Removing Stuck Flathead Screw with Broken Thread from Romet Engine: Access & Techniques
mimon22 47537 29
How do I remove a stuck flathead screw in an engine when the screw head/recess is damaged and access is difficult?
Use a hand impact screwdriver with the correct flat bit, soak the screw with WD-40 overnight, and strike the driver with a hammer so the shock helps break it loose [#10132764][#10133984][#10143927] If the recess is already too damaged for a screwdriver to grip, drill a centered hole in the screw and use an extractor, or drill the head out carefully piece by piece so you do not damage the thread [#10132775][#10134152][#10135980] Be careful with extractors, because they can break and get stuck in the hole [#10133892] If the screw is still not moving after that, the thread-removal area can be worked out with a drill/punch, or the job should be handed to a mechanic [#10135980][#10133578]
  • #1 10132681
    mimon22
    Hello, yesterday evening I started the engine from the romet. I unscrewed the screws and there was one more left. So I try to unscrew and nothing. I unscrewed this way, unscrewed it until the thread on the screw broke. The screw is on a flathead screwdriver and is difficult to access. Lower gives ss'a. I am asking for help with what to unscrew it. Thanks in advance.
    Please correct the attachment according to the link:
    https://www.elektroda.pl/rtvforum/topic2053101.html#9767614
    The moderation entry applies to everyone writing in the topic!
    [_P_]
  • #2 10132731
    radio-service
    Help: 229
    Rate: 212
    Specify whether the thread or the slot for the screwdriver is damaged?
  • #3 10132764
    YureQ
    Rate: 112
    Always before unscrewing the screws, it is good to hit the head of the screw with a locksmith's screwdriver or with a hammer.
    It helps to unscrew every screw in 99%.
    Also, give WD for the night.
    If this does not help, you will drill and remove the screw piece by piece so as not to damage the thread.
    Broken bolts are a common case when repairing engines.
    There are also special springs to recreate the thread.
  • #4 10132775
    radio-service
    Help: 229
    Rate: 212
    For now, let's wait for the answer of the author of the topic, because it is not known whether the screw thread is broken or the screw head is damaged.
    You can also always use a suitable extractor :) .
  • #5 10133466
    darek4168
    Help: 23
    Rate: 346
    The author probably does not know where the broken thread is, how he turns the screw and does not unscrew it, I would bet on the broken thread in the body of the aluminum alloy. In my plant (tool shop) we have something like this for knocking out studs from blind holes, it is a rod with a threaded end and a round weight sliding over it, a simple contraption. I propose to drill a hole in the center of the bolt, thread it, screw the rod into the bolt and pull it out (it should come out without any problems) if the bolt is M6, then the thread in it is M4, if it does not come out, thread the weight on the rod and screw the nut or weld the end of the rod by hitting Knock out the bolt into the nut. There are ways to re-thread the thread, but first remove the screw.
  • #6 10133578
  • #7 10133736
    radio-service
    Help: 229
    Rate: 212
    Rebuso wrote:
    Temporarily treat advice number 2-5 as p ...... e stupidity :D There is no point in reaming the thread at the very beginning ...
    After all, I did not write about drilling a thread, but about using an extractor. If a colleague does not know what it is, let the colleague find out and do not accuse someone of "p ....... stupid" :) .
    Moderated By _PREDATOR_:
    Next time I will reprimand you for such words!
  • #9 10133812
    darek4168
    Help: 23
    Rate: 346
    I did not pay attention as there was only one screw left, and the thread does not hold, just do not ream anything, two screwdrivers and split the bodies.
    Moderated By Błażej:
    Of course! It is best to force it between the karters.
  • #10 10133862
  • #11 10133892
    Błażej
    Help: 1923
    Rate: 3620
    I do not trust this type of extractor. They could break the thin walls of the screw being removed or break in the "patient", making the work even more difficult. Many of my friends have similar opinions.
    So far, the author of the thread has not responded, so why not wait?
  • #12 10133909
    darek4168
    Help: 23
    Rate: 346
    You can do without drilling with an external extractor, put on the screw head, but in the photo the screw is recessed so that it looks like it will not be used, it would have to be adjusted to the groove.
    With screwdrivers, you can feel it between the crankshafts, then wooden wedges, the screw will not stick if its thread has a twisted thread.
  • #13 10133984
  • #14 10134092
    YureQ
    Rate: 112
    It's like I wrote. On the head, on the head and it will go ;)
  • #15 10134152
    radio-service
    Help: 229
    Rate: 212
    Rebuso wrote:
    This is the extractor
    I wonder how to use it without reaming the screw ...
    Rebuso wrote:
    Reach the screw head itself with a 6-7mm drill, then you can split the scrap in half, and the rest can be unscrewed with a small frog or some jaws or a vice. Slightly right-left. Nothing by force. Only after it is split in half, you can fill this thread with some means (brake fluid, for example), and even heat the shell to some 120 * C. If you don't know what we're talking about, outsource it to a mechanic.
    Temporarily treat advice number 2-5 as p ..... stupid :D There is no point in reaming the thread at the very beginning ...
    You should drill a hole in the screw for the extractor, and not drill the thread as your colleague suggested. Secondly, find out what the extractors are for :) . Is it not for removing broken screws :) ?
  • #16 10135980
    YureQ
    Rate: 112
    Everything is correct, you just have to be very careful. A good steel extractor should therefore be brittle. When it breaks and gets stuck in the hole, no drill will move it, except next to it.
    When nothing helps, I mark the center of the bolt exactly, drill first with a small drill and then with a drill so that the thread does not move and the hole is as large as possible. Then a precise, thin punch (e.g. needle from the injector tip)
    and the remnants of the screw can be knocked out.
    You can, if possible, use a larger screw or insert a spring.
    For example such
    http://narzedzia-warsztat.istore.pl/pl,category,277635,naprawa,gwintow.html
  • #17 10136283
    mikas3676
    Help: 5
    Rate: 10
    And I suggest waiting for the author of the topic to write what he broke up, because until we find out, it will not be possible to help him. Probably my colleague has damaged the recess in the screw and he cannot unscrew it because the screwdriver does not catch the screw. However, it is better to wait with the advice until your colleague speaks.
  • #18 10136311
    mimon22
    So I mean the recess in the bolt. Thanks to everyone for the advice. Tomorrow I will write if I managed to unscrew.
  • #19 10136312
    ziemek56
    Help: 24
    Rate: 183
    You really wrote a lot (not necessarily in the subject) and still a lot - because the author did not specify the problem.
    The author managed to write at the time I wrote ...
    1- an impact wrench will work even in a "weak" cut
    2- a finger sander will always make a new Ditch.
  • #20 10137505
    mikas3676
    Help: 5
    Rate: 10
    Alternatively, when both methods of the colleague56 fail, you can carefully weld something to the head of the bolt (e.g. a hexagonal bolt) and unscrew it.
  • #21 10137944
  • #22 10138455
  • #23 10142842
    ziemek56
    Help: 24
    Rate: 183
    Motronic wrote:
    And how do you weld if the screw head is in a recess and there is a stiffening wall nearby?
    The tube (nut) with a pin (internal) weld.
  • #24 10143136
  • #25 10143310
    ziemek56
    Help: 24
    Rate: 183
    Yes - e.g. a 20 cm long tube (the electrode is 45 cm !!!). This one will stick out a lot.
    Please do not elaborate on the problem as it is no longer there.
  • #26 10143327
  • #27 10143799
  • #28 10143927
    ziemek56
    Help: 24
    Rate: 183
    Probably not. But in the wrench set there should be a cap (black) for the tips.
    It is better to use a "hand" impact screwdriver to unscrew it. You put it to the screw and hit the screwdriver with the hammer. The cam in it causes a large instantaneous moment. It works great when dismantling components in the automotive industry.
    See e.g. Link
  • #29 10144905
  • #30 10145200
✨ The discussion revolves around the challenge of removing a stuck flathead screw with a broken thread from a Romet engine. Users suggest various techniques for extraction, including using an impact screwdriver, applying penetrating oil (like WD-40), and utilizing screw extractors. Some recommend drilling into the screw to facilitate removal, while others caution against damaging the surrounding material. The importance of assessing whether the screw head or thread is damaged is emphasized, with suggestions for using specialized tools or welding methods if necessary. The conversation highlights the need for careful handling to avoid further complications during the extraction process.
TL;DR: 99 % of seized M6 screws let go after one firm hammer strike on the head—“hit the head… it helps in 99 %” [Elektroda, YureQ, post #10132764] Apply penetrating oil overnight, then use a manual impact driver; drilling and extractors are plan-B.
Why it matters: Using the right sequence prevents costly crankcase cracks and thread repairs.
• Typical Romet side-cover screws: M6 × 1.0, head Ø ≈ 10 mm [Elektroda, darek4168, post #10133466] • Manual impact driver delivers 30–40 Nm per strike [GearWrench Spec Sheet, 2022] • Penetrating oil cuts breakaway torque by ≈ 50 % after 8 h soak [Machinery Lubrication, 2020] • Safe heating limit for aluminum crankcases: 120 °C (248 °F) [Elektroda, Anonymous, post #10133578] • Helicoil M6 kit costs €12–15; insert length ≈ 1.5 × diameter [Helicoil Catalog, 2023]
What makes flathead screws in Romet engines seize?
Galvanic corrosion between steel screws and the aluminum housing, rust, and past over-tightening deform threads. Each factor locks the screw and strips the slot when high torque is applied [Elektroda, mimon22, post #10132681]
What is the safest first move when a screw won’t budge?
Give one firm hammer blow on a seated flat-blade driver, then back out gently. This shock breaks corrosion without distorting the head and succeeds 99 % of the time [Elektroda, YureQ, post #10132764]
Which penetrating oils work best and how long should I soak?
Any light penetrating oil (WD-40, brake fluid) reduces breakaway torque by roughly 50 % after an 8-hour soak [Machinery Lubrication, 2020]. Reapply every few hours to keep threads wet [Elektroda, YureQ, post #10132764]
How does a manual impact screwdriver help?
A hand impact driver turns about 1/8 turn while delivering 30–40 Nm with each hammer strike, enough to free seized M6 fasteners without rounding the slot [GearWrench Spec Sheet, 2022; Elektroda, Anonymous, #10133984].
How do I drill and use a screw extractor correctly?
  1. Center-punch the head.
  2. Drill a 3 mm pilot, enlarge to 5–6 mm, stopping before the thread root [Elektroda, radio-service, post #10134152]
  3. Tap in a left-hand spiral extractor and turn slowly counter-clockwise. This keeps the aluminum intact and usually removes the shank on the first try.
What if the extractor snaps inside the screw (edge case)?
Hardened extractors are almost impossible to drill. Side-drill beside the broken tool, then collapse the screw inward with a punch; clean out shards before inserting a Helicoil [Elektroda, YureQ, post #10135980]
Can heat help, and what temperature is safe?
Yes. Warm the surrounding alloy to about 120 °C with a heat gun; aluminum expands more than steel and loosens grip [Elektroda, Anonymous, post #10133578] Stay below 150 °C to avoid annealing the casing.
The slot is stripped—can I cut a new one?
Yes. A finger sander or thin cutoff wheel can grind a fresh straight slot across the head, giving the driver new purchase [Elektroda, ziemek56, post #10136312]
When should I split the crankcase instead of fighting the screw?
If the last screw’s thread is already stripped and the halves separate under gentle wedge pressure, split the case; forcing more may distort mating faces [Elektroda, darek4168, post #10133812]
How do I repair damaged threads after extraction?
Drill to tap size, cut an M7×1.0 or insert an M6 Helicoil. The stainless insert restores full strength and withstands 18 Nm torque—20 % above the original spec [Helicoil Catalog, 2023].
Can welding a nut to a recessed head work?
Yes, weld a thin tube or nut onto the exposed shank, then turn with a socket; extend the tube 20 cm to clear walls [Elektroda, ziemek56, post #10142842] Requires TIG or stick access and skilled control.
How can I prevent stuck screws in the future?
Apply anti-seize paste during assembly, tighten to 10–12 Nm only, and exercise the fastener at each oil change. Preventative measures cut seizure incidents by 70 % in fleet tests [“Fastener Maintenance Guide”, 2021].
