Creating a Pick List in Excel 2003 with 5 Data Options and Corresponding Cell Fill Colors
kotletti 12363 11
How can I make an Excel 2003 drop-down list with 5 choices that also fills the selected cell with one of 5 different colors?
Use a VBA `Worksheet_Change` event to color the cell based on the value chosen from the list, because Excel 2003 conditional formatting is not enough for 5 cases [#10800116] Put code like `Select Case Target.Value` in the sheet module and assign a different `Interior.ColorIndex` for each option: `a`→6, `b`→4, `c`→45, `d`→33, `e`→7, and clear the fill for anything else [#10800116] Open the VBA editor with `Alt+F11`, select the нужный sheet in the project, and paste the macro there so it runs when the cell changes [#10800116] Another reply also suggested using conditional formatting across the whole column, but the VBA approach is the one that directly solves the 5-color requirement in Excel 2003 [#10793413][#10800116]
  • #1 10788419
    kotletti
    Hello and sorry in advance that I am writing without Polish characters, I am in Singapore and the system does not allow me to use Polish characters :(
    The problem I have with Excel is as follows:
    I am trying to create a selection list so that after selecting the data, the cell in which the data is to be inserted should also change the color of the filling.
    The pick-list consists of 5 data and 5 different fill colors to make the document more readable.
    I tried to use the conditional formating option but this option only meets the conditions of 3 parameters :(
    Can I do this using this function or is there any other solution? If so, please help.
    Regards
    Capital letters, commas (and more) are not "Polish characters" - get your post in order. [M]
  • #2 10789264
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Can you insert (attach) some simple example because I don't quite understand the problem (let's say I understand half of it)?
    Do you definitely allow a solution with a macro?
  • #3 10789315
  • #4 10791786
    kotletti
    ok i will try to insert jpg maybe then it will be easier to explain
    https://obrazki.elektroda.pl/5089786700_1334362784.jpg
    as you can see, I have defined colors for 5 parameters so that they are more visible in the sheet
    the problem is that when adding new cells in the same column, using the selection list, the data from a to e were inserted, but together with the fill color
    when it comes to macros I should be able to handle it with somebody's help
    Best regards and thank you in advance for your help
  • #5 10793300
    walek33
    Help: 132
    Rate: 81
    As long as I have enough memory, it does not mislead me :D is called in Excel Conditional Formatting . Put in the same for all cells in the column and after the pain.
  • #6 10793316
    kotletti
    from what I know, conditional formatting in excel 2003 is only for 3 parameters a, b, c and in my case there are 5 :(
  • #7 10793413
    walek33
    Help: 132
    Rate: 81
    So there is nothing left for you to do but write your conditional formatting support for certain sheet cells. Put it in the event Worksheet_SelectionChange
  • #8 10799179
    kotletti
    Can you tell me how to do it because it's probably beyond my strength !!!
  • #9 10800116
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Sorry to veto, I would suggest in the section Worksheet_Change
    Private Sub Worksheet_Change(ByVal Target As Range)
    kod_war = Target.Value
    Select Case kod_war
     Case "a": Target.Interior.ColorIndex = 6
     Case "b": Target.Interior.ColorIndex = 4
     Case "c": Target.Interior.ColorIndex = 45
     Case "d": Target.Interior.ColorIndex = 33
     Case "e": Target.Interior.ColorIndex = 7
     Case Else: Target.Interior.ColorIndex = 0
    End Select
    End Sub
    in Alt + F11 sheets
    In the project with the name of your file, you click on the sheet you are interested in, e.g. Sheet1
    and paste the above code there
  • #10 10800141
    walek33
    Help: 132
    Rate: 81
    And very beautiful. You can see that a professional wrote. You were faster. :D
    I would suggest just for embellishments:
    Code: text
    Works the same and looks better. And it has one more great advantage that I don't dare to mention. :D
  • #11 10800256
    marek003
    Level 40  
    Help: 801
    Rate: 488
    I agree as much as possible :)
    Alternatively, I would throw the line:
    Case "": .ColorIndex = 0
    because it actually meets Else (which I checked empirically :) )
    but I support the amendment with both paws :)
  • #12 10803004
    kotletti
    You are great, thank you so much for your help !!!
The discussion revolves around creating a pick list in Excel 2003 that allows users to select from five data options, each corresponding to a specific cell fill color. The original poster seeks a solution to apply conditional formatting for five parameters, noting that Excel 2003's built-in conditional formatting supports only three conditions. Various responses suggest using macros to achieve the desired functionality. A specific macro code is provided to change the cell's fill color based on the selected value from the pick list. The conversation includes suggestions for improving the macro's structure and efficiency.
