Tap Water Quality: Comparing Cold vs Warm Water Parameters, Bacteria, Nitrates & Taste
KSRhaziel 32399 18
Why do hot and cold tap water show different test parameters, and is hot tap water less safe or worse to drink?
Hot tap water is usually just cold water that has been heated, so the differences you measure come mainly from temperature effects and the hot-water circulation system, not from a different water source [#10298803][#10299862] Heating changes solubility, can drive off dissolved gases, and can decompose bicarbonates so carbonates precipitate, which affects hardness, pH, taste, and scale formation [#10297615][#10299862][#10300694] Hot water also circulates in a closed loop and goes through repeated heating/cooling cycles, so it can pick up more deposits from pipes than cold water that has simply stood in the line [#10299862][#10300901] For hygiene, the installation should keep hot water at 55–60 °C at the tap and allow periodic thermal disinfection at 70–80 °C to reduce Legionella risk [#10313232][#10309876] In older systems, exchanger leaks could let technical water contaminate the hot-water side, but modern plate heat exchangers are separated circuits and are monitored [#10298803][#10315023][#10347560]
  • #1 10297381
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    More than once I have heard that supposedly water in the tap, depending on whether it is cold or warm, has different "parameters". Apparently, hot water is not as purified as cold water and it can cause more bacteria, etc. I would like to dispel myths and my doubts. While searching internet forums, I found two statements:
    Hot water is the same as cold water with the difference that after passing through heat exchangers, some water quality indicators, especially the taste ones, usually deteriorate due to the evaporation of some compounds. Also, importantly, the disinfectant (chlorine dioxide) disappears in the water, which may favor the appearance of undesirable bacteria.
    I did the water tests today and I have heard the difference well, however. It may not be that important, but it is ;)
    WARM
    Nitrates 0
    GH 8
    KH 17
    Ph 8.5
    COLD
    Nitrates 0
    GH 6
    KH 13
    Ph 7.8
    It follows that it is better to just heat it with cold :D
    So is there maybe someone who is familiar with this topic and would like to explain how it is in reality?
  • #2 10297615
    Tommy82
    Help: 455
    Rate: 1074
    When it is heated, the ability of the water to dissolve things changes.
    Therefore, for example, limescale builds up in the kettle. Well, no matter where the water from the kettle settles, it won't have it either.
    There is also something like Legionella and hot water strings are to be able to temporarily raise the temperature just for disinfection purposes.
  • #3 10298803
    Artur k.
    Help: 1279
    Rate: 1701
    As far as I know, hot water is nothing but heated cold water. Hot water comes from the heat and power plant (often above 100 degrees Celsius), in the heat exchanger it heats the cold water from the network and goes to the taps.
    Hot tap water should have the same properties as cold water heated in any way (e.g. with a kettle) to the same temperature.
    A heat exchanger is like a transformer - it has a primary circuit and a secondary circuit (as in the winding transformer), the circuits are not in direct contact with each other. Hot water from the network is actually dirty and as such is only suitable for central heating (it is used for this purpose). Nothing to do with drinking water.
  • #4 10299167
    Stefan_2000
    Help: 36
    Rate: 39
    Artur k. wrote:
    the circuits do not have direct contact with each other
    Well, not always. After years, heat exchangers may start to leak, if they leak "outside", sooner or later someone will notice it, but if there is a leak "inside", people will get an addition of industrial water to the hot water, because water in the network has a higher pressure.
    Apparently, during the People's Republic of Poland, technical water (overheated steam?) From the mains was colored (or some fragrances were added, I don't know) just to detect leaks in exchangers.
    Therefore, it is a very silly idea to take hot tap water for making tea :-)
    kisses,
    St.
  • #5 10299371
    Artur k.
    Help: 1279
    Rate: 1701
    Yes and no. In the past, it could have been so, now in practically every heat node there are appropriate electronic systems that control the temperature and pressure of both circuits as well as the temperature and pressure of the returns (the return is colder). If something is wrong - they turn it off, it works a bit like an electric RCD. On the basis of this data, the controller is able to show how much energy the building consumes on its display.
    I don't know much about it, so I won't go into the details. I know what my uncle, who has been dealing with this for 30 years, told me.
  • #6 10299862
    lynx22
    Help: 5
    Rate: 27
    As Artur near. Warm water is warmed up cold. The differences in parameters result from the fact of changes taking place under the influence of temperature (e.g. decomposition of bicarbonates, which in turn leads to the precipitation of carbonates). In addition, cold water with the tap turned off "stands in the pipes, and hot water circulates in a closed circuit all the time, which ultimately results in many heating and cooling cycles.
  • #7 10300433
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Let me make the following quote:
    On the Bergamut Islands
    Apparently there is a puss in boots,
    The donkey was also seen,
    Whose ant was carrying,
    There is a playwright
    Laying golden eggs
    Apples grow on the oaks
    In ermine caps,
    There is also an old whale,
    What wears glasses
    Moons are learned
    In tomato sauce
    And trained rats
    On top of a glass mountain
    There is an elephant with two trumpets
    And only ... these islands do not exist.
    Whether hot steam is circulating in the network or superheated steam does not really matter, after all, both substances are the same H2O. In the People's Republic of Poland, everything was possible, even coloring and giving the smell of overheated water vapor.
  • #8 10300629
    Janusz
    Help: 29
    Rate: 18
    What my colleagues write out is pure theory.
    In practice, the hot water that flows from the tap is unfortunately more polluted.
    In my house, the screens next to the faucets or aerators are often clogged - only those "on the hot side".
    Often also after a temporary lack of water - heat is just one muck ...
  • #9 10300694
    tronics
    Help: 358
    Rate: 841
    @Janusz - my colleagues clearly indicated that there are temperature dependencies on the solubility of many substances (including chlorine, oxygen, co2, as well as bicarbonates and ferrates) in H2O. For this reason, in many cases domestic hot water pipes and valve filters on the domestic hot water side most often get "in the butt" - in my case, precisely because of ferrous materials. A dozen or so km away, another water supply plant, a different chemical composition. and the dominance of calcium and magnesium carbonates. In addition, there is the case of legionella, which has already been mentioned: http://pl.wikipedia.org/wiki/Legionella - in cold water pipes it does not have such conditions for development as in boilers and hot utility water pipes.
  • #10 10300901
    Artur k.
    Help: 1279
    Rate: 1701
    Janusz - this muck is just dried rust, it also flies from the cold. There is more flow from the hot one, because you have circulation and the water has to travel twice as long - so it will collect twice as much muck from the pipes. Circulation is needed for the residents of the last floors of a multi-story building to have hot water immediately after turning on the tap. If there was no circulation, you would have to wait for the water from the basement heat node to reach the top floor. Not only is it inconvenient for the inhabitants, but also a terrible waste of water.
  • #11 10309876
    Chris_W
    Help: 386
    Rate: 1051
    I don't know much about it, so I won't go into details. I know what my uncle, who has been dealing with this for 30 years, told me.
    For the sake of accuracy - the primary circuit is not regulated in terms of temperature or pressure (it belongs to the heating plant), but only the flow - solenoid valves set such a flow on the primary one to obtain the set parameters (temperature) on the secondary one. The node controller should (and most often has) periodically raising the temperature on the secondary in order to sterilize the installation.
  • #12 10311713
    Artur k.
    Help: 1279
    Rate: 1701
    That's right - the primary circuit temperature is not regulated but monitored. On this basis, the energy consumption is calculated. And on this basis, it is quite easy to find a leak - the usual energy balance.
  • #13 10313147
    Mirosław Śmielak
    Colleague Chris_w and Artur k. - take care of your statements about electronics, because maybe you are more oriented there. Who has heard of the periodic increase in water temperature for sterilization? valves of the Samson type (older installations) or electronically controlled, which self-regulate and maintain the set temperature.
    steel) and corrosion, as well as economic and safety factors
    The boiler scale and water contamination (stagnation in rarely used sections of the installation) cause water contamination.
    monitoring? if there is a leak, you can see it. Penetration of so-called SPEC water
    it was possible in the old type of "Jad" exchangers, but these are no longer used
    in residential buildings, and that was it.
  • #14 10313232
    tronics
    Help: 358
    Rate: 841
    Who has heard of periodically raising the water temperature for sterilization?
    Well, here is a quote from Wikipedia, thank you friend for such an interesting and valuable comment.
    One of the basic principles of adapting hot water installations to measures reducing the risk of Legionella infection is laid down in the Regulation of the Minister of Infrastructure of April 12, 2002 on technical conditions to be met by buildings and their location (Journal of Laws of 2002, No. , No. 75, item 690, as amended - Journal of Laws of 2009, No. 56, item 461). Regulation § 120 sec. 2 reads: "The hot water plumbing should be able to obtain water at the inlet points at a temperature not lower than 55 ° C and not higher than 60 ° C." in paragraph 2a reads: " The hot water plumbing system should allow for continuous or periodic disinfection by chemical or physical method (including periodic use of the thermal disinfection method), without reducing the durability of the installation and the products used in it. For thermal disinfection, it is necessary to ensure that the water temperature at the points of use is not lower than 70 ° C and not higher than 80 ° C. .
  • #15 10313413
    lynx22
    Help: 5
    Rate: 27
    The last two statements are not exclusive. Installations are adapted to increase the temperature in the circulation, but rather it is not done periodically, only when the presence of bacteria is detected.
    My expensive Wikipedia is not a reliable source of information for me, but only an indication of where and what to look for.
  • #16 10314788
    bonanza
    Power inverters specialist
    Help: 283
    Rate: 424
    Rather periodically.
  • #17 10315023
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Mirosław Śmielak_ Yeah, everything is clear, but you forgot to add that each heat exchanger, not only the famous JAD, can have an internal leak, and a lot of interesting chemicals are added to the primary circuit (flowing through the boiler piping) to soften this water to protect the installation from precipitation scale, and corrosion inhibitors.
    Bon Appetit
  • #18 10316745
    Artur k.
    Help: 1279
    Rate: 1701
    Rozporządzenie Ministra Infrastruktury z dnia 12 kwietnia 2002 r. w sprawie warunków technicznych, jakim powinny odpowiadać budynki i ich usytuowanie. wrote:
    2. The hot water installation should ensure that the water temperature at the tap points is not lower than 55 ° C and not higher than 60 ° C, and the installation should allow for its periodical thermal disinfection at a water temperature of not less than 70 ° C.
    http://isap.sejm.gov.pl/DetailsServlet?id=WDU20020750690
    Although the CW temperature is indeed set to 55 degrees. Only if someone questioned it, Mr. Buddy Mirosław Śmielak ?
  • #19 10347560
    Mirosław Śmielak
    Answering K. Kamieński, I explain that the currently produced plate heat exchangers are made of acid-resistant steel and the leaks we are talking about do not occur (they do not corrode like the old JADS). accumulated sediment, but then you have to turn off such an installation. Inhibitors are used in installations which are also recommended there.
The discussion centers on the differences in quality between cold and hot tap water, particularly regarding parameters such as bacteria presence, nitrates, and taste. Participants clarify that hot water is essentially heated cold water, but it can be more contaminated due to factors like stagnation in pipes and the potential for leaks in heat exchangers. Hot water systems often circulate water, which can lead to the accumulation of impurities. Concerns about bacteria, such as Legionella, are raised, emphasizing that hot water systems can create conditions conducive to bacterial growth. The conversation also touches on the technical aspects of heat exchangers and the importance of maintaining water quality through proper temperature regulation and monitoring.
