Excel - Color Coding Cells in Main Employee List Based on Leave and Sick Status Columns
Gandalf1967 23528 4
  • #1 10680562
    Gandalf1967
    Welcome back.
    Before I ask a question here, I try to solve it by looking in ready-made topics. I found solutions to problems similar to mine, but without the possibility of applying them in this case. The point is that I have three columns on one sheet. One contains the names of all employees, the second is a list of employees on vacation, and the third is a list of sick employees. I would like the cells with employees on leave to change their color on the main list (all employees) to e.g. blue, and those on sick leave to e.g. orange.
    I tried to do it with the simplest method for a layman, that is with conditional formatting of cells from the main list, but as usual I got stuck on a formula that would search for these employees from the "absentee" lists.
    I hope someone has already rubbed against something similar and can help me with that.
    Regards.
  • #2 10681500
    adamas_nt
    Help: 1508
    Rate: 659
    If you don't mind a color source column, the easiest way is:
  • #3 10681769
    Gandalf1967
    A great idea - by the colors. There are only two problems: at work I have excel2003 and I'm afraid that there is not even such an option there, and secondly - I have had Excel 2007 recently and I do not know how to set the formatting in your way :| . I don't dare to ask for a "physical" example - you learn new things in your life ... I'm just afraid that it won't work in the 2003 version ...
  • #4 10682056
    adamas_nt
    Help: 1508
    Rate: 659
    In E2007, the matter is very simple. You select the columns (non-contiguous by holding down the Ctrl key), select> conditional formatting> format only unique or duplicate values. You choose the filling and that's it.
    I saved in E2k3 format. Formatting partially works in OpenOffice (I don't have E2003). The formula, hmm, after converting to OO was a bit long :) but quite understandable. It should be straightened and a second one added. Maybe someone will check in E2003, while throwing prtScr with the rules window?
    In the attachment the above-mentioned file.
    • Gandalf.xls (18.5 KB) You must be logged in to download this attachment.
  • #5 10684475
    Gandalf1967
    Not so much that I improved but - I added a new line to change the color of both options (holidays and sickness). It works fine, but significantly slows down the operations performed on this sheet by a few seconds. It seems that this form of formatting is a heavy burden on the system (budget computer at work).
    https://obrazki.elektroda.pl/8781410300_1331898630.jpg
