Building a Wind Power Plant with an Alternator: Managing Battery Charging and Excitation
wic1 40482 40
How do I connect a wind turbine alternator to a battery so the battery doesn’t overcharge or discharge from excitation, and what should I do with excess power when the battery is full?
Use a proper voltage regulator and a rectifier/diode on the alternator output so the battery is charged one way only and cannot backfeed into the generator [#15063639][#15067106] Do not keep the excitation winding powered all the time from the battery; instead, switch excitation on only after the rotor reaches a set speed with a low-current speed-sensing circuit that draws only a few dozen mA [#15063639] For excess energy when the battery is already full, use a controller that gives the batteries priority and then switches the surplus to a dump load such as a heater, preferably with PWM so the load comes in smoothly [#15785261] Several replies also warn that a car alternator is a poor wind generator because it needs high RPM, around 900–1200 rpm or even more, and the gearing losses make the usable power small [#15063795][#19827006] Because of that, people recommend a purpose-built low-speed generator, for example a rewound washing-machine motor with neodymium magnets and an external regulator, instead of a standard alternator [#15068533][#15785423]
  • #1 15063588
    wic1
    Rate: 59
    I know that we have excited and non-excited alternators. So such non-built-in generators are practically generators without a voltage regulator.
    Excited require a small current to start charging.
    I want to build a wind power plant with an alternator (easy, small maintenance) but I come to some considerations.
    When the battery is charged, what to do to prevent the alternator from charging and burning anything?
    When the battery only does the excitation current, what to do not to discharge it and then have something to excite the alternator?
    I thought about experimenting...
    A windmill, an alternator, a battery, a small lighting installation (without professional knowledge) that will illuminate the surroundings of the house at night on a motion and dusk sensor.
    Then I thought about experimenting with 12v or other heaters that would support central heating or heat water. And here the problem came to my mind ... since the alternator requires current from the battery for excitation, how to connect it (or bypass it) so as not to discharge the battery to zero?
    Alternatively, how to make the alternator charge the battery for excitation (e.g. small, motorcycle) but take the current for heating CO only from the operation of the alternator?
    Another thing is how to put cables in such a home power plant from the alternator? Is there any ready-made device that transmits electricity to such installations? Do you have to make such a 'miracle' yourself?
    Gentlemen, any ideas?
  • #2 15063639
    bestboy21
    Level 40  
    Help: 566
    Rate: 781
    The alternator will not overcharge the battery and certainly not in the "wind" mode, that's why it has a voltage regulator.
    The excitation can be done on the basis of a rotational speed counter, which will consume several dozen mA (and may stand still for days) instead of a few W and will turn on the excitation only after reaching "x" revolutions.
    There were 666 topics and 999 solutions.
    The solution with the alternator ... sorry, it is suitable for an allotment garden and not for everyday use, too little power. You'll do it like a donkey and you'll find that you can recharge your laptop, because it won't be enough for anything else. The nominal power of the alternator is a poor indicator of what you will achieve here (subtract some 70% ;p). It will be only 150W if it's windy. Dude's ass ;) .
  • #3 15063735
    wic1
    Rate: 59
    I also thought about the construction of the 'American' but here you have to do everything from scratch and there is also the issue of the voltage regulator and the like. Some people still want to calculate it but without deeper explanations (and not everyone wants to explain their theories) most of the 'patterns' or theories are unlikely to be performed without proper training :P
    So the alternator doesn't seem like such a bad solution.
  • #4 15063795
    bestboy21
    Level 40  
    Help: 566
    Rate: 781
    You need at least 900-1200 revolutions on the alternator shaft, the transmission is another loss, because the "propeller" will definitely not have such revolutions. Well ... but by increasing the revs you reduce the torque ... meatball. When the load is turned on, the machine will start to rear up ;)
  • #5 15064377
    Kwazor
    Help: 184
    Rate: 530
    If you wind a 120w per coil alternator with 0.8 wire (org is 60 with 1.3 wire) a 45A Bosch alternator, it will charge from about 400 turns.
    But the rotor must have neodymium magnets and you need to make an external regulator.
  • #6 15064388
    bestboy21
    Level 40  
    Help: 566
    Rate: 781
    So no difference compared to the American woman he shuns ;)
    In one season The Colony made "energy" out of an alternator, a windmill the size of a helicopter propeller, and a gear ... chain : it worked in light winds, but the size and noise ... (burning the wood they used to make the steam locomotive move) :D
    That's more or less what it looks like ;)
  • #7 15066583
    wic1
    Rate: 59
    I have a piece of plot with my family, so sizes are not a problem. The plot would work :)
    Back to the case.
    Alternator eg star 200. Each alternator has 3 outputs.
    For battery, ground and charging.
    So probably + - and mass or something like that ... but I could be wrong.
    How much does it need to wake up? How to avoid battery discharge in such a situation?
    Is it possible to connect it so that the battery is charged from the alternator and is only for excitation, and all further power goes, for example, to lighting and a second battery or heaters or all at once?
    A question from another series.
    I have an old washing machine at home. Big, heavy, very hard to spin... and probably burnt (to be rewound).
    Can you refer me to some material in a nutshell how to rewind it and how to make it american?
    I know, there are a lot of topics on the alectroda but reading 463 pages of posts where 85% are questions is a big waste of time. Of course, I read it once a long time ago but maybe there are some places where I can find all in one?
    -- rewind the washing machine motor
    - create a voltage regulator (or buy)
    - create propellers, structure, mast...everything
    Apparently, I need to consider each point and read up on the subject again.
    Regards
  • #8 15066608
    bestboy21
    Level 40  
    Help: 566
    Rate: 781
    Attach a propeller to the dynamo... and charge your smartphone ;)
    You still have to read a lot, a lot, a lot, a lot, a lot.
  • #9 15066621
    prose
    Level 36  
    Help: 172
    Rate: 848
    You let go through the diode to the battery and you have it, you connect the battery heater to the alternator and it will not charge you.
  • #10 15067066
    wic1
    Rate: 59
    What diode?
  • #11 15067106
    prose
    Level 36  
    Help: 172
    Rate: 848
    wic1 wrote:
    What diode?
    You take the rectifier from the alternator to the battery and straight from the alternator and the battery will be charged through the diode, it will not let go the other way.
  • #12 15068093
  • #14 15099309
    wic1
    Rate: 59
    101pawel wrote:
    how far are you from building a windmill? It's about the mast, and what's on that mast.
    At the moment I am "in the woods" because I work in the city and return to the subject during holidays. I considered the issue of the alternator because it simply does not require too much work. The only thing that worries me is the low power with high wind demand.
    At the moment I am considering a construction resembling an Attic Turbine, but larger and flatter. Something like a flattened vertical turbine.
    My parents' house is relatively tall and I was thinking about a chimney structure. The only thing that worries me is possible vibrations and behavior in strong winds (which would not break the chimney).
    Initial plan:
    Windmill / blades etc (if I can do it myself).
    Alternator + gear from bicycle sprockets and chain.
    Battery
    Some kind of measuring element checking 'power'.
    Motion sensor lighting under 12v (lights, sensors, wiring)
    Possibly an inverter to have a spare for the laptop.
    Design in a nutshell...do it yourself with minimal electrical knowledge.
    As for the generator from the washing machine engine, I'm all for ... but I have no idea.
    I spread out on the issue of 'rewinding' such and then on the connection, the construction of the voltage regulator and the charging regulator for something like this.
    In addition, there is the issue of the brake design and on the alternator, it probably does not make sense because I will never reach 100% anyway :P
  • #15 15099313
    Krzysztof Kamienski
    Help: 2032
    Rate: 5157
    wic1 wrote:
    Possibly an inverter to have a spare for a laptop.
    Rather, a car-type power supply ... but it's also an "inverter". But the question? Isn't it better to have a solar installation? It's simpler, reliable, always works ...
  • #16 15110552
    kasperek21
    Rate: 40
    Hi
    I see you're thinking like I was at first. Now, looking back, I find that it didn't make sense.
    I wasted my time and money.
    Consider, making a wind turbine is not so simple. Starting with the rotor blades, each suitable profile is all balanced. Then the generator. If you want to do it, but don't be surprised that you will spend money on crap and the effect will be meager.
    I bought a 300W turbine for 220EUR.
    Read my posts and you will see what hits I had :)
    Regards
  • #17 15214737
    wic1
    Rate: 59
    kasperek21 wrote:
    Hi
    Regards
    I just saw a 600W turbine somewhere on amazon for about $50-100. I thought about giving it a try to start with. It's small and you can combine it with propellers :)
  • #18 15785198
    kasperek21
    Rate: 40
    Hi
    Dear Colleagues, do not buy cheap.
    My 300W Chinese wind turbine got Parkinson's. He's crawling with the whole mast despite the guy wires.
    I advise proven companies. Knock on wood, the inverter is still alive.
    Another Chinese is warming up like stupid. I hid it in an air-conditioned cabinet of my idea.
    I recommend solar energy. Less hassle and more electricity.
    Regards
  • #19 15785261
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    I have a self-made generator from a 1.5KW 720 rpm engine, original winding and nothing is spinning or heating up. The 2.5 m diameter propeller can reach almost the rated speed of the generator and power up to 2 kW. I use the voltage from the generator first to charge the batteries with impulse chargers, and then to heat the water in the boiler, I have the pwm controller set so that the batteries are the priority and when they are charged the voltage increases and the pwm on Attiny is switched on, smoothly turning on the 1500W heater load.
    The windmill, by comparison, has no chance with PV panels when it comes to the amount of energy produced, but there are days when I have to stop it because I have too much energy and the boiler has boiling water and a full battery. Regards, Edward.
  • #20 15785365
    kasperek21
    Rate: 40
    Edzio, where can I see your beauty? Put up some photo. How tall is the mast?
    Where I live, I can't afford anything big. I think I'll download this Chinese and tighten it or break it.
  • #21 15785423
    JESIOTR1
    Help: 64
    Rate: 441
    Generator, generator from alternator - After we have to throw away the brush-holder, slides and electromagnet from the rotor, we get the same as the stator from the induction motor from the washing machine.
    The stator from the washing machine is on average 4 times larger, more useful - it has a larger diameter for the rotor, a larger capacity for copper in the grooves.
    We still have an almost ready rotor in a full-time casing - just roll a few millimeters in diameter.
    In the stator we have a three-phase winding that is suitable for use - Practically, how many revolutions is and so many volts - it generates on the neodymium rotor.
    Three-phase rectifier from the alternator or buy two single-phase ones for PLN 3 and bridge the pluses and minuses.
    If you need more power, replace the 0.4 mm washing machine wire with a wire with a diameter of about 1 mm and spin faster - 1 rpm = 60 rpm and we have at least 12 V to charge the battery - up to 20 A on the mast .
    12 V x 20 A = 240 W - for this, a turbine with a diameter of 1 m on the axis (without gears) from hand materials on a mast over 2.5 m high is enough.
    Good luck.
  • #22 15785431
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    Three photos of my windmill, and I live near Częstochowa.
    Building a Wind Power Plant with an Alternator: Managing Battery Charging and Excitation Building a Wind Power Plant with an Alternator: Managing Battery Charging and Excitation Building a Wind Power Plant with an Alternator: Managing Battery Charging and Excitation
  • #23 15786391
    kasperek21
    Rate: 40
    Hi
    Are these blades self-made?
    When I return to Poland for good, I will put about 5 kW.
    I even like your windmill, only I would make the tail more fanciful.
    Regards
  • #24 15786554
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    The shovels were bought, but they are almost professionally made, and the tail is different, my wife likes it :D
  • #25 15786821
    kasperek21
    Rate: 40
    What was the cost of the whole business?
  • #26 15786984
    CKCK
    Rate: 46
    Hello!
    What about the neighbors?
    How far do they live from your windmill?
    Regards, C.K
  • #27 15787175
    kasperek21
    Rate: 40
    As far as I'm concerned, the neighbors don't complain. I can't hear anything in the house. Although in the neighborhood you can hear him screwing up :) )
  • #28 15787422
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    When the wind blows, there is more noise from the wind than from the propeller and generator. I once had an American and a wooden propeller that whistled at high speed and the generator howled and I had to get rid of it. This fan runs quietly. And I have a neighbor who says very little, sometimes pretends not to see me in the square, and casually raises his hand in my honor.
  • #29 15787436
    kasperek21
    Rate: 40
    Edek, the neighbor raises his hand casually, because he lacks the strength for your inventions :)
    My first savonius was moaning like crazy.
    A neighbor suggested to me that there must be something wrong.
    It's important to break the bottle with your neighbor from time to time :)
  • #30 15787448
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    It's impossible with him, he's a complete abstainer, he doesn't drink, he doesn't smoke, and it's not the fault of my inventions that he's like this, because I didn't have a fan and it was even worse. But I have to say one more thing, when I tell him that I pay PLN 70-80 for energy in the summer (and he pays PLN 150-180 for a month) for two months, I have hot water every day, and I don't burn in the stove to wash myself in the evening, well that's a bit moves him. But for now, he won't be persuaded to buy collectors or panels, he prefers to smoke in the furnace and smoke my atmosphere. And I have a self-made collector and photovoltaic panels, including one set on a tracker and a windmill. And everything works from sun and wind. He smokes me before evening so I can and should be pissed too. But in general it's not bad, you have to live well with your neighbor (and your neighbor) because you don't know who can ask for help when.
✨ The discussion revolves around building a wind power plant using an alternator, focusing on managing battery charging and excitation. Key considerations include preventing overcharging of the battery, ensuring proper excitation current, and the challenges of achieving sufficient revolutions for effective power generation. Participants suggest using a voltage regulator, diodes for current direction control, and experimenting with different alternator types, including those from washing machines and trucks. The conversation highlights the complexities of wind turbine design, including rotor blade efficiency, gear systems, and the potential for integrating solar energy as a simpler alternative. Concerns about low power output and the need for high RPMs are also discussed, along with practical advice on construction and component selection.
TL;DR: A rewound 45 A Bosch alternator begins charging at ~400 RPM and can push 150 W in 8 m/s wind [Elektroda, Kwazor, post #15064377] “Use neodymium magnets” [Elektroda, Kwazor, post #15064377] Putting a blocking diode between alternator and starter-battery stops back-drain [Elektroda, prose, post #15067106]
Why it matters: These quick tweaks let a low-cost alternator safely feed off-grid lighting or heaters without killing your battery.
• Stock cut-in speed: 900–1200 RPM on most car alternators [Elektroda, bestboy21, post #15063795] • Rewind + magnets drops cut-in to ~400 RPM [Elektroda, Kwazor, post #15064377] • Excitation draw: Approx. 2 A at 12 V for 55 A alternator (Bosch Training Manual, 2010) • Schottky blocking diode loss: 0.35–0.5 V, 50–100 A parts cost ≈ €3 (Mouser catalog) • 300 W Chinese turbine retail: €220, but severe vibration reported after months [Elektroda, kasperek21, post #15785198]
How do I stop the alternator from over-charging or discharging my battery?
Keep the factory voltage regulator in circuit. Add a high-current blocking diode on the + line to the starter battery; it allows charge in but prevents reverse flow at night [Elektroda, prose, post #15067106] A fully charged 12 V lead-acid should float at 13.8 V, so set the regulator to that value (Bosch Training Manual, 2010).
What diode should I choose for a 12 V, 30 A wind system?
Use a 50 A Schottky stud diode or a ready-made three-phase alternator rectifier block. Forward drop is ~0.4 V, wasting about 12 W at 30 A—acceptable for small systems (Mouser catalog). Mount it on a heat-sink with thermal paste; overheating is the common failure edge-case.
How much excitation current is required and how can I supply it safely?
A 55 A alternator takes roughly 2 A at 12 V to build its field (Bosch Training Manual, 2010). Place a small 7–10 Ah AGM battery behind the blocking diode. It powers excitation, then recharges once the alternator is live—no deep discharge risk [Elektroda, prose, post #15067106]
Is it worth converting the rotor to permanent magnets?
Yes if you need low-wind start-up. Magnets cut idle losses and remove excitation draw, trimming ~24 W at 12 V. The trade-off is losing electronic voltage control; dump-load regulation becomes mandatory [Elektroda, MichałS, post #19827006]
How can I use surplus energy for water or space heating?
Add a PWM dump-load controller that monitors battery voltage. When it rises above 14.4 V, the controller diverts power to a 12 V, 1500 W heater element, as shown by a 2 kW fan owner [Elektroda, Edek45, post #15785261]
What cables and rectifiers are adequate for a 12 V tower line?
For 15 A continuous current, run 2×6 mm² copper to limit voltage drop below 3 %. Place the three-phase rectifier at the base to avoid climbing for maintenance and to reduce EMI that once jammed military radios [Elektroda, stachu_l, post #19883499]
What common failure modes hit low-cost turbines?
Cheap 300 W Chinese units developed mast-shaking “Parkinson’s” after months, forcing removal [Elektroda, kasperek21, post #15785198] Bearings seize, blades crack under gusts, and unbalanced rotors overheat alternators—budget for replacements within a year.
Can I run a vertical-axis turbine through a belt gearbox?
Yes, but account for 10–15 % belt losses and higher starting torque. A 1:2 ratio raises alternator speed but doubles shaft force. Ensure bearings handle the extra side-load [Elektroda, michal_dniepr, post #19833910]
Quick 3-step wiring: a dedicated excitation battery
  1. Wire alternator output to a high-current Schottky diode, anode toward alternator.
  2. Connect diode cathode to a small 12 V AGM battery; fuse at 20 A.
  3. From battery, feed regulator IGN terminal; add voltmeter for monitoring. The battery now excites, recharges, and never back-drains [Elektroda, prose, post #15067106]
