Why does current in a circuit flow from positive to negative?
turbolax 88850 8
  • #1 4249852
    turbolax
    Help: 9
    Why does the current in the circuit flow from positive to negative? and who is behind it? I have such a problem, help me
    LuckyDj
    Help: 186
    Rate: 192
    Actually, it flows from minus to plus! But contractually it is as you wrote.
    The current flows from negative to positive, because the current is electrons and the electrons have a negative charge, so they accumulate in the "minus". For the current to flow, there must be a potential difference, and such a difference is in a closed circuit and electrons from where there are more of them flow there where there are fewer of them, which is a plus.
    I think I remember well from school ;) What?
    Quarz
    Help: 1646
    Rate: 629
    it is a matter of a generally accepted contract, but in reality it can be different depending on what is the carrier of the (negative, positive) electric charge.
    In conductors, the charge carriers are negatively charged electrons and their real direction is opposite to that assumed as positive.
    In electrolytes where ions move, this direction is both ways: positive cations go to the negative cathode, and negatively charged anions go to the positive anode.
    In semiconductors, this charge movement is even more complicated, so let me give you a description of it.
  • #4 4249962
    turbolax
    Help: 9
    and I found this on one of the pages what do you think about it?
    "flows from plus to minus (i.e. from higher to lower potential). Well, it is absolutely true, this is how the direction of the electric current (opposite to the movement of electrons) was assumed! electrons move in the opposite direction. "Oh, and you don't know who came up with this proposition ??
    robolupo
    The current flows from plus to minus because historically an elementary charge has been defined as the value of the charge carried by a proton or the absolute value of the charge of an electron. In college, we were taught that the current flows from plus to minus because electrons move from minus to plus one by one, leaving behind empty spaces (in a positively charged crystal lattice, in which something like electrons are floating in the energy conduction band - I think that's good I wrote). Such open spaces are called electron holes, and since their charge is not balanced by any electrons (like an electron hole - there is no electron there), it has a positive charge. Such a free space is replaced by another electron, which leaves behind a free space for another electron to enter etc ... and so the electrons move like cars in a line, and the gaps between them are taken by subsequent cars coming from the back, so such a break gives the impression that it is moving to the back of the queue. phew! That is why the current flows from positive to negative. Or as a colleague wrote above about ions. Greetings.
  • #6 4252569
    turbolax
    Help: 9
    ok thanks for your help
  • #7 15075880
    Carniv0re
    As far as I know, the current flows from plus to minus and the voltage from minus to plus.
    The direction of the current is historically accepted, but the voltage has already been "improved".
  • #8 15075984
The discussion centers on the flow of electric current in circuits, which is conventionally described as moving from positive to negative. This is a historical convention, as the actual flow of current is due to negatively charged electrons moving from the negative terminal to the positive terminal. The responses clarify that in different contexts, such as conductors, electrolytes, and semiconductors, the behavior of charge carriers can vary. In conductors, electrons flow from negative to positive, while in electrolytes, both positive ions (cations) and negative ions (anions) move towards their respective electrodes. The concept of "holes" in semiconductors is also introduced, where the movement of electrons creates the appearance of positive charge movement. The discussion concludes with an acknowledgment of the historical context of these definitions.
