)
    I thought that nothing can be done without changing the system, and here you are :)
    And thank you for your persistence in explaining to me like a child :)
  • #10 19044276
    bum78
    Hello, I have the same problem, you can tell me which driver worked. I am struggling with this problem and there is nothing I can do about it. I have an Asus K52F, I installed Windows 10, reversed camera I have read various forums and there are always some problems, nothing works.
  • #11 19044287
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ bum78 what's your camera Enter the identifier from the device manager (pid and vid). For this try to install drivers for W7 (proper).
  • #12 19044682
    Gienek
    Level 37  
    Help: 393
    Rate: 353
    I have the same computer. I took advantage of this (attachment). Everything is back to normal :D
    • Camera_Chicony_VISTA64_WIN7_64_615200260.zip (1.34 MB) You must be logged in to download this attachment.
  • #13 19054256
    Regularna
    Mr. Gienek,
    if I may ask, I would love to know how to install these drivers step by step. Thank you in advance
  • #14 19054270
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    You download, unpack (7zip), install from the device manager by selecting the camera driver updates and selecting the directory with unpacked drivers as a source.
  • Asus K52jc webcam upside down on Windows 10
    #15 19518460
    kamko3
    Rate: 9
    Good morning, I have a similar problem. My computer is an Asus K52jc. After updating the system to win10 home, my webcam works but upside down. My webcam is: USB VID_04F2 & PID_B1E5 & REV_2069 & MI_00
    USB VID_04F2 & PID_B1E5 & MI_00
    Thank you in advance for your help. I would like to mention that I have already installed all the drivers for win7 and there are no drivers anywhere on win10, please help. Regards.
  • Windows 10 lacks working Asus k52j camera drivers
    #16 19518476
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Sure, there is no, since the last drivers were released 11 years ago under W7, there are no others.
    If these don't work after manual installation https://dl.driverpack.io/driverpacks/repack/W.../Chicony-Sonix-WinAll-061.005.200.440_CNF7129 then-drp.zip that the camera will not work under W10, and it offers terrible quality anyway, there is no point in using it. Buy a modern USB camera.
  • #17 19518492
    kamko3
    Rate: 9
    Thank you for the answer, unfortunately my webcam is still working but upside down. I know that my predecessors came to an agreement with the webcam and it finally worked for them. A portable USB webcam does not suit me because I work a lot in the field and I need to have as little equipment as possible. If someone has an idea how to solve the problem, please help and greetings.
The discussion revolves around an issue with the built-in camera of the Asus K52J laptop, which displays an inverted image after upgrading to Windows 10. Users shared various troubleshooting steps, including editing registry settings and installing drivers. One effective solution involved creating a registry file to adjust the camera's "Flip" setting. Users also suggested checking for compatible drivers from Windows 7 and using third-party software like ManyCam or OBS to flip the camera image if necessary. Despite some users facing difficulties, one participant successfully resolved the issue by installing the correct driver from Asus's website.
