DIY Mini Wind Power Plant: Creating Efficient Lighting for a Square - Alternator, Voltage Options
BlackMill 82860 13
How can I build a small wind turbine to light a square, and should I use 220V, 12V, or 24V with batteries?
You need to size the generator to the actual lighting load first, because the square’s size, the number of lamps, and their wattage decide whether 12/24V or 230V makes sense. For a larger square, a 12V or 24V generator may not provide enough energy, and both the low-voltage and 230V options still need over 1000 rpm; one reply suggests using a 3~ cage asynchronous induction motor as a 230V generator [#10482779] If you want a cheap DIY option, another user reported testing two cordless screwdrivers as drive/generator and getting almost 14V and 5A, about 70W, enough for a 12V/55W H3 bulb [#10656743] A different reply says rebuilding a washing-machine motor is expensive and recommends buying a ready-made “windmill generator” instead [#10647982]
  • #1 10482318
    BlackMill
    Hello, I have a problem, I want to make a small wind farm to illuminate the square, but I do not know what to do with a normal 220v or 12 or 24. Because the NP alternator needs quite high revolutions, what to make the transition from what, or maybe will be better because the energy will be accumulated in the batteries I do not know what to do, please help. And thanks in advance.
  • #2 10482757
    gomak22
    Help: 6
    Rate: 14
    and how large square do you want to illuminate?
  • #3 10482779
    marcin55246
    Help: 53
    Rate: 168
    Specifically, how large a square do you want to illuminate? and how many bulbs do you want to connect and what power? then you can think about the type of generator to use.
    By creating 12 or 24 V generators, it may not give enough energy (in my assumption it will be a larger square). You can also use a 3 ~ cage asynchronous induction motor to make a generator for 230V. You need over 1000rpm for both solutions anyway, so there's a choice.
  • #4 10485358
    JESIOTR1
    Help: 64
    Rate: 441
    Maybe it suits you - once I built a 15 m in a few minutes - it still stands today.
    http://www.youtube.com/watch?v=IqMtuk7mV8k&context=C357d0caADOEgsToPDskK4O47nNh2yNFBPTr-Igip1
    It shines LEDs and charges small batteries up to 12 V - for several years now.
    You cannot see the propeller - in the film the phenomenon of Steroscopy changes the rotation "wrong way" and slows down.
  • #5 10634509
    mk1265
    Rate: 11
    JESIOTR1 I have a question for you in your project, what did you use to produce electricity? I would also like to do something similar, just connect it to a garden fan, I was thinking about an alternator but I do not know if I will succeed
  • #6 10635583
    JESIOTR1
    Help: 64
    Rate: 441
    mk1265 - Alternator No. You will be better Motor than Washing Machine - There is a better stator there (Ready) - only you need to make the rotor. It will be more effective for all Heaven.
  • #7 10644166
    JESIOTR1
    Help: 64
    Rate: 441
    I used an electronic drive motor - almost any one is suitable.
    It is best to wind a stator in three phases according to needs, stick neodymium and twirl.
    I have a little baby wound up on the balcony, it is lying in the garage. I also have a little bigger one rolled up from the washing machine for the garden.
    DIY Mini Wind Power Plant: Creating Efficient Lighting for a Square - Alternator, Voltage Options DIY Mini Wind Power Plant: Creating Efficient Lighting for a Square - Alternator, Voltage Options DIY Mini Wind Power Plant: Creating Efficient Lighting for a Square - Alternator, Voltage Options
    You don't have to be lurking - I encourage you to DIY.
  • #8 10645259
    mk1265
    Rate: 11
    The problem is that I have never done it, I am studying electronics and I have a project of a hybrid power supply for garden lighting to implement and I need some generator for a windmill of such a typical wooden garden, so any gears would not interfere. I have a washing machine motor, but I don't know if I can convert it
  • #9 10647982
    JESIOTR1
    Help: 64
    Rate: 441
    They do not teach this in college yet. When remaking the washing machine motor, you have to invest at least PLN 300 in materials (copper, neodymium and trinkets).
    I recommend the ready-made alegro called "Prądnica do windmill" - there is a large selection - maybe you will find my offer + less than PLN 200 for the labor.
    You can't make it cheaper yourself. You have to study quickly - I can help you at PW.
  • #10 10656743
    anpaw-grojec
    Rate: 17
    Everyone wants to make generators from alternators or motors from washing machines, a lot of work and expenditure, and you can cheaper and simpler. I made a test in half an hour, namely two 18 Volt screwdrivers 900 rpm drive, the second as a 550 rpm generator without a switch and a regulator H3 bulb 12V 55W. At full speed, I got almost 14Volt and 5Amps, that's about 70W. Screwdriver motors, even if used heavily, rarely break down, batteries and switches do not go out. by connecting them in series or in parallel. So cheap and easy to make a good power plant, on the exchanges you can buy a screwdriver for a few zlotys without batteries and chargers, and the chain and gears, preferably from an electric scooter, the chain is thin which reduces the resistance and the gears have a large gear ratio, besides they are relatively cheap for all. I wish you good results to all those willing to undertake this test.
  • #11 10656869
    tomleszno
    Help: 19
    Rate: 61
    anpaw-grojec
    It was supposed to be a joke, of course.
    You tested your amazing construction for 10 minutes or maybe an hour.
    The windmill is supposed to run for years, not hours, days or months. At most an inspection once a year, lubrication, cleaning, etc. You dismantled the motor, since this screwdriver has ball bearings? Probably not. For this also a commutator in a crap design.
  • #12 10656984
    anpaw-grojec
    Rate: 17
    tomleszno
    This is no joke, I have repaired screwdrivers with a LI-JON battery, all of them had damaged switches, so powered screwdrivers have a bigger hoof than the nickel ones, and they spent two three years screwing screws on the roofs.
    After dismantling, I checked the motor, i.e. clearances on the sleeves and the commutator with brushes, the motors were in very good condition, they did not even spark. The motor shaft is loaded in a triangle, so most of the resistance on the bushings is taken over by the modes, otherwise it is only receiving one mode, the front and rear bushings it is rubbed on opposite sides. It is known that it is not a professional generator, but the wind does not blow so strong all the time that it would destroy the generator after a few days. This solution is partially educational for less advanced hobbyists because it is simple and cheap. I am going to build a wind farm. but I live in the city center in a one-family estate and there are houses around, but the wind is even quite strong, I have a 1.5 kW DC motor with its own excitation 8 pole pieces, at 600 rpm it gives about 250 Volt vertical turbine three blades AL 1 sheet at 2m, the height and shape of the blades must be selected experimentally mounted in the frame in the frame, suspension, two crosses from the washing machine, automatic the removal of the seals is very easy, simple and cheap on two bearings. Advantage no permit needed because it is a long haul truck. The use of water heating, without batteries, which lowers the cost, and an additional tank as a battery is relatively cheap. I think it will work out.
  • #13 10657059
    zenon1967
    Rate: 50
    tomleszno
    Do not stress the collegiate power plant with a screwdriver [even a few pieces connected in series ......] good idea - I support it.
    The second good idea is a vertical turbine on the roof for heating water based on a 600 rpm engine.
    More ideas like this and we'll get out of the crisis quickly.
    Only one small but col. Apnaw- be careful that the water does not boil for you.
  • #14 10657331
    anpaw-grojec
    Rate: 17
    zenon1967
    As I mentioned, a screwdriver, washing machine motor or alternator used for a windmill is similar to a power plant as a children's bicycle for a car.
    I read the question of a mini power plant with a stepper motor or other ideas where you have to put a lot of work and money and the effect is none. Making a 200 or 300 watt wind generator and a good wind is like dividing a match into four, how to use this energy, charge the batteries and what further emergency lighting can be a 12volt LCD TV, and maybe a heater in a 10-liter bottle.
    Here's an idea for a cheap and simple DIY generator for hobbyists.
    I wrote a generator from a 1.5 kW engine that the car was being dragged on the envelope roof, I think it will not go, I had to support the roof over the stairs with a pipe pillar, I had to get a permit because the hole flooded with concrete is a great construction and without permission it is arbitrary, what about the mast for the windmill what I am writing a pinwheel.
The discussion revolves around creating a DIY mini wind power plant for illuminating a square, focusing on the challenges of selecting the appropriate voltage (220V, 12V, or 24V) and generator type. Participants suggest using a washing machine motor or screwdriver motors as alternatives to traditional alternators, emphasizing the need for high RPMs (over 1000) for effective energy generation. Various DIY approaches are shared, including the use of neodymium magnets and electronic drive motors. Concerns about the longevity and maintenance of the constructed generators are raised, with recommendations for simpler, cost-effective solutions. The conversation highlights the importance of battery storage for energy accumulation and practical applications for the generated power.
