Rectifier Diode Current Flow: Direction from Point A to B, Positive or Negative?
done 83603 9
How does current flow through a rectifier diode between points A and B, and which point should be positive or negative?
A rectifier diode conducts when its anode is at a more positive voltage than its cathode, so conventional current flows from anode to cathode; the cathode, marked by the stripe, should be connected to the negative side of the supply [#1044187] [#1044519] If the two voltages are both negative, the less negative one is still the more positive one, so current flows from that point toward the more negative point [#1045219] Electrons flow in the opposite direction, from negative to positive [#1044216]
  • #1 1044162
    done
    Help: 11
    Rate: 58
    Hello, I have such a trivial question, please write me in what direction the current flows through the rectifying diode from point A to B. Ie. is there + or - at point A . Where in fig 2. there are points A and B in Fig. 1. Greetings.
    • Rectifier Diode Current Flow: Direction from Point A to B, Positive or Negative? dioda df06.jpg (6.9 KB) You must be logged in to download this attachment.
  • #2 1044187
    zodiak318
    Help: 249
    Rate: 306
    In order for the diode to conduct, the cathode (strip) must be connected in the "-" side of the power supply, ie in Fig. 2 it is the other way around.
  • #3 1044216
    silvvester
    Help: 25
    Rate: 168
    and to make it happier, the electrons flow from the negative to the positive pole :)
    but contractually it is as a colleague wrote.
  • #4 1044350
    done
    Help: 11
    Rate: 58
    Thank you very much for the answer. So this drawing is good :) greetings
    • Rectifier Diode Current Flow: Direction from Point A to B, Positive or Negative? dioda df06 dobry.jpg (6.68 KB) You must be logged in to download this attachment.
    zodiak318
    Help: 249
    Rate: 306
    I confirm :) .
  • #6 1044442
    KKK
    Help: 152
    Rate: 63
    The questioner did not specify what this information was needed for, and now looking at these drawings, I think whether it will end up with shooting off some 8O electrolyte.
  • #7 1044519
    Paweł Es.
    Help: 1236
    Rate: 693
    Unfortunately, nothing beautiful is obvious. While Catholic, Lutheran, Pentecostal (i.e. generally Western) LEDs have a cathode where there is a dash (or a spot) on the housing, Orthodox and non-believing LEDs (from the former USSR) have the reverse designation and the color means the anode. This should be taken into account and always check the diodes of unknown origin with a tester.
    ANODA           KATODA
    For the diode to conduct this, the anode must have a more positive voltage than the cathode.
  • #8 1044674
    kilerOS
    yes in forward direction for silicon 0.7V potential difference, for germanium 0.3V :)
    probably out of politeness and not messing with your colleague, you missed the fact that diodes were conducted in the opposite direction, called the zener effect :)
    The first page in the search engine shows us this:
    http://www.tranzystor.pl/tekst/teksty/a_elementya.txt.html
    Cheers, KilerOS.
    PS.
    and if both potentials are negative, which voltage is more positive?
  • #9 1045219
    Paweł Es.
    Help: 1236
    Rate: 693
    A colleague, who was also polite, asked in the first post about a RECTIFIER diode where the Zener effect occurs at such voltages that it is useless and when it occurs it usually only once and involves the need to replace the element.
    and if both potentials are negative, which voltage is more positive? [/ quote]
    If we have -5 and -4.3 then -4.3 is more positive (i.e. greater) than -5, so the current will flow from the -4.3V point to the -5V point.
  • #10 1045687
    Vujek
    congratulations on your ingenuity
    we have more positive and more negative tensions
    all in all a cool, humorous term ...
The discussion centers on the direction of current flow through a rectifier diode, specifically from point A to B. It is clarified that for the diode to conduct, the cathode must be connected to the negative side of the power supply, while the anode should have a more positive voltage. The flow of electrons is from the negative to the positive pole, and it is noted that the potential difference required for silicon diodes is approximately 0.7V, while for germanium diodes it is about 0.3V. The conversation also touches on the Zener effect and the importance of checking diode orientation, especially with diodes of unknown origin. The participants emphasize the need to understand the voltage levels, even when both are negative, to determine the current flow direction.
