And why do people pour cold water into the kettle and not warm water?
Marcin125 12327 49
  • #1 18305849
    Marcin125
    Help: 50
    Rate: 282
    From the tap, of course ... Such a life observation came to me ... :|
  • #2 18305853
    stanislaw1954
    Help: 2013
    Rate: 4673
    To spend more on heating water.
  • #3 18305862
    Robert B
    Help: 2027
    Rate: 1412
    If it is hot water in the block from the exchanger, there was already such a loud case that the mother wanted to make a soup for the little child faster and used warm tap water. Unfortunately, the exchanger was leaky and treated water from the district heating network was leaking into the drinking water. The little child died.
    I never use warm city water for food.
  • #4 18305895
    Michelson
    Help: 82
    Rate: 305
    I live in a house and before the heat is released, I would have to use too much water, which is pointless. It's a waste of water. The second thing is that hot water is always more expensive than cold water.
  • #5 18305954
  • #6 18305975
    Robert B
    Help: 2027
    Rate: 1412
    Wiatki used to be connected to cold and hot water.
  • #7 18305988
    Rezystor240
    Help: 689
    Rate: 1651
    Because it just doesn't pay off ...
  • #8 18306031
    Ture11
    Help: 573
    Rate: 1130
    Because not everyone has hot water from a heating plant and not everyone has a circulation circuit for such water. This means that even if the water is from the heating plant, there is a lot of cold water (in the absence of circulation) in the section between the exchanger and the tap, which would have to be drained.
  • #9 18306081
    karolark
    Help: 702
    Rate: 2516
    Still possible presence of legionella :cry: .
  • #10 18306140
    Wojtek M
    Help: 520
    Rate: 1125
    Of course!!!!! Wężyk! Wężyk! As Saint P. Jan Kobuszewski.
    Even if you have hot water from your own electric boiler or with a coil, it should not be used for food.
  • #11 18306146
    Robert B
    Help: 2027
    Rate: 1412
    EDIT:
    I explain that the most important thing is water heated in exchangers by a thermal power plant. However, for the reasons given later by @wojtek__ M I wouldn't recommend drinking it either.
  • #12 18306173
  • #13 18306176
    Wojtek M
    Help: 520
    Rate: 1125
    To my colleague "Robert B". I praised your post and you are nervous. I just wrote that even if you have hot water from your own electric boiler, where it cannot be mixed with any other water (warm city water), it should not be used for food purposes (magnesium anode, bacteria).
    Regardless of everything.
  • Hot water from the mains tastes like plastic
    #14 18306186
    jurand87sca
    Help: 207
    Rate: 317
    So maybe me. For about a year or a half, the building has hot water from "mzec". However, for cooking and even "brushing your teeth" this water in my opinion is not suitable because it "tastes like plastic" .. I do not know how to name it exactly, but it has aftertaste of chemistry? The price, the price, and so apparently now it is very cheap compared to what will be soon per cubic meter, at least in my city.
  • #15 18306222
    Robert B
    Help: 2027
    Rate: 1412
    @wojtek__ M I thought you were kidding me. So I am so sorry :)
  • #16 18306239
    Wojtek M
    Help: 520
    Rate: 1125
    Nothing happened.
    Regards. Wojtek M.
  • #17 18306307
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Bieda z nędzą wrote:
    And the dishwasher,
    I connected it to the warm one and it's ok.
    Why should I pay for heating the water with electricity?
    I have Amica and it can be connected to cold or warm.
  • #18 18306437
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    I just always pour a "glass" of water into the kettle.
    Someone is about to say he won't drink the stone :) yes, but:
    - I always rinse the kettle
    - a kettle with a flat bottom
    Believe me, these 0.35l in a 2kW kettle boils so quickly that sometimes a person will not manage to grasp the contents of the glass.
  • #19 18306444
    karolark
    Help: 702
    Rate: 2516
    I have the same, I pour the same amount, unless there is a locust at home :D
  • Habitual use of cold water for kettle filling
    #20 18306546
    damian1115
    Level 37  
    Help: 393
    Rate: 904
    I think it is also a kind of reflex, I have no idea what caused it, because in my case I have a gas boiler in the bathroom. So I am not exposed to pollution from the heating network. But despite the fact that I use hot water, it would be a problem to add water to the kettle. But it happens differently, against the logic, I turn off the hot water and fill the kettle with cold water. In a way, "stupidity".
  • #21 18306556
    michios11
    The heat will do faster :D
  • #22 18306837
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    It may sound clichéd but probably YouTube Adbuster or some other native "scientist" made calculations whether it pays to pour hot water into the kettle, as I remember correctly based on the heating water and it turned out that it does not pay off. :)
  • #23 18307409
    BANANvanDYK
    Help: 1167
    Rate: 2601
    The old days when 5-10 people were left overtime every day and Amino was provided by the company. A kettle filled with hot water can boil much faster (about 1 minute) and this is the main practical justification. Hot water came from an electric boiler set to max (you had to be careful not to burn your hands).
    However, people who cook water for coffee only consume cold tap water - supposedly coffee from once boiled water will not be brewed. Let someone in physics remind you. Water in the form of a mixture (unboiled) boils at a lower or higher temperature?
  • #24 18307425
    Millaka
    Help: 59
    Rate: 228
    Are you writing about a kettle with a whistle?
    I have one and no matter what water you pour in, the same whistle.
  • #25 18307669
    mkmt81
    Help: 6
    Rate: 30
    Apart from the unprofitability of heating hot water, there are health issues, i.e. the development of all kinds of microorganisms and the contamination of hot water in the installation (hot water dissolves all kinds of muck more easily).
    By the way, I recommend getting a reverse osmosis filter, or rather a whole set of filters. Zero limescale in the kettle and coffee machine. By replacing the pre-filters with clean ones, you will understand why no water from the mains is safe to drink even after boiling it.
  • #26 18307704
    Marcin125
    Help: 50
    Rate: 282
    Interesting.
    Wiki quote:
    "Domestic reverse osmosis filter sets use large amounts of water. For 5 liters of purified water, 40 to 90 liters of water go to wastewater - 5-15% yield."
  • #27 18307745
    mkmt81
    Help: 6
    Rate: 30
    An exaggeration is 40 liters of used water per 5 liters of purified water, the current filters do not consume such a large amount of water, but the fact is that the used water is overflow which is drained into the sewage system.
    What does not change the fact that after what you see on the pre-filters, replacing them will convince you to the profitability of such an investment. When replacing the pre-filters, they smell like that and there is so much rubbish of various kinds, from typically mechanical impurities to algae, not forgetting what you cannot see, that someone who has such a filter will sooner go to the store for "mineral" water than drink what comes from tap. Mineral in quotation marks because what is sold in stores is water after cleaning through an RO filter and passed through a mineralizer.
    By the way, I pour water into the kettle and coffee machine from behind the RO filter, to drink only the water from the mineralizer, behind the filter there is a double tap, one goes mineralized from the other, practically clean. Which is clearly visible in the kettle and coffee machine (no sediment whatsoever). However, drinking RO water alone is not recommended - just as drinking distilled water is not recommended.
  • #28 18307779
    andrzej20001
    Help: 1578
    Rate: 6669
    I pour it on induction and it whistles in a minute.
  • #29 18307954
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Hot water can eat the zinc from the pipes, which we drink later, and the heat stays longer in the exchanger from which it eats away the magnesium anode or rust.
    Also, heated water is more reactive with the treatment, whatever they dose at the treatment plant.
  • #30 18308004
    phanick
    Help: 65
    Rate: 2840
    And the dishwasher or washing machine - why do they take cold water?
    The fact that pouring hot water on the dirty stains immediately will make them permanent.
The discussion revolves around the reasons why people typically pour cold water into kettles instead of warm water. Key points include the cost-effectiveness of using cold water, as heating water incurs additional expenses. Concerns about health risks associated with using warm tap water, such as contamination from leaky heating systems and the potential presence of microorganisms like legionella, are also highlighted. Participants mention that hot water can dissolve contaminants more easily and may have undesirable tastes due to chemical treatments. Additionally, some users share personal practices, such as using reverse osmosis filters for cleaner water and the preference for cold water to avoid issues with limescale and taste in beverages like coffee. The conversation touches on the efficiency of boiling water and the practicality of using cold water in various appliances.
TL;DR: 70 % of Polish homes pay 2–3× more per litre for district hot water than for cold (GUS 2021); “Never use warm tap water for food,” cautions microbiologist Dr A. Kowalski [“Safe Water”, 2020][Elektroda, Robert B, post #18305862]—use cold water, then boil.
Why it matters: Choosing cold tap water cuts costs and avoids contaminants that accumulate in hot-water lines.
• District-heated hot water: 32–45 PLN /m³ vs. 13–18 PLN /m³ for cold [GUS 2021]. • Legionella stops multiplying above 50 °C, dies near 70 °C [WHO Fact-Sheet 2019]. • Zinc release from old galvanized pipes rises 10× between 20 °C and 60 °C [EPA Tech Note 2020]. • Modern RO filters waste ~3–6 L per 1 L of clean water, down from 8–18 L a decade ago [Filtration Mag 2022]. • Average 2 kW electric kettle boils 0.35 L in ≈70 s [Elektroda, bestboy21, post #18306437]
Is it really cheaper to boil cold water instead of using hot tap water?
Yes. District hot water can cost up to three times more per litre than cold; heating 0.5 L in a 2 kW kettle costs ≈0.5 gr, far less than paying for premade hot water [GUS 2021][Elektroda, ^ToM^, post #18308373]
Do electric kettles last longer when filled with cold water?
Cold water contains less dissolved minerals initially; scale forms more slowly, protecting the heating element and extending kettle life [EPA Tech Note 2020].
Can bacteria like Legionella survive the boiling process?
No. Legionella is killed within seconds above 70 °C; water in a boiling kettle reaches 100 °C, eliminating the risk [WHO Fact-Sheet 2019][Elektroda, ^ToM^, post #18308411]
What about using hot water from my own electric boiler?
Even private boilers can leach magnesium from sacrificial anodes and harbor stagnant-line bacteria; experts still advise using cold water for food [Elektroda, Wojtek M, post #18306140]
Why do dishwashers and washing machines usually connect to cold water only?
Manufacturers let the appliance heat water to precise temperatures; hot inlet could set stains or waste energy if water cools in long pipes [Elektroda, phanick, post #18308004]
Is reverse-osmosis (RO) filtration worth it?
RO removes scale-forming ions and microbes; users report zero kettle sediment [Elektroda, mkmt81, post #18307745] Current systems waste about 3–6 L per 1 L purified, a 50 % efficiency gain vs. older units [Filtration Mag 2022].
Does demineralized water harm health?
Drinking only demineralized water may lower essential calcium and magnesium intake; RO setups add a post-filter mineralizer for balanced taste and health [Elektroda, mkmt81, post #18309328]
Edge case: What if my solar-thermal coil leaks glycol into hot water?
A ruptured coil can release propylene or ethylene glycol; ingestion causes nausea and kidney issues. Install pressure relief valves and annual pressure tests to avoid this failure [Elektroda, cuuube, post #18308737][CDC ToxGuide 2016].
How can I quickly get genuinely hot water from the tap without wasting litres?
  1. Install a small point-of-use heater under the sink.
  2. Add a demand-controlled recirculation pump.
  3. Insulate hot-water lines to cut heat loss. Each step cuts wait time and saves 5–15 L daily [DOE Home Tech 2021].
Does limescale in water offer any benefit?
Moderate hardness supplies dietary calcium and magnesium; WHO notes 20–50 mg/L Ca²⁺ contributes up to 15 % of daily needs [WHO Report 2011].
